    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 04-25-2015, 04:45 PM   #13306
Trader Rating: 478 (100%+)
I think that I need a new scale. Per my scale, my Lite with Ti upper screws, Ti ball studs, pucks, slipper eliminator, KO one10 servo, 2.4 wheels, CF strap, aluminum wheel nuts, and a Trackpower 90c 3250mah lipo, hobbywing 3.1 & Bandit motor weighs 1438 grams (minus wing and transponder). I have another car that is similar but it has a hand milled chassis and it was 1520 with a 4400mah SMC lipo. Is that possible? I might have to drive to Lowes and buy another scale....I'm going to do that right now.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-25-2015, 05:00 PM   #13307
....forgot, I have a second scale in my track bag. This a different scale and this time I threw the transponder on. You'll see the next pic without a body.
Old 04-25-2015, 05:03 PM   #13308
Here's without a body....
Old 04-25-2015, 05:28 PM   #13309
Originally Posted by Jmuck69 View Post
The online instruction manual at Team Associated's website lists what tools are needed.
2mm & 1.5mm
I looked over the instructions but I guess I missed that. Thanks for your help.
What about nut drivers? Are all the wheel nuts 5mm
tekin112000 is offline   Reply With Quote
Old 04-25-2015, 05:42 PM   #13310
Jmuck69's Avatar
5.5mm and 7mm. Wheel nuts and slipper nut are 7mm and all others are 5.5mm
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 04-25-2015, 06:59 PM   #13311
jmcelroy42's Avatar
Originally Posted by Mizchief View Post
Is that an RSX with an aftermarket cap? Does the cap give you better performance or did you just need a replacement?
Tekin actually sells 2 different sizes of caps,it's the bigger one,and I jus figured it couldn't hurt, bigger is better right?
Really loving the mid motor compared to the RM I jus switched from, can drive it so much harder (more like a 4x4)
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 04-26-2015, 01:43 AM   #13312
HSV427's Avatar
Trader Rating: 21 (96%+)
I was wondering has anyone tried the xfactory carbon chassis, i have a b5m with all the goodies so its really not worth getting the new lite, but my buggy can still afford to lose weight and was wondering would it be worth while getting the carbon chassis or getting the lite chassis any advise would be appreciated as i don't want to lose any of the great handling you get with the stock chassis.
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
Old 04-26-2015, 02:10 AM   #13313
Alot of guy's have been having success with Bezerk RC ' S carbon chassis. Won the Australian Stock Title. Contact Paul through Bezerk RC FB page.
71WOK is offline   Reply With Quote
Old 04-26-2015, 05:13 AM   #13314
Trader Rating: 48 (100%+)
Picked up my lite yesterday, started the build, the only thing missing is the front bumper. The car is coming together nicely.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-26-2015, 07:27 AM   #13315
RCBuddha's Avatar
Trader Rating: 33 (100%+)
I stuck a link on the front page for Bezerk R/C. Here's some examples of the work:
Probably the coolest thing about his services is he can re-produce older graphite chassis like for this HPI Pro:
RCBuddha is offline   Reply With Quote
Old 04-26-2015, 07:48 AM   #13316
Suspended
You're suppose to weigh the car as track ready.
Mantis Toboggan is offline   Reply With Quote
Old 04-26-2015, 08:29 AM   #13317
Thomas PA's Avatar
If you run on med-high grip or higher, you'll want the chassis stiffeners with it. The extra flex the chassis gives you is incredible on med-low bite or lower. You'll probably new a spring change either way, but it'll still feel great.
Thomas PA is offline   Reply With Quote
Old 04-26-2015, 08:34 AM   #13318
I investigated carbon chassis recently and some racers indicated they would load up on compression then release. Some of the drivers indicated they did not like carbon because of having to time the release point that may be inconsistant. I installed the lite chassis and am doing well @ 1502 grams.
Micah123 is offline   Reply With Quote
Old 04-26-2015, 10:18 AM   #13319
gabc's Avatar
I'm sure you could set it up for almost any conditions but based on how it is set up I'd say its really meant for a higher grip track the way they sell it. In the winter when traction decreases greatly on our track, we go heavy and set the cars up soft. The Lite is light and stiff.
That's a good point. Guess I'll go with the b5m n forget the extra bells n whistles of the Lite.. Unless someone really has tried and had good success with the Lite on loose tracks.
gabc is offline   Reply With Quote
Old 04-26-2015, 11:39 AM   #13320
motorcitymatt's Avatar
There is another nice CF chassis available from Plan B Racing. The claim is that it saves 78g over the stock (not milled) B5M chassis. Because it only costs $70 I decided to forego the Factory Lite and take advantage of the lower price and $15 gift certificate Tower had for the B5M Team Kit. I also like the ability to retain the use of velcro for securing the body via the delrin insert pieces.
https://www.facebook.com/planbrc
You can contact Plan B here: acercracer@gmail.com
Schumacher Cougar KC, KF2 SE
RC Clubhouse in Warren, MI
DiscountRCStore.com (The best online hobby shop)
motorcitymatt is online now   Reply With Quote
