    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 02-13-2015, 06:14 AM   #11581
Mason's Avatar
Originally Posted by Mantis Toboggan View Post
Or, instead of forcing the threads to form with a screw, you could cut threads with a tap and have no problem using aluminum screws. Now, aluminum is not nearly as strong as steel or titanium, so the use of aluminum screws should be limited to low stress areas. Nice thing is aluminum is even lighter than titanium.
or for the cheap skates, pre-thread with your steel screws first.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 02-13-2015, 06:40 AM   #11582
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by vito View Post
Tom just heard from his doctor and polyp was pre cancer, but he got it all.
That is good news! Just take the doc's suggestion on recovery time serious no matter how anxious Tom gets.
When re-inserting aluminum screws into plastic I always turn the screw the wrong direction until I feel the screw drop. This tells me that I now have the threads aligned and I will not be cutting new threads when I screw it in. You have to try it once or twice to feel what I mean by dropping into the threads. It is hard to explain that feeling.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-13-2015, 06:49 AM   #11583
jmcelroy42's Avatar
Great tip! I wouldn't have thought of that.
Which places are you guys using the alum screws, and what ones would you keep steel or Ti?
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 02-13-2015, 07:06 AM   #11584
Super Moderator
Kraig's Avatar
When I had my B5M I believe I only used the aluminum screws where they recommended them.
Old 02-13-2015, 07:07 AM   #11585
Suspended
Trader Rating: 61 (100%+)
I've owned a car with alloy screws before. Never again, Ti is just so much stronger though slightly heavier.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 02-13-2015, 08:17 AM   #11586
HYPERformance06's Avatar
Does anyone no the screw size for the exotek slipper eliminator. Wanna go with a lighter screw set for the spur.
HYPERformance06 is offline   Reply With Quote
Old 02-13-2015, 08:32 AM   #11587
timannnn6's Avatar
Trader Rating: 124 (100%+)
Originally Posted by Logi Maker View Post
I think your screenshot is from the B5 manual. My B5M manual says to put on opposite side of spur gear.
Official Team Associated RC10 B5m Mid-Motor Thread-screen-shot-2015-02-13-8.27.49-am.png
timannnn6 is offline   Reply With Quote
Old 02-13-2015, 08:38 AM   #11588
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Count the gears. Shot from the B5m lite manual. To each his own. I always run it towards the spur to remember which side the head is on.... all adjustments (slipper, gear mesh, diff) on the same side.
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 02-13-2015, 08:40 AM   #11589
easy way to remember kit location for thrust bolt. its always on the passenger side of the car or right side. doesnt matter if its 3 or 4 gear
Patrick Hertel
B5M - Trinity d4 17.5 1s ss
As I lay rubber down the street.
I pray for traction I can keep, but if I spin
And begin to slide, please dear god protect my ride.
Old 02-13-2015, 08:44 AM   #11590
Logi Maker's Avatar
4-40... not sure of the length.
Kyle Predmore
Old 02-13-2015, 08:44 AM   #11591
timannnn6's Avatar
Yes..and the Lite has the 3 gear which would put thrust bolt head on passenger side of car.
Old 02-13-2015, 08:44 AM   #11592
timannnn6's Avatar
You got it.
Old 02-13-2015, 08:51 AM   #11593
fpart's Avatar
Trader Rating: 39 (100%+)
Send a message via Skype™ to fpart
Is there any reason I should get the b5M lite if I will just run mod?
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 02-13-2015, 08:54 AM   #11594
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I think we are going to see this over and over. Nothing about the lite car makes it stock only. If you need weight you can add it.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-13-2015, 09:08 AM   #11595
air8's Avatar
Trailing axle inserts--Can the insert be moved back and forth without wrecking the setup? Like how critical is it to move the front wheelbase at the same time?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
