    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 12-30-2014, 05:11 AM   #10066
Suspended
Trader Rating: 61 (100%+)
MIP still hasn't given a solid date on their 3 gear last I checked. (2 weeks ago).
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 12-30-2014, 07:19 AM   #10067
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I was told that they pulled it. Unless they can find a way to make theirs much better than AE's, they have dropped the project for now.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-30-2014, 07:34 AM   #10068
Suspended
The billet alloy case was pretty badass.
Old 12-30-2014, 07:59 AM   #10069
99% bling, 1% cooling. Competing with AE's plastic case and pricing would be hard
Old 12-30-2014, 08:39 AM   #10070
thebombster's Avatar
Has anyone tried running the stock shock pistons 1.5 front and 1.6 rear? I didn't have time to get the machined pistons I needed and was curious if that would be better then the standard manual setup 1.6/1.7.. I run a indoor clay. High traction and 35/30 shock oil
thebombster is offline   Reply With Quote
Old 12-30-2014, 08:56 AM   #10071
triplesix's Avatar
Didn't try the 1.5 front, but I'm happily running 1.6 rear (and front btw.) with 32.5 (37.5 front) on high grip like astro or even carpet. Going from the 1.7 to 1.6 helped with landing bigger jumps on the hard surface.
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 12-30-2014, 09:29 AM   #10072
Suspended
Mip said this morning they will have it out and available early 2015.
Old 12-30-2014, 09:38 AM   #10073
hmm, those sponsored guys need to give more accurate rumors, lol.
Old 12-30-2014, 09:52 AM   #10074
Suspended
Just like when Ae mentioned their 3 gear, I just call the company direct. Ae gave a date of Jan 5th.
Old 12-30-2014, 10:18 AM   #10075
Now I'm nervous to try it I have them in already an got a big cash race coming, guess I'll find out if i get better results soon
Old 12-30-2014, 10:30 AM   #10076
dbowen's Avatar
I would run either 2x1.6's all the way around or 3x1.4's in the front 1.6's rear or 3x1.4's all the way around. I run 1.6's in the rear if the track is smooth and high bite but if it is medium to high with a lot of bumps and stuff I run 3x1.4's in the rear but I always run 3x1.4's in the front
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 12-30-2014, 10:56 AM   #10077
Yea most people run 3x1.4's but LHS didn't have any so I'll try them out and if it doesn't work I'll put 1.6's in
Old 12-30-2014, 11:01 AM   #10078
Trader Rating: 14 (100%+)
Default Reedy Motor Tabs
I just finished my B5M build and went with a Reedy 17.5T motor.
Out of the factory sealed box, the motor tabs/posts have a little play in them.
Is this normal?
I just put a small zip tie around the "B" tab so there is no way it could ever touch "A" or "C".
I was told by the LHS this is normal.
Thanks!!
sstriano is offline   Reply With Quote
Old 12-30-2014, 11:50 AM   #10079
Is this normal?
Thanks!!
Sounds fishy to me......I have several Reedy motors at home (Mach 1 and 2) and don't remember any of them having noticeable play in the tabs. Someone correct me if I'm wrong but aren't all of the tabs connected to the sensor board? I would call AE and talk to them about it.
StadiumRC is offline   Reply With Quote
Old 12-30-2014, 11:58 AM   #10080
At the LHS, we opened one up and the tabs sit in a groove inside the non-conductive (forgot the word) material where they are then soldered to the stater (correct piece?).
We called Associated and the guy said they are designed this way so they dont break that solder to the stater as they would if they were completely rigid.
He also said they all vary in the degree they move, but I just wanted to get some feedback from the forum.
Thanks!!
