    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-20-2015, 06:55 PM   #13141
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Originally Posted by BrandonBreh View Post
Can anyone tell me the difference between the c and d arm mount? Advantages and disadvantages? What is reccommended for indoor high traction damp clay?
I would guess it changes the angle of the hinge pins to adjust toe?
The C mount is on the front side of the transmission and controls toe and anti squat. The D mount is the rear most mount at the back of the car. Every car has a C and D mount
pink_sleeve is offline   Reply With Quote
Old 04-20-2015, 07:42 PM   #13142
Canada 95's Avatar
Default Battery wars
Maybe ROAR needs to introduce a minimum size and minimum weight of batteries stop the battery war that is now going on with smaller and lighter packs.
Will dumping return to racing??
Longer mains, smaller batteries, higher costs
I am a professional. At the circuit I am calm. At home I am very different.
Canada 95 is offline   Reply With Quote
Old 04-20-2015, 08:07 PM   #13143
Suspended
Trader Rating: 61 (100%+)
No serious 17.5 racer would use one of the small packs.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-20-2015, 08:15 PM   #13144
Trader Rating: 29 (100%+)
The small packs are more intended for mod to save a lil weight. In stock LRP now makes a lightweight LCG 4300mah pack its called a stock spec. The ultra shorty is intended more for mod.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 04-20-2015, 08:42 PM   #13145
xyzracer's Avatar
honest question, why not?
xyzracer is offline   Reply With Quote
Old 04-20-2015, 09:04 PM   #13146
Jordan Anderson's Avatar
Voltage.
Although Lipos do have a relatively flat discharge curve, none the less, as you deplete a pack in a race it provides less voltage.
A higher capacity pack will provide a higher average voltage over the duration of a race as compared to a lower capacity pack.
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 04-20-2015, 09:13 PM   #13147
Thomas PA's Avatar
Originally Posted by Jordan Anderson View Post
Voltage.
+1
This can be the difference between making a double double, or having to make it a double single single. And if someone else can still make it at the end, you're gonna lose some time to them there. Best thing to do is drop the weight elsewhere and run a bigger mah pack. I can run a 5000 and stay near minimum weight. Can really feel the difference over a 4100 pack at the end of a main
Thomas PA is offline   Reply With Quote
Old 04-20-2015, 09:53 PM   #13148
Suspended
IR and MAH.
Weight is not everything, but it's certainly something.
Old 04-20-2015, 10:09 PM   #13149
KrAcOn's Avatar
The following will ship from our Reno, Nevada distribution center
$40 Promotional Discount 1 -40.00
TOWER SPECIAL OFFERS-C 1 .00
ASCD9000 Associated RC10B5M 2WD Factory Lite Buggy Kit 1 279.99
SHIPPING AND PAYMENT
Current Charges (U.S. Dollars)
In-Stock Items: $239.99
Surface Shipment: Waived
Total Current Charges: $239.99
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 04-21-2015, 03:25 AM   #13150
alb
Trader Rating: 19 (100%+)
speaking of the C and D mount, How much of a difference do the brass mounts make? I lust got the set but have not put them on yet.
alb is offline   Reply With Quote
Old 04-21-2015, 06:47 AM   #13151
Suspended
I have tried the brass C mount, and actually like it on my t5m. The D mount doesn't make complete sense to me personally, but I'm sure there are several people that like it though.
Old 04-21-2015, 07:04 AM   #13152
Is there any reason a servo saver should not be used with a B5M?
rossb is offline   Reply With Quote
Old 04-21-2015, 07:14 AM   #13153
less steering feel. I've never had a problem on a 2wd buggy running no servo saver.
Hyperhobbies.ca
Rcbatterydepot.com
lee111m is offline   Reply With Quote
Old 04-21-2015, 07:17 AM   #13154
Suspended
15 years ago, definitely you needed/wanted one. Today's servos are so good and durable, that I just don't see the need.
The alloy racks, and the servo horns are suspect though on the T5M - I've even seen a stock plastic rack get broken. Remember this - you strengthen 1 part, then the other parts have the load transferred to them. Eventually this will affect the servo - Alloy rack, alloy bell cranks, alloy servo horn, and I'd bet you'll see broken steering blocks and broken servos.
Old 04-21-2015, 07:19 AM   #13155
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I suspect AE will need to beef up the alloy/plastic steering for the T5M. Probably an HD version.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
