    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 01-29-2015, 02:21 PM   #11011
onefast8's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Wildcat1971 View Post
I never bent and axle. Is that a real issue? Or just a precaution for the T5M coming and standard parts.
Same here - never bent an axle, kit front bearings (and all the rest) are fine and my ball cups were great out of the box...sometimes this thread makes me wonder..haha
Jake R.
onefast8 is offline   Reply With Quote
Old 01-29-2015, 02:27 PM   #11012
HYPERformance06's Avatar
You got a good kit then lol. I've never bent an axle, bearings are notchy after a month. Ball cups where really tight but I loosened them up.
HYPERformance06 is offline   Reply With Quote
Old 01-29-2015, 02:37 PM   #11013
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
looks like AE went to the 2 pad system for weight savings.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-29-2015, 02:52 PM   #11014
gooba's Avatar
Anybody seen this yet
http://www.redrc.net/2015/01/team-as...it/#more-92147
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 01-29-2015, 02:55 PM   #11015
yep all over Facebook all day today
scythe23 is offline   Reply With Quote
Old 01-29-2015, 02:59 PM   #11016
thebombster's Avatar
Looks like the same bearing eating setup up front
And it's not that the bearing are bad, you can throw the worlds greatest bearing in the front and they get notchy, even if you have the clamping hex axel and glue the inserts, it's a poor design
Tyler Baum│Railyard Hobbies│Trains and Lanes│B5M│Slackstar│Reedy│Jconcepts
thebombster is offline   Reply With Quote
Old 01-29-2015, 03:05 PM   #11017
Rick Hohwart's Avatar
reedy are not great packs for stock. Chances are, you are just used to worse packs. Drop them on an IR checker and you will see. Keep in mine, Reedy is not into the "stock game". Locals have tested a lot of batteries. The orions were deemed to be turns. Started off great and quickly faded away. So far, the 6+ month old Trinity 100c packs are holding a low IR. But you will pay for that. The turnigy ultimate's are ok for the budget racer and so it the vant stuff from dirt cheap RC.
Reedy batteries are actually low IR high power if you are buying the right ones and charging them the same as other packs being compared. We are big into the stock game but let our customers do the winning instead of sponsoring a factory team.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 01-29-2015, 03:05 PM   #11018
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I probably have 150 packs on my stock front bearings... smooth as butter. The only thing I have changed is the Exotek titanium front axles.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-29-2015, 03:08 PM   #11019
Really? My inserts are glued, I'm running stock axels right now. I have avid bearings in the front and they get griddy after 2 race weekends..
Guess I'll try those axels out
Old 01-29-2015, 03:14 PM   #11020
AZJP's Avatar
Trader Rating: 20 (100%+)
This is due to axle alignment. When you glue inserts, you need to put the bearings in first with the axle, then glue the seam or the bearings will be misaligned and feel gritty.
AZJP is offline   Reply With Quote
Old 01-29-2015, 03:26 PM   #11021
Originally Posted by Cridd View Post
I use v2 slipper with b5 spring and nut, good to go.
Cool, thanks for the info. That's the first thing I'm going to do.
Losi Mini 8t
Associated B5m
Tekno Short Course
Losi 8ight 3.0
Ping i20 Driver & Callaway X-Tours irons
dtgolfing is offline   Reply With Quote
Old 01-29-2015, 03:37 PM   #11022
kdub's Avatar
Originally Posted by HYPERformance06 View Post
thats my guess. u can run stock pins but to do the rear pull feature needs their longer pins. if the stock pins didnt work i dont see why they would have the d mount for sale
That's correct, kit hingepins fit perfect. To pull the pins out the rear, you will need our updated parts coming in about 1 month.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 01-29-2015, 03:46 PM   #11023
3srcracing's Avatar
Trader Rating: 25 (100%+)
Heck yes!! Thats why I waited to buy a B5m!
3srcracing is offline   Reply With Quote
Old 01-29-2015, 04:14 PM   #11024
onefast8's Avatar
Hmm.. I have the Exotek TI front axels also...#Bearinglife
Jake R.
Old 01-29-2015, 04:16 PM   #11025
VegasHB's Avatar
Exotek, Avid or Schelle need to make a better front hub and insert system to keep this from happening. It's just poor axle alignment that's chewing up bearings. Some kits have better alignment than others or using hard hubs with inserts helps a little.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
RodRC
