    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-04-2015, 08:15 PM   #12166
raceguy13's Avatar
has anyone installed the +4 c mount and 5mm hexxes? I just installed mine and the hex isn't even close to clamping the axle. I tightened the screw all the way in the hex and it just slides on and off the axle, it is super sloppy on the axle.
raceguy13 is offline   Reply With Quote
Old 03-04-2015, 08:38 PM   #12167
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
The new 5mm hex is designed for the new HD axle that is about .3mm thicker than the standard B5/B5M axle
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 03-04-2015, 08:41 PM   #12168
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by air8 View Post
I will give it a try tonight sir.
Any idea if your batteries are around the 1" height?
are you using those low mah packs?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-04-2015, 09:09 PM   #12169
B44
B44's Avatar
Any set ups for carpet off road...thanks
B44 is offline   Reply With Quote
Old 03-04-2015, 09:48 PM   #12170
air8's Avatar
I am. LoL.The Venom shorties. They've been good, this is like 4th season I think. Mid 2012 is the date I wrote on them. We only race the 10th scale cars indoor from October to April. I use an 8.5 in mod nowadays. Smaller track around 90x60 I think. With this car i just converted the only extra mod motor I have is a Velocity 7.5.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-04-2015, 09:54 PM   #12171
Trader Rating: 29 (100%+)
My new venom shorties are absolutely killer. Best battery I have used to date. Its pretty sad when my venom packs have lower IR and more punch than my high end reedy and orion packs.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 03-04-2015, 10:21 PM   #12172
air8's Avatar
Hard to get the angle with my phone. But there is less than a 2mm gap. But the battery is crazy loose in there. It slides forward easy. I guess with my layout I could just stuff foam in there.
--"U Ain't Fast!!"
Chris Pearce
Old 03-04-2015, 10:26 PM   #12173
air8's Avatar
I'm attempting the full inline layout. The Tekin RS is just a little too big of footprint to fit though.
--"U Ain't Fast!!"
Chris Pearce
Old 03-05-2015, 05:35 AM   #12174
That's me pre-ordered a B5M Lite!
Can anyone tell me which length of flat sensor cable I'll need to run it under the battery?
The Dark Knight is offline   Reply With Quote
Old 03-05-2015, 06:04 AM   #12175
jmcelroy42's Avatar
Try turning the battery thumb screws upside down, that's what I had to do on the RM with my SMC 3500 & 3800 packs.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 03-05-2015, 07:43 AM   #12176
Fastforward's Avatar
I cut a piece of foam to go under the battery.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 03-05-2015, 08:16 AM   #12177
jmcelroy42's Avatar
You should put the foam between the battery and the brace to keep your COG as low as possible.
Old 03-05-2015, 08:20 AM   #12178
VegasHB's Avatar
https://www.facebook.com/planbrc/posts/1500128036928298
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 03-05-2015, 09:42 AM   #12179
Titanium rear axles from amain
http://www.amain.com/protek-rc-titan...axle-2/p439339
Old 03-05-2015, 09:47 AM   #12180
Jordan Anderson's Avatar
http://www.teamassociated.com/pdf/ca...S4_Levanen.pdf
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
