    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 02-04-2015, 02:49 AM   #11326
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Mantis Toboggan View Post
What does this have to do with a B5M?
Zero, zilch, nadda......nothing
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 02-04-2015, 05:41 AM   #11327
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Cridd View Post
Whats a good battery resistance and what is not good and should get rid of the battery?
The good, bad and ugly.
I know it's off topic, I'll answer.
It matters what type of racing you're doing, lower Ir = more power. So in 17.5 racing, you want the lowest possible. In mod, high IR's can cause unnecessary heat in the battery because of the increased amp draw from the motor.
IR is very much a perspective thing. Anything over I'd say 6 for a combined pack is not good.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 02-04-2015, 07:11 AM   #11328
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by BS-Racing View Post
Looking for a piston/oil set up for high pack but yet still soft (if that makes sense) Im running 1.5 in the rear with 32.5 oil. the jumps don't have the most forgiving landings. I need something with enough pack to keep the chassis from bouncing off the ground and unloading the rear end however I've found a softer set up works great at my local track.
Thanks in advance
I'm liking the RCSHOX 2 stage pistons. 25/22.5 oil
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-04-2015, 07:16 AM   #11329
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Thanks in advance
how much does your car weight?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-04-2015, 07:33 AM   #11330
MikeXray's Avatar
Speaking of weight, I was surprised my car was so light, I have the full pucks, cut gears, with the 4 gear, 25g C block, shorty, full size servo, LRP flow, r1 wurks 17.5, I was at 1508.
Old 02-04-2015, 07:37 AM   #11331
weird. tires matter a lot. my M4 tires add 25g over my clay tires.
When I weighted 1680g no shock package was great. at around 1550, the car lands pretty good with 1.6s. Imo, the car is WAY to heavy out of the box. The new car is perfect for racing. The weight was the only real gripe I ever had with the car.
Old 02-04-2015, 07:41 AM   #11332
MikeXray's Avatar
I'm looking forward to trying the lighter chassis with the brick pack, I believe it should be able to get into the low 1500g range.
Old 02-04-2015, 07:44 AM   #11333
yeah, that chassis will be sold out for a while
Old 02-04-2015, 09:37 AM   #11334
BS-Racing's Avatar
Originally Posted by JFuel11 View Post
We have been running 1.4 x 3 schelle pistons in the rear with 30 to 32.5 weight oil with great results.
Originally Posted by Skeeter36 View Post
I like the 3x1.4 with 32.5 and white or gray spring but have never tried them in the rear.
Thank you guys for the suggestion, I will be trying the 3X1.4 ASAP
Shes a big girl, 1606g race ready running Stock. However I just tore it apart last night to put some lightweight pieces on it, Not a lot, so I'd guess the new weight will be 1575g Race ready
B5M
BS-Racing is offline   Reply With Quote
Old 02-04-2015, 09:41 AM   #11335
the 1.4x3 has LESS pack when landing. I run 1.6 f/r and 32.5/30 weight oils. I am at about 1550. I use grey/grey springs, when I run slicks and white/white when I run mini pin tires.
Old 02-04-2015, 09:44 AM   #11336
Super Moderator
racer1812's Avatar
I was going to suggest a 1.4 3 hole with a 27.5-32.5 oil but I'm not a set up guru so I stayed out of it.
Big girls..I like em'............just not too big
Old 02-04-2015, 10:13 AM   #11337
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Great Setup...
Wildcat,
We had been running 1.6 front and rear locally for a while too with 32.5 in front and 27.5 in rear. We have found the 1.4 x 3 s give us more traction overall when used at all 4 corners. We are running 35 front and 30 rear for oil with great success. I feel the 1.4 x 3 with 30 gives good low speed dampening and packs up nice over the 1.6 with 27.5 for our given track.
Thanks for the info and help!
Alan
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 02-04-2015, 10:17 AM   #11338
dbowen's Avatar
Wildcat,
Alan
Ya I completely agree with you and I love the 3x1.4s it deff is an advantage in the rear when the track is loose and bumpy. But I recently went back to the 2x1.6 in the rear bc my track had a lot more bite then usual for our recent big race.
I always run 3x1.4s in the front I think it gives the car a little bit more steering than the 1.6s
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 02-04-2015, 10:24 AM   #11339
Jmuck69's Avatar
Originally Posted by Jack Smash View Post
I heard that the team guys were testing a new 5 gear
Whatever...AE guys in my area are testing the 1/12 scale pods in the back with direct drive. talk about ultimate weight savings! Pinion and spur gear only, no diff. Dialed...
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 02-04-2015, 10:27 AM   #11340
HYPERformance06's Avatar
Links, pics, more info kinda cool to check out
HYPERformance06 is offline   Reply With Quote
