    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 01-09-2015, 02:14 PM   #10351
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Graham11 View Post
since bushings are cheaper than buying new caps, which bushings fit these older style caps? these:
http://www.amain.com/team-associated...g-blue-4/p7969
or I also have the schelle standoffs which I took off because the shock caps I got didnt fit and thats why i bought the AE standoffs, so I guess i could replace the b5m bushings with the old schelle b4 bushings:
http://www.amain.com/schelle-racing-...hing-4/p300382
Im not positive if the b4 schelle bushins will fit on the b5 style standoffs. But the AE bushings will work, remember that they are 4-40 thread though.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-09-2015, 03:14 PM   #10352
Razathorn's Avatar
Honestly, if you want to measure spring rate to compare and identify springs, all you need is a digital scale, a digital caliper with depth gauge, and a spring retainer. It takes a little practice to get it down, but once you do, it will seem silly how easy and obvious it is.
Stand a spring up on a digital scale with the spring retainer cup on the top. Slide the caliper depth gauge through the retainer and down to the scale surface. This allows you to measure the length of the spring and retainer cup. Now set your digital caliper for 1" shorter than that previous measure, and lock the digital caliper with the locking screw. Tare the scale out with the spring and retainer still on it and then stick the now 1" shorter depth gauge through the retainer and spring again, compressing the spring until the depth gauge hits the scale. You will see the numbers slowly creep up as you get closer to the surface of the scale, and then when you touch it, they will rocket up as you apply direct force with the digital caliper depth gauge instead of the spring. The number right before you touch the scale with the depth gauge is your spring force at 1", and that gives you the spring rate, which is generally measured in lb/in, so set your scale to lb/oz unless you want to do math, or have google do math
This will ultimately irritate you when you find out how far off AE's cheap springs are from their advertised rates. I'm not saying they're bad, or they're not consistent, but when they say they're 3.00 lb/in, they're not... they're more like 3.05 lb/in.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 01-09-2015, 05:07 PM   #10353
Can anyone confirm if the hard steering blocks and inserts cure the slop problem - or is glue required with those also? I just picked up a hard steering/insert set today and don't want to glue them unless I have to.
StadiumRC is offline   Reply With Quote
Old 01-09-2015, 05:14 PM   #10354
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
Glue still
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 01-09-2015, 05:31 PM   #10355
Originally Posted by deftones.jt@gma View Post
Glue still
Ok, thanks for the heads up. I didn't glue the ones on my B5 initially and then had to take them apart and glue them. I cant help but think they could revise that part so glue wasn't necessary. No biggie.
Old 01-09-2015, 06:24 PM   #10356
Use the set screws
robbie_gtc is offline   Reply With Quote
Old 01-09-2015, 07:29 PM   #10357
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I would prefer one piece spindles. The inserts were a good try at innovation, but one piece would have been fine.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-09-2015, 07:32 PM   #10358
Graham11's Avatar
Trader Rating: 21 (100%+)
What are you guys gluing? The inserts to the spindles?
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 01-09-2015, 07:36 PM   #10359
Super Moderator
Correct. Gluing the 0/5 inserts into the caster block. Takes away some of the play that can develop over time.
Old 01-09-2015, 07:48 PM   #10360
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Well no WONDER I haven't won the super nats yet... this WHOLE time I have my car set up for 3.00 pound springs like the package says!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-09-2015, 08:11 PM   #10361
I glued my trailing axle inserts into the steering blocks on my B5. Has been good ever since. I just don't like using glue - it's really not a huge deal, just would prefer to not have to if possible. I just finished gluing the inserts for my B5M. I haven't tried gluing the inserts in the caster blocks, I have been using the optional set screws.
Old 01-09-2015, 08:23 PM   #10362
Gpeters66's Avatar
It really ticked me off on this build that on the "Racer's Tips" Like putting in those set screws that they are NOT included in the kit!
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 01-09-2015, 08:23 PM   #10363
Mason's Avatar
I used some goop on all inserts as well as set screws. About as good as its going to get for interchangeable pieces.
Mason is offline   Reply With Quote
Old 01-09-2015, 08:24 PM   #10364
Mason's Avatar
I would rather they not put 8, 12, or 16mm heavy set screws in there when I can get by with a 3mm
Old 01-09-2015, 08:51 PM   #10365
thecman26's Avatar
Trader Rating: 98 (100%+)
That's because most "racers" already have all that kinda stuff perhaps?
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
