    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 02-11-2015, 08:26 PM   #11536
AZJP's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Jpdanger View Post
Why are they running the rear camber mount upside down and shimming up 3mm? Why not flip over and only shim up 1mm?
Because that would be 3mm not 1mm. To achieve 1mm or 0 or negative, you run it -2 and add washers as needed.
AZJP is offline   Reply With Quote
Old 02-11-2015, 08:33 PM   #11537
Originally Posted by sanderson373 View Post
I blew a ball diff already on the second night and its high grip plus I'm using pin points on the rears and wedges z3 on the from and its crazy grip it points and goes very easy to traction roll so I'm goin to try both out so do u have any idea what diff fluid I would use bc I was kinda thinking about 1000-2000 plus I will b switching to outdoor here soon
I had my gear diff installed and filled with 2K for the race Sunday. It felt good to me but I wasn't pushing hard enough to unload the inside wheel so I don't know if it would have started to diff out or not.
I only finished 3rd in the b main but that was mostly due to me being overly careful. The buggy was definitely capable of finishing higher than the position I drove it to.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 02-11-2015, 08:54 PM   #11538
TOO-TALL's Avatar
Dumb question. ......I've always ran my diff with the screw head opposite side of the moter plate(like the manual says) now I was told that is wrong.So what side should it be on ???
What side should the screw head be on for the 3gear?
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
Old 02-11-2015, 08:56 PM   #11539
Suspended
Trader Rating: 61 (100%+)
It doesn't matter.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 02-11-2015, 09:05 PM   #11540
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Socket View Post
It doesn't matter.
I cant wait to login in the morning and see 5 people tell you that your wrong when you are absolutely correct.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 02-11-2015, 09:07 PM   #11541
If the thrust bearing is working properly, it will make no difference.
Cautrell05 is offline   Reply With Quote
Old 02-11-2015, 10:19 PM   #11542
spammy's Avatar
Originally Posted by Wildcat1971 View Post
loose diff probably or crappy gear mesh
I was running a gear diff and do you think it will hurt anything in the tranny.do you think it could ba a bearing or or could it be a spur
spammy is offline   Reply With Quote
Old 02-12-2015, 06:00 AM   #11543
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Does it matter...
I run mine to the back, found it never comes loose...
JK... It really doesn't matter.
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 02-12-2015, 06:20 AM   #11544
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
so you are running a gear diff and slipper eliminator, and are getting a high pitched squeal from the rear of the car?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-12-2015, 07:00 AM   #11545
Mason's Avatar
It doesn't matter.
You're both wrong. There is no spoon.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 02-12-2015, 07:04 AM   #11546
Suspended
I would assume somewhere in the drive line a gear is toasted. Whether it's the gear diff, transmission or the spur gear, something is finished.
Old 02-12-2015, 07:24 AM   #11547
spammy's Avatar
Yes
Old 02-12-2015, 07:30 AM   #11548
+1 Take apart your tranny and trouble shoot it. a high pitched squeal from a gear diff sounds very odd.
Old 02-12-2015, 07:47 AM   #11549
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Official Team Associated RC10 B5m Mid-Motor Thread-screenshot_2015-02-12-07-45-21.png
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 02-12-2015, 07:51 AM   #11550
Super Moderator
Originally Posted by Logi Maker View Post
It doesnt matter. It is user preference, whichever way allows you to make needed adjustments easier.
