    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-30-2015, 05:00 PM   #12751
Jordan Anderson's Avatar
When using the AE aluminum rear hubs, what's the trick positioning or tool for snapping the outer camber link ball cup onto the ball stud?
It was very difficult with needle nose pliers...
JORDAN // EVAN RC8.2e, B5, B5M, EB48SL, SCT410.3
R/C GEARS , TRUKZ/KARZ , VRC PRO
We're not sponsored, but would recommend:
Team Associated, Tekno, A Main, Action, PM
Futaba, Schelle, Avid, Proline, Lunsford
Jordan Anderson is offline   Reply With Quote
Old 03-30-2015, 05:24 PM   #12752
Jmuck69's Avatar
Use the built tools on you hand...fingers. Just snap it on.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 03-30-2015, 05:25 PM   #12753
Suspended
Trader Rating: 61 (100%+)
Take a 5.5mm driver and put it on the ball cup. Then push.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 03-30-2015, 05:25 PM   #12754
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
sockets idea is better and the way I actually do mine
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-30-2015, 05:41 PM   #12755
vr6cj's Avatar
Trader Rating: 124 (100%+)
I use my "Man" hands. lol
vr6cj is offline   Reply With Quote
Old 03-30-2015, 06:28 PM   #12756
shannow's Avatar
I use a plumbing pliers. Open it to whatever's convenient to grab. Lots of control over it and very neat.
shannow is offline   Reply With Quote
Old 03-30-2015, 06:42 PM   #12757
Just use your hands.
Beaver9332 is offline   Reply With Quote
Old 03-30-2015, 06:43 PM   #12758
Send a message via AIM to Racerbucky
Originally Posted by Cpt.America View Post
That doesn't lower the roll center 2.5mm.
technically, since it's the only way you can actually measure the roll center, he is correct.
Racerbucky is offline   Reply With Quote
Old 03-30-2015, 06:58 PM   #12759
Man hands hey? ...
Thanks for the nut driver idea Socket, I'll give that a shot next time.
Old 03-30-2015, 07:18 PM   #12760
Mizchief's Avatar
+1 I use channel locks or sometimes a big C clamp. Anything that can give you pressure on it straight down vs. at an angle like needle-nose
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 03-30-2015, 08:15 PM   #12761
Thanks guys, good tips.
Old 03-30-2015, 08:15 PM   #12762
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Moving your ballstud up and down doesn't measure the rollcenter any more than putting more paint on your body measures your center of gravity. Sure it can be lowered or raised, but measuring the point along the center-line of the chassis is something else entirely.
Nevermind.. don't have the energy.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 03-30-2015, 08:44 PM   #12763
I put the ball stud in the ball cup before I thread it on to the buggy. place the ball stud horizontal(or sideways so have you) to the ball cup then use pliers to press it in. Should easily pop in that way.
robbie_gtc is offline   Reply With Quote
Old 03-30-2015, 08:57 PM   #12764
How in the world are you making changes where you can measure how high or low you are setting your roll center? How do you lower your roll center exactly 2.5mm?
I would imagine he means he added 2.5mm of washers under the inner camber link in the rear which would effectively lower the roll centre. But that would not be a 2.5mm difference in roll centre. That is a completley differemt measurement.
It seems to be just a miscommunicated point he made.
Old 03-30-2015, 10:48 PM   #12765
Originally Posted by jjahn View Post
I think most people understood what he meant. Just another pissing match over technicalities.
I didn't understand what he meant and I think I have a pretty good understanding of what roll center is and how to change it. It certainly isn't all done by raising or lowering camber link mounts.
Increasing ride height also lowers roll center. Changing pills in your pin braces so the arms attach to the chassis higher or lower will change your roll center as well.
-Chris
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
