Team Associated RC10 B5m Mid-Motor Thread >
Like Tree54Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 03-01-2015, 10:21 AM
  #12076
does anyone have a link on how to do the b5m to b5 rear conversion kit build steps go? im thinking of doing it for the summer/ outdoor track. i bought the b5m converted from the b5 rear with the team associated conversion kit. so i have all the parts for the b5m and the b5 rear conversion. i mean should i even try it? or should i stick with mid motor only?
Moyanator609 is offline
Old 03-01-2015, 10:30 AM
  #12077
air8's Avatar
Originally Posted by aeRayls
The mount itself is 3. Shim with hole in front is 0 and shim with hole in back is 6
Originally Posted by Jpdanger
I thought no shim was 0, shim bump down was 3, and shim bump up was 6???
Ok cool. I just wanted to make sure. So what spacer or what do others use to take up the slop as if the shim wasn't there?
air8 is offline
Old 03-01-2015, 10:35 AM
  #12078
air8's Avatar
I started converting a rear to a mid last night, opposite of you, but I am using the online B5M manual and going through the steps as if I were building a mid motor.
air8 is offline
Old 03-01-2015, 10:40 AM
  #12079
aeRayls's Avatar
You put the shim on top of the wing for 3
aeRayls is offline
Old 03-01-2015, 10:50 AM
  #12080
air8's Avatar
...insert cricket chirping... OH! Right. Well that's embarrassing.
air8 is offline
Old 03-01-2015, 10:52 AM
  #12081
air8's Avatar
For some reason I was thinking the wing needed to stay at the same height. LOL. I'll just keep quiet in my corner now.
air8 is offline
Old 03-01-2015, 02:04 PM
  #12082
gogi108's Avatar
Anyone running boosted 17.5 and can recommend a starting point for gearing ? Running hobbywing 3.1 esc and want to stick with the 72t spur .
gogi108 is offline
Old 03-01-2015, 02:07 PM
  #12083
R/C Tech Elite Member
In theory yes
Thanks. My setup is all about theory right now. The buggy is already capable of quite a bit more than I'm able to get out of it while still driving clean. I'm working on catching up with it though.
iScream is offline
Old 03-01-2015, 02:23 PM
  #12084
aeRayls's Avatar
What track are you running at?
aeRayls is offline
Old 03-01-2015, 02:59 PM
  #12085
It's a brand new indoor carpet track in Spring Hill, Tennessee. Not sure if it even has a name yet and we have to set it up before each race then tear it down afterwards.
We had almost 20 2WD buggies last Sunday though. The top 5 fast guys averaged 21.3 for their top 10 laps while I was at 25.5 average for my top 10.
But I wasn't testing the limits of my current setup much at all. I believe my B5M will hang with any buggy that was out there and can beat most of them. I just have to work on doing my part.
iScream is offline
Old 03-01-2015, 06:43 PM
  #12086
spammy's Avatar
Running on carpet and I have a on power push I need more steering what can I do
I have the kit setup but I did change to the b5 front arms and running 40 weight front oil with grey spring
In the rear 37.5 oil with blue spring and 3 deg toe
Now what to do thanks for the info
I forgot running 1.6 pistons all around
spammy is offline
Old 03-01-2015, 07:25 PM
  #12087
sanderson373's Avatar
Have you tried running the wedges z3 tires i have on my b5m and vintage and i turn on a dime or you could tried running the stealths tires
sanderson373 is offline
Old 03-01-2015, 07:44 PM
  #12088
spammy's Avatar
I been running Schumacher stagers and it is workin good but I just need alittle more on power steering. Thanks for the tip
spammy is offline
Old 03-01-2015, 07:48 PM
  #12089
Absolutely love my buggy
Acline6194 is offline
Old 03-01-2015, 08:09 PM
  #12090
raceguy13's Avatar
Get a kf2 lol
raceguy13 is offline
