    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 05-02-2015, 04:36 PM   #13471
aeRayls's Avatar
Originally Posted by BrandonBreh View Post
Anybody having problems with a shock sitting on the mount? I have the aluminum mounts and there is a ton of play between the shock and the mount.
You need the plastic replaceable pivot balls. The newer packages include them
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 05-02-2015, 04:59 PM   #13472
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
AE should really do a better job with those. the mounts should come with balls.....silly
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-02-2015, 05:08 PM   #13473
KrAcOn's Avatar
Agreed, I got some new aluminum ones and put on new shocks and there is play in there.
I'm thinking the plastic ones like what are on My B5M-L are a better way of doing it.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 05-02-2015, 05:55 PM   #13474
I got the short shock mounts. They will still work correct? To get those black pivot balls, do i need to buy the other package?
BrandonBreh is offline   Reply With Quote
Old 05-02-2015, 08:27 PM   #13475
Fabulous's Avatar
Trader Rating: 42 (100%+)
If your going to use the Aluminum Shock Bushing on your B5M you need both parts which are sold separately.
ASC91533 Shock Bushings
ASC91447 Shock Bushing Balls
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 05-02-2015, 08:28 PM   #13476
3srcracing's Avatar
Trader Rating: 25 (100%+)
Mine came with the bushings in it.
Going to the 1.4x3 will just give more steering right? Seems to be a very common setup change, but I don't think I could handle more steering.
The spacers on the ball-stud on the front shock tower affects what?
3srcracing is offline   Reply With Quote
Old 05-02-2015, 08:36 PM   #13477
I use the avid ones. 5 months and still snug on the shock caps
Old 05-02-2015, 09:28 PM   #13478
Here is a complete guide on using ballstud washers and how they effect the car
Tune With Camber Links
Old 05-03-2015, 07:22 AM   #13479
Mason's Avatar
Originally Posted by RCW View Post
Sorry if it's already been said, but the setup sheets from the stock Nats are posted on AE's site.
I love how kody's setup sheet for electronics says see rivkin's setup.. and then rivkin's sheet says see rivkin's sheet.
Mason is offline   Reply With Quote
Old 05-03-2015, 07:41 AM   #13480
aeRayls's Avatar
The alum shock mounts now include the plastic pivot balls!!
Old 05-03-2015, 09:30 AM   #13481
nice
Old 05-03-2015, 09:30 AM   #13482
they probably mean rivkins reedy 410 setup.
Old 05-03-2015, 10:11 AM   #13483
3srcracing's Avatar
So from what I understood, adding a spacer on the front shock tower (from 1mm to 1.5) will make the steering less responsive and easier to drive?
Old 05-03-2015, 10:19 AM   #13484
aeRayls's Avatar
Correct
Old 05-03-2015, 12:12 PM   #13485
Trader Rating: 15 (100%+)
what are the benefits/ drawbacks of running the flat pistons, versus the tapered pistons?
motoman811 is offline   Reply With Quote
