    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 04-06-2015, 10:58 PM   #12871
Cridd's Avatar
Trader Rating: 16 (100%+)
Ty
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 04-07-2015, 05:11 AM   #12872
carcrusher46's Avatar
Trader Rating: 17 (100%+)
You can use the existing steel top shaft with the new V2 case, but you would need to use a 6x10x4mm bearing - they aren't a common size but there are a few companies that make them out there.
Matt Stoltz
Thank you to my sponsors:
Team Associated - Reedy - JConcepts - Life Fast RC Paintworks
carcrusher46 is offline   Reply With Quote
Old 04-07-2015, 05:38 AM   #12873
air8's Avatar
6x10(31404) is a common size for 8th scale off-road cars' steering post bearings I think...if that's the size needed.
This V2 case(91522), is this to be able to use the 3-gear aluminum top shaft?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-07-2015, 05:56 AM   #12874
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
This is so you can use the same top shaft when transitioning between the 3 and 4 gear. The newer cases also seem to mesh the gears together a little bit better.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-07-2015, 06:08 AM   #12875
air8's Avatar
Ah, ok. Nice. After I tried the 3-gear this weekend I was looking and wondering what do I do with this nice aluminum shaft now. LOL.
--"U Ain't Fast!!"
Chris Pearce
Old 04-07-2015, 06:21 PM   #12876
What is holding the motor wires together in the center? Is it just a piece of shrink tubing? I am working on installing the wiring on my new B5M and like how the wires are held together.
explorerlyon is offline   Reply With Quote
Old 04-07-2015, 06:30 PM   #12877
Trader Rating: 478 (100%+)
I have a couple b5 lite clones but I wonder how the real car is out of the box. Anybody have one yet? I'm curious. Its hard to keep up with this thread. I mention that in case I missed something.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-07-2015, 06:31 PM   #12878
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Yes shrink tube
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 04-07-2015, 06:32 PM   #12879
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
I used some 1/2" heat shrink for mine.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 04-07-2015, 06:32 PM   #12880
HBRob's Avatar
As far as I know it hasn't shipped yet.
#ocrcarmy
Old 04-07-2015, 06:39 PM   #12881
I'm trying to catch up on this thread and noticed a couple pages back that people were saying their X rings leaked? I find that hard to believe unless somebody really did something wrong. They might be one of AEs greatest achievements with the new 5 series cars.
Old 04-07-2015, 07:48 PM   #12882
Hi Guys.. I'm curious how long the Pucks usually last? I picked up a used B5M setup for 17.5, and don't think I ran it more then 5-6 practice runs before they were wore out, actually worn a little to far and started to wear on the out-drives. I ordered replacement pucks along with replacement out-drives I was lazy, decided not to replace the out drives just yet, and only replaced the pucks... they lasted maybe 3 practice/batteries. So, I'm assuming the out-drives are done and I'll replace them.. but going forward how long should I expect the pucks to last? Seems to me the molded plastic is pretty soft and led me to wonder if anyone makes them in a stronger material? Anyone know if anyone has tried to 3D print them yet?
Thanks,
Robbie
roffutt is offline   Reply With Quote
Old 04-07-2015, 07:51 PM   #12883
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Thanks,
Robbie
they need to be greased. I have 30+ packs on my current pucks
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-07-2015, 08:17 PM   #12884
HBRob's Avatar
Thanks,
Robbie
Make sure to apply black grease, also if your bearings on the axles have any slop in/out or up/down it will make them wear faster.
#ocrcarmy
Old 04-07-2015, 08:40 PM   #12885
I get 30-35 packs or 2 weeks out of a set of pucks. I use mobile one synthetic bearing grease on mine. All it takes is being lazy once to wipe a set out.
