    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-12-2015, 06:42 PM   #10456
sanderson373's Avatar
Originally Posted by DIRT DIGGER View Post
thanks. im running on a med bite loose hard packed indoor track. im running it box setup and cant get steering or bite the car just wants to spin out i have to feather it the whole race and have on power steering. im putting flat arms on it now. is there anything else i can do or buy to improve these issues? please help thanks
Try some hole shot tires I'm a firm believer in them
Rc8b3e
B4.2, B5M,B44.3, t5m, SC5M, B5M Lite
Extreme Hobby Shop in Spring Hill,TN
Slash 4x4, tekno 410, slash 2wd, blue eagle, radicator
85' goldpan, rc10 worlds car, losi xx4
sanderson373 is offline   Reply With Quote
Old 01-12-2015, 07:10 PM   #10457
thebombster's Avatar
putting b5 arms on flat front and back. are the shocks suppose to mount to the front of the arms instead of the back like the stock ones? the rear arms look the same
The shocks mount the same, the rear look the same but it moves the hubs foward 2mm I think
thebombster is offline   Reply With Quote
Old 01-12-2015, 07:38 PM   #10458
TC5Driven's Avatar
I need some help on building the shocks on the B5M. The manual says to use a 5mm shock cup but I only see shock cups marked 1,2,3&4. I cant figure out what shock cups I should be using in the front and rear for a track such as OCRC in HB. Any help would be great.
TC5Driven is offline   Reply With Quote
Old 01-12-2015, 07:42 PM   #10459
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Dog Runner View Post
Sounds like you could be using better tires. I'd try that first. Maybe you could borrow tires from someone for a lap or two to test if you don't have what the "fast guys" are using.
My thoughts exactly... Make sure you have the correct tires and make sure your braking endpoint is set right... Touchy brakes can throw off your throttle if you are on and off both all the time... Mm is alot different then rm... For me i had to adjust to being alot more smoother at first... Really i dont even use the brakes except when jumping... You always have to be on slight throttle through the turns cause if you let off suddenly sometimes mm buggies will react violently... its all about how smooth you are with the throttle IMO... Box setup should run fairly fine with the correct tires!!
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 01-12-2015, 07:53 PM   #10460
thecman26's Avatar
Trader Rating: 99 (100%+)
Use the middle sized spring cups, the numbers only refer to the molds.
As far as proper building, theres a great youtube video out!
https://www.youtube.com/watch?v=k2ahQOYp49Q
https://www.youtube.com/watch?v=K5CLUAJIWIQ
https://www.youtube.com/watch?v=DCEtEPH526c
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 01-12-2015, 08:19 PM   #10461
Cridd's Avatar
Trader Rating: 16 (100%+)
+1 on tires. Was using chainlinks today and they were slippery, went to de ja vu and was like a totally different car, went from baby to beast.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-12-2015, 08:29 PM   #10462
anyone know the trick to puting these b5 arms on? does the left go on the right and right on left? so the shock mounts are on the back.
DIRT DIGGER is offline   Reply With Quote
Old 01-12-2015, 08:30 PM   #10463
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
the right goes on the left and so on
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-12-2015, 08:34 PM   #10464
thanks wild! both spacers behind hub?
Old 01-12-2015, 08:35 PM   #10465
yes, I run my hubs all the way forward
Old 01-12-2015, 11:54 PM   #10466
matt777's Avatar
This has most likely been covered a bunch of times, But why is the reason some run Kyosho springs, Is it just because there a slight different spring rate?
matt777 is offline   Reply With Quote
Old 01-13-2015, 01:55 AM   #10467
mdowney's Avatar
Trader Rating: 21 (100%+)
Kyosho's springs are made by X-Gear and they have a reputation for being the best quality springs on the market. Pro drivers from a variety of chassis sponsors have been running X-Gear springs on their kits (sometimes secretly) on and off for several years.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 01-13-2015, 01:44 PM   #10468
Looking for some advice. Been running my B5M and starting to get it dialed. Only think i can get figured out is how to get the car to maintain its corner speed. It seems like i have to slow down more than others to get the car to turn like it should. I'm running stock pistons and springs, with 25 wt oil. i had 30 in it but changed it to 25 and that really helped. Spindle height is still set to middle position. i use the same tires as the fastest guy so tires shouldnt be whats wrong. it feels like the car still pushes alittle in the corner. what would you guys suggest? thanks
TEAM HOLY ROLLERS
Team Associated B5M
PHILIPPIANS 4:13
bbrace3m is offline   Reply With Quote
Old 01-13-2015, 01:49 PM   #10469
MikeXray's Avatar
Trader Rating: 73 (100%+)
Have you tried the RM front arms and tower?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-13-2015, 01:56 PM   #10470
No i have not. how would that help?
TEAM HOLY ROLLERS
Team Associated B5M
PHILIPPIANS 4:13
