    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-11-2015, 06:28 PM   #12301
Originally Posted by Toiffel View Post
My guys at the HS said they should have the lite by the 15, fingers crossed
Not to be a downer, but that was probably the original date. Referring to the post about the phone call to Associated and assuming that the person on the phone is actually in the know, then I would say if Team Associated doesn't know, then the your lhs doesn't know. I hope I'm wrong!
MBX7R Eco--Tekin Gen 2 1900kv, RC10B5m Factory Lite on order, Hitec Lynx 4s
All sold: RC8.2E--Tekin RX8 1900kv, DEX408--Tekin RX8 1900kv, SC104x4--RX8 Pro4 4000kv, E-Revo Brushless, Hpi Sprint 2 Drift, Airtronics mt-4,
jjahn is offline   Reply With Quote
Old 03-11-2015, 06:50 PM   #12302
Regional Moderator
RobsRacin's Avatar
Originally Posted by Deluxe312 View Post
Ensure you have proper/broken in rear tires. Other than that, here are things to try:
open cell foams in rear tire
3+1 toe/antisquat
shim rear hubs all the way forward
move battery all the way rear
27.5 weight oil/1.6 piston/green spring/26.5mm exposed shaft rear shock
longer front shock shaft exposed (or verify to 20.5mm)
lay rear shock down to inside hole on tower
0.5 degree rear hub inserts
cut the outside braces on waterfall mount
loosen screws that mount brace to transmission case
2mm on plastic rear camber mount
brass c mount
I will try a few of these out, thank you!
RobsRacin is offline   Reply With Quote
Old 03-11-2015, 09:12 PM   #12303
I know it's been covered but I can't find it now. Someone posted a list of motor plates and weights. From stock to carbon. Where would I find that? Would be a good one to add on the first page.
Nick
Cautrell05 is offline   Reply With Quote
Old 03-11-2015, 09:31 PM   #12304
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Nick
I would be happy to add that list to the first page.
RCBuddha is offline   Reply With Quote
Old 03-11-2015, 09:49 PM   #12305
likea45's Avatar
Originally Posted by jjahn View Post
Good to know, thank you. I just have the go ahead to spend the funds and I want to buy it before she changes her mind! Plus I hate waiting. Knowing that I can get some decent hop ups plus the light chassis all in one package means I can't settle on the regular one.
I was really considering the Durango DEX210v2, I liked the DEX408 way better than my RC8.2e, but I always get sucked into associated vehicles.
I own a PRS1 and I think it's every bit as nice as a B5. Owning and running both I will say if you are starting out go with the associated since you can pop in to any LHS for parts. Other than that it's a choice. Both great cars.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 03-11-2015, 10:29 PM   #12306
ray_munday's Avatar
Originally Posted by RobsRacin View Post
Anybody got any ideas for increasing rear traction? Im box stock other than rear motor arms front and rear. 24mm on the ride height.
Not sure what sort of track you are racing on, but I have put together a setup guide for the B5M on our typical tracks downunder which may be of interest to readers of this thread (see the pdf at the bottom of the link
Ask Ray Munday - JConcepts, Reedy, Associated Aussie Support Thread
Our tracks generally arent super high grip but we have got the B5M working better than the rear motor in pretty much every condition including very low traction. Its an amazingly versatile car!
Ray
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 03-11-2015, 10:31 PM   #12307
Cool. Now we just need to find that post. I'm pretty sure it was in this thread but I don't remember where.
Old 03-11-2015, 10:44 PM   #12308
Default Building Ultimate B5M
Building the ultimate B5M for both stock and maybe mod
I am wanting to get back into RC racing.
Old time Ultima and Laser owner from long time ago....
Looking at mid mount Rb6 or B5M
I am asking for your experience and knowledge to built the ultimate B5M so when when i race i can not blame the car when i come last each rce...
ASC90003 - Team Associated B5M Team Mid Motor 2WD Competition Electric Buggy Kit
LRP80970 - LRP "Flow" WorksTeam Brushless ESC
LNS2006 - Lunsford "Punisher" Associated B5/B5M Titanium Turnbuckle Kit (6)
ASC232 - Reedy Sonic Mach 2 Spec Brushless Motor (17.5T)
ASC91373 - Team Associated Front Shock Tower
ASC91398 - Team Associated "Flat" Front Arm Set
ASC29167 - Team Associated DS1015 High Torque/Speed Digital Servo w/Heatsink
SHL1300 - Schelle Racing Nova "Buggy" Slipper Assembly
ASC91520 - Team Associated RC10B5M Aluminum Rear Ballstud Mount (Blue)
MIP14195 - MIP Aluminum Hard Coated Associated B5/B5M Top Shaft
MIP14230 - MIP "Pucks" Bi-Metal Associated B5/B5M R-CVD Drive System
ASC91600 - Team Associated RC10B5M Titanium Screw Kit (83)
JCO2346T - JConcepts B5/B5M Titanium Knurl Tip Front Axle Set
google Schelle-Ceramic-B5-Ceramic-Bearing-Set-SCH2300 (can not post links)
I based alot of this info from this link
google B5M_StephenBess_Project17.5Racer (can not post links)
I am a little confused about what i need to convert to a 3 gear box and if i need some extra parts. I would love to have a smooth running gear box/diff to keep it light and spinning as smooth as possible.
I didnt want to post a new thread in case i got spanked, 800 pages is alot of pages.
I tried to search for ulitmate, light weight 17.5 but couldnt find good info like above link.
If i can make this happen you will see the car made and run on local clay track (high grip)
Dmitri Tech is offline   Reply With Quote
Old 03-12-2015, 05:29 AM   #12309
Toiffel's Avatar
Trader Rating: 52 (100%+)
I hope not !!! I spoke with them yesterday, and they know better than mess with my builds......lol
Esteban "BBQ" Baquero
Barry "Barely" Goodwin's worst nightmare.....
Toiffel is offline   Reply With Quote
Old 03-12-2015, 07:18 AM   #12310
RCBuddha's Avatar
Was it on facebook? I started a small list already. So if anyone out there has a chance, please weigh your motor plates (in grams) and either post it here or PM me. Thanks.
Old 03-12-2015, 10:07 AM   #12311
HYPERformance06's Avatar
Ray
awesome thanks. i loved running your b4.2 setup
Patrick Hertel
B5M - Trinity d4 17.5 1s ss
As I lay rubber down the street.
I pray for traction I can keep, but if I spin
And begin to slide, please dear god protect my ride.
HYPERformance06 is offline   Reply With Quote
Old 03-12-2015, 10:19 AM   #12312
Ray
would you be able to make a setup sheet like u did for the b5m but for indoor tracks?
Patrick Hertel
Old 03-12-2015, 10:22 AM   #12313
JeepnMike's Avatar
Tower changed their stock status to "early April" now. This sucks for people with patience issues.
TRF801x - DB01RR - B5m Lite - TB03 - Variety Of Vintage Tamiya
JeepnMike is offline   Reply With Quote
Old 03-12-2015, 11:10 AM   #12314
Tower must have read my post.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 03-12-2015, 12:32 PM   #12315
This sucks! I may just go for a 1/8th e-buggy instead.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
