    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-02-2015, 08:44 AM   #12106
Suspended
Trader Rating: 61 (100%+)
You lost me at B4 front end.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 03-02-2015, 09:06 AM   #12107
Jmuck69's Avatar
Originally Posted by The Dark Knight View Post
Do any of you guys race on grass or astro? Or is it mainly dirt & clay?
Over here in the UK, I mainly race on grass & astro.
I'm thinking of getting the B5M Lite to race in mod mainly due to the optional extras the kit comes with. My plan would be to try the 3 gear box first and see how I get on with it then depending on the outcome, either stick with the 3 gear box or try a 4 gear box.
Mainly dirt and clay but a few tracks are carpet. Grass and astro are non-existent.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 03-02-2015, 09:11 AM   #12108
air8's Avatar
LOL. Same thought went through my head.
Originally Posted by jerzi View Post
My b5m kuch carbon chassis. Not it has an b4 frontend but will be fitted with an b5m. It is 4mm thick and it is superb stiff. Dont need to make any extra carbon parts to make it stiffier.
Weight is 138gr.
NOT FOR SELL
Jerzi
Jerzi did you lay the carbon fiber yourself, or did you purchase the material?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-02-2015, 09:21 AM   #12109
air8's Avatar
Did anyone have to shave the brass or aluminum C mounts to get the locknut to sit flush? And/or possibly get a nut driver on there?
--"U Ain't Fast!!"
Chris Pearce
Old 03-02-2015, 09:25 AM   #12110
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You dont need a locknut on the aluminum piece...I just put a little bit of threadlock on the screw.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-02-2015, 09:30 AM   #12111
Suspended
I did it my self.
Did an chassis mold out of nice wood.
Jerzi
jerzi is offline   Reply With Quote
Old 03-02-2015, 09:30 AM   #12112
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I dont have nuts on mine. Just locktite.
So, last night I was working on my cars for cactus. I was going to build come front hubs with +3 and +4 inserts, then glue the inserts in. As usual, the +3 inserts worked well and were smooth and felt centered. The axle just fell all the way through both bearings and the axles are smooth. The +4 insert however, needed to have presure applied to get the axle through the bearings. And once they were "popped" in, there was heavy grinding and resistance. I tried to "work" the insert in and center them so I could glue them into the sweet spot. However, this was never to be the case. So, what prep work are you guys doing to center the +4 inserts? Sanding the outer edges of the inserts? I have never ever been able to get the +4 inserts smooth. The +3 are always pretty good.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-02-2015, 10:41 AM   #12113
kdub's Avatar
Originally Posted by Razathorn View Post
I believe the wing mount is 6, then the shim forward makes 9, and the shim backwards makes 3. Run the shim on top in any orientation for 6.
The wing mounts are 3 deg, so shim on top is 3 deg. Shim on bottom wedge up is 6 deg, shim flipped is 0 deg. I haven't tested this much, just my standard setup to run the shim on top of the wing.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 03-02-2015, 10:52 AM   #12114
MikeXray's Avatar
Trader Rating: 73 (100%+)
Interesting, do the +4s have the same issue when installed as +2? I have run 3 for a long time, I have a set of glued 4's. but they haven't made it into the car yet..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-02-2015, 10:57 AM   #12115
yeah. I was looking at them last night. If i had to guess, I would say the location of the molding injection point is the issue. I tried several different hubs (hard and regular), I mixed hard inserts with plastic hubs and vice versa. Crush tubes and no crush tubes, lol. I can only think I need to sand them until they can align, then glue. But before I destroy all my parts trying to work out a technique, I was looking to see how others do it.
Old 03-02-2015, 11:49 AM   #12116
Trader Rating: 29 (100%+)
I dont seem to have this front wheel bearing issue. Mine stay free and not crunchy for awhile like at least 3 months.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 03-02-2015, 01:38 PM   #12117
VegasHB's Avatar
You will once you switch your inserts around. My feeling is that the bearings "wear in" to that set of inserts/hub. You take those same bearings and swap inserts and they're instantly toast since they wore into the previous setup.
Someone like Exotek, Avid or Schelle need to make a new front hub and insert assembly that doesn't eat bearings. However that might cut into their bearing sales.....conspiracy!!
I've had better luck using the hard hub kits though.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 03-02-2015, 01:49 PM   #12118
Peter Martin's Avatar
These will help.
http://tkocompetitiondev.com/product...roducts_id=596
Peter Martin is offline   Reply With Quote
Old 03-02-2015, 01:52 PM   #12119
Originally Posted by Peter Martin View Post
We will see. I have some of those coming
Old 03-02-2015, 01:55 PM   #12120
Suspended
dominick i.'s Avatar
Trader Rating: 123 (97%+)
Peter Martin knows his stuff...even back in the 80's at Family Hobbies he was quick.....
club racing is always great racing......
I am probably the only non sponsored racer in the usa.....:)
dominick i. is offline   Reply With Quote
