Team Associated RC10 B5m Mid-Motor Thread
Has anybody run across titanium hinge pins yet? Looked around a bit and never found any.
Nick
Nick
Super Moderator
Trader Rating: 31 (100%+)
don't like'em thats why. tight. i'd prefer a ball cup that just fits right the first time. the rpm and jconcepts cups and even the replacement ae cups for the b4 are better IMHO. better fit anyway.
I'd much rather have to squeeze the ballcup with some pliers to loosen then up than to have to pop off one every time I wanted to adjust roll center, camber gain, or even adjust my diff.
AE is updating the cups to be more free. I am told the only way to make sure you get them though, is to order from AE directly, as shops might have old stock
i've never had that issue in the past, doubt i would in the future.
i'd like cup that fit correctly instead of cups that are all goobered up from pliers. i guess i'm in the minority.
With out a doubt you are the minority. Stock cups work just fine, with just a little "adjusting" on some of them.
Yea they are also a must-have upgrade for the b44.3. I really like not having to pop them off and on the stud every time you need to adjust the slipper or something
Super Moderator
I think the AE balls are bigger than anything else on the market right now so it might be hard to find something that is a direct replacement. I could be wrong though.
I thought they did a manufacturing change on the cups, so they would fit better?
Anyone try the 3 gear yet? I find it odd that AE is going 3 gear on the ft lite. When I used to run Durango, 4 gear seemed to provide best forward traction for mm.
Nobody runs titanium hinge pins that I know of... too soft and will surely bend too easily. It's one of the few places you typically want quality hardened steel. The factory pieces seem pretty bullet proof to me.
