    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 01-21-2015, 12:10 PM   #10651
Originally Posted by Krio View Post
I use their garodisks and love them, but I just use the 2 pad configuration. Much lighter and feels more linear.
Same here... love em, 2 pad (V2)
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 01-21-2015, 03:10 PM   #10652
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Originally Posted by iScream View Post
That's interesting. Maybe I should run 8.5 if I really want a similar feel between the two. Thanks, man.
I ran a 6.5 in my 44.2 and when I went to 2wd I switched to a 7.5 and they are very similar. I run minimal timing on carpet, especially since it's a smaller track. After a 5 minute race it was coming off at 105 if that. Geared 23-78 with the Schelle slipper. When I run off-road on a large dirt track I just increase ESC timing. Plenty fast.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 01-21-2015, 03:12 PM   #10653
hi im building my shocks put oil in and blead them one shock shaft pulls itself all the way up and the other doesnt move much. please help
DIRT DIGGER is offline   Reply With Quote
Old 01-21-2015, 03:24 PM   #10654
Jmuck69's Avatar
Just pump the shaft in and out a few times (what she said...). It's an emulsion shock so you need to mix the air with the oil evenly. It will balance out.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-21-2015, 03:33 PM   #10655
thank u. is it suppose to suck back up when u pull it out?
Old 01-21-2015, 06:44 PM   #10656
sanderson373's Avatar
Thanks, Scott. I've got a 17.5 in it right now cause I thought that was gonna be required. I decided on Saturday to redo the setups on both buggies and didn't have the B5 ready by the time I got there Sunday. So I ended up only running the D413.
I'm going to leave the 17.5 in there for this Sunday and see how I like it but want to be prepared with a mod motor depending on how things sort out with classes as we get going on the new track.
-Chris
Well I'm not gonna tell u what to fun but 17.5 is whatevery body is running because its plenty of fast and more controllable plus the track ain't that big so you can't open it up with the 8.5 like you can with the 17.5
Rc8b3e
B4.2, B5M,B44.3, t5m, SC5M, B5M Lite
Extreme Hobby Shop in Spring Hill,TN
Slash 4x4, tekno 410, slash 2wd, blue eagle, radicator
85' goldpan, rc10 worlds car, losi xx4
sanderson373 is offline   Reply With Quote
Old 01-22-2015, 12:37 AM   #10657
HYPERformance06's Avatar
Is it bad I'm running a tamiya part on my car? Could it be curse? Doesn't seem like it since I usually tq
Patrick Hertel
B5M - Trinity d4 17.5 1s ss
As I lay rubber down the street.
I pray for traction I can keep, but if I spin
And begin to slide, please dear god protect my ride.
HYPERformance06 is offline   Reply With Quote
Old 01-22-2015, 12:39 AM   #10658
Cursed? Tamiya parts lol
Patrick Hertel
Old 01-22-2015, 12:44 AM   #10659
Has anyone ever made these homemade wing mounts? The spacers are the old axle spacers off the b4 before they went to hex. Went behind the hub pin. Then you cut of some of the post and drill a hole. I cut just enough so the wing still sits onto the posts. I did this to my b4 as well. All of the screw wing mounts I have seen are all aluminum. I don't think I can trust aluminum mounted to my shock tower. Because when you flip over, the front shock tower and the rear wing take all the impact, and being the wing mounts are mounted in the middle of the shock tower I could see it snapping the tower. Rather have the mounts be flexible
Patrick Hertel
Old 01-22-2015, 03:29 AM   #10660
Trader Rating: 18 (100%+)
Did mine the same way,only I used wing washers from 8th scale.wings last longer now without those little clips to tear through the wing.
David Osborne,
Nemoracing usa
Gofast hobbies,West Virginia hobbies
Amain Hobbies
Fioroni usa
xxxntwv is offline   Reply With Quote
Old 01-22-2015, 06:08 AM   #10661
Jmuck69's Avatar
It will initially from the vacuum created when bleeding but after pumping the shaft quickly in and out a few times it will equalize and be fine.
B6D | B64D
Old 01-22-2015, 07:00 AM   #10662
couldnt agree more. the wing stay solid until its time to replace it. never had one where it would rattle on the mounts like they did being mounted with clips
Patrick Hertel
Old 01-22-2015, 07:00 AM   #10663
Cridd's Avatar
Trader Rating: 16 (100%+)
Look cool
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-22-2015, 07:34 AM   #10664
timannnn6's Avatar
Trader Rating: 124 (100%+)
Just a heads up....SMC's got most batts in stock including shortys.
http://www.smc-racing.net/index.php?...ory&path=67_97
timannnn6 is offline   Reply With Quote
Old 01-22-2015, 07:40 AM   #10665
Originally Posted by Cridd View Post
Look cool
yea i bought them a month ago. couldn't find anything for the b5m because no one carried them until a few weeks ago. now avid and other make them but they are all black and are just plain looking no cutouts at all
Patrick Hertel
