    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 01-14-2015, 10:35 AM   #10501
Mason's Avatar
washing balls, checking droop. When did this turn into a physical?
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-14-2015, 10:56 AM   #10502
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
When the guy who wears gloves to apply his tire sauce tells you to cough...RUN
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 01-14-2015, 11:08 AM   #10503
Super Moderator
racer1812's Avatar
Originally Posted by Bartman42 View Post
I've got some tires that vary in diameter. Just by changing tires it affects ride height by 2mm. What do you guys feel is more important. Keeping the ride height the same so CG is not changed or leaving the shock collars in the same position so the arm angles stay the same? Thoughts and theories please...
Cpt.Americas post raises some questions. But for myself and everyone I talk to, ride height is a constant and we don't change it based on tire size. Meaning adjust ride height to compensate for the difference in diameter.
Old 01-14-2015, 11:26 AM   #10504
Razathorn's Avatar
In regard to ride height changing for tires, you should always adjust ride height back after a tire change.
The shorter a tire gets, the less leverage the bottom of the tire (contact patch on track) has against the hub/spindle hinge pin fulcrum (think longer bar == more leverage) as the car is in a corner. This results in less ability to pull the camber link outward toward the outside of the corner and produce chassis roll. Raising the ride height up, as we all know, increases roll, so correcting ride height in this case replaces some of the lost chassis roll.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 01-14-2015, 05:32 PM   #10505
Trader Rating: 42 (100%+)
Thanks guys... I was thinking of splitting the difference but I think you've convinced me to reset ride height.
Bartman42 is offline   Reply With Quote
Old 01-14-2015, 07:47 PM   #10506
Suspended
Raz
I usually apply a little sauce to the rear tires, then scrub it in with one of those small fingernail brushes, then I use the same brush on the fronts without adding any more sauce. The brush has enough sauce stuck in the bristles to still effectively sauce the tires without really needing to add more. I make sure to keep the fingernail brush in an old resealable tire bag.
Mantis Toboggan is offline   Reply With Quote
Old 01-14-2015, 07:56 PM   #10507
Razathorn's Avatar
Originally Posted by Mantis Toboggan View Post
Raz
I actually do something similar with a toothbrush. Just use very little / leftovers from rears.
Old 01-14-2015, 08:27 PM   #10508
RCBuddha's Avatar
Trader Rating: 33 (100%+)
http://www.redrc.net/2015/01/schelle...r-arm-mount-d/
"The Schelle B5M aluminium rear arm mount D replaces the kit plastic part on a B5M and T5M. The design improves durability, ground clearance, and also ease of use to disassemble the rear suspension, while the added strength of aluminium allows for a minimalist design using machined Delrin pivot balls to allow for perfect suspension alignment. The compact design keeps the mount high off of the chassis bottom to avoid dragging on jumps and landings. With the addition of a rear carbon fibre cap, Schelle is planning new inner hinge pins that allow for rear-pull in dis-assembling the rear end and changing anti-squat. Available in both black or blue anodized with laser etched Schelle logo."
RCBuddha is offline   Reply With Quote
Old 01-14-2015, 10:06 PM   #10509
Trader Rating: 29 (100%+)
Are the schelle mounts available yet?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 01-14-2015, 10:12 PM   #10510
Suspended
Trader Rating: 61 (100%+)
Latest I've heard is the 3 gear is really good.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 01-14-2015, 10:15 PM   #10511
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
In regards to the different diameter tires, always reset ride height to the tires. This is a big thing in on road when running foam tires. If you forget to set it after a couple heats or practice runs the car just doesn't handle well anymore. I also have to readjust droop after a couple runs, so I would do that with the shock eyelet on my buggy.
With all this talk of foams... How do you guys go about replacing foams? I want to save both the tire and rim but replace my shot foams. But they are clay compound tires so acetone doesn't work... Do you cut them with an exacto knife?
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 01-14-2015, 10:32 PM   #10512
TOO-TALL's Avatar
Boil one side of the rim for 10 to 15 minutes should just come right off.
TOO-TALL is offline   Reply With Quote
Old 01-14-2015, 11:00 PM   #10513
On the foams most cut with a sharp exacto right at the inside bead. Replace foam and reglue not that hard really.
Kyosho MP-9 TKI3, Tekno SCT-410, AE B5M, AKA racing, Mel's Shells, Family Hobbies in Vineland NJ, Sjrc
purple rides is offline   Reply With Quote
Old 01-14-2015, 11:13 PM   #10514
Cridd's Avatar
Trader Rating: 16 (100%+)
A few on B5 nation said the same. Reedy will be interesting.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-15-2015, 04:19 AM   #10515
Jmuck69's Avatar
It's available to order, go get you one.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
