    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 02-25-2015, 10:52 AM   #11941
Originally Posted by MikeXray View Post
34/69 @ 50* timing so far, I tried 60 with less gear and it didn't really get hot, where its set now its come off around 140, so its likely it can handle 60, but I wasn't risking it at motorama
Thanks guys, I guess I'm way under geared LOL. I was messing around with 30/69 and 31/69 and 50* timing.
Any of you running a fan on there?
Leon
napoleon1981 is offline   Reply With Quote
Old 02-25-2015, 10:56 AM   #11942
MikeXray's Avatar
Trader Rating: 73 (100%+)
Leon
Not currently, but is on the list of things to do.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-25-2015, 11:04 AM   #11943
vito's Avatar
happy off dr orders now bin 2 weeks back to paying
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 02-25-2015, 11:07 AM   #11944
Suspended
Trader Rating: 61 (100%+)
What is your ambient temp?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 02-25-2015, 11:48 AM   #11945
Jordan Anderson's Avatar
Does anyone know if the copper washers in these fit the V2 aluminum shock caps?
Doesn't look like the V2 aluminum shock caps come with an o-ring for the bleeder screw like the previous caps used to?
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 02-25-2015, 11:52 AM   #11946
AE-Reedy
Originally Posted by Jordan Anderson View Post
Does anyone know if these fit the V2 aluminum shock caps?
The V2 caps, #91450, now use a nylon washer. The losi washers should not be needed. I have used the caps with no oring or washer and had zero leakage.
Sean Cochran is offline   Reply With Quote
Old 02-25-2015, 12:06 PM   #11947
MikeXray's Avatar
Motorama was probably 55-60?
Old 02-25-2015, 12:40 PM   #11948
Nat Maniac's Avatar
Has anyone else (excluding Wildcat as I know he doesn't like this kind of stuff) purchased the FT aluminium blue shock bushings?
I installed them last night but there is approximately 2mm of slop between the nut and the shock cap so effectively useless.
Has anyone else found this?
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 02-25-2015, 01:04 PM   #11949
jmcelroy42's Avatar
From what I understand is as long as there isn't up/down slop you are ok, I have the Schelle ones and the shocks move in/out on the bushing but up/down is good.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 02-25-2015, 01:49 PM   #11950
Trader Rating: 29 (100%+)
Either your shocks caps are extremely worn out or you possibly got incorrect parts. I just put those on my car because i got tired of replacing the schelle bushings everyother race day. Not exagerating either. Schelle ones are awesome design but bushing is no good. The FT ones snugged mine right up and i believe the part numbers are b5 specific.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 02-25-2015, 01:51 PM   #11951
And that blue shock spacer has a black plastic bushing that slides over it... that could be what you are missing.
Old 02-25-2015, 02:35 PM   #11952
If you are talking about movement fore and aft, I would say absolutely no issue.
will5879 is offline   Reply With Quote
Old 02-25-2015, 02:53 PM   #11953
Trader Rating: 483 (100%+)
I did the same thing when I first got my B5Ms. When you buy the FT shock bushings you also need to buy part # asc91447 which shows up as B5 shock bushing ball. I wish somebody has told me that too....I raced a while before I figured it out and honestly my lap times did not go up after I added the shock bushing balls.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 02-25-2015, 03:40 PM   #11954
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
lol, what me? Actually, I dont care for those sort of upgrades normally. I bought a used roller for my daughter and it had the FT standoff on it. And no it did not have 2mm of up and down play. Make sure you bought the inserts with the FT standoffs.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-25-2015, 03:43 PM   #11955
Nat Maniac's Avatar
I have it installed as it came with it but still have the slop,i cant help but think i must be doing something wrong.
http://youtu.be/KPhC9hlnekE
