    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 12-26-2014, 05:52 PM   #10021
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Originally Posted by steelers82 View Post
does anyone know how to install the ft steering rack, no idea where the shims go that come with it?
goes between the bearings.
http://www.redrc.net/2014/12/avid-b5...m-spring-cups/
"Avidís Avert aluminium spring cups for the Team Associated B5, B5M and B44.3 are a direct replacement for the standard plastic cups and they are of a unique angled slot design to prevent them from coming off in demanding conditions. They also fit snug on the shock eyelet to help prevent shock shafts from pulling out of the plastic shock end. The cupís dimensions resemble the +5 Associated parts, they are machined from black anodised 6061-T6 aluminium material and come in packs of four including an Avid mini decal sheet."
RCBuddha is offline   Reply With Quote
Old 12-26-2014, 06:36 PM   #10022
vito's Avatar
thanks guys I get buy from a little help
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 12-26-2014, 06:50 PM   #10023
Suspended
Trader Rating: 61 (100%+)
So you made a heavier piece in the worst place possible.
I hope they're cooler, but this also, "Traxxas T maxx make everything out of aluminium" mentality isn't for me. The plastic ones work fine, and I haven't seen a spring cup failure since my xx days.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 12-26-2014, 06:54 PM   #10024
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Aluminum pieces often do not weigh more than their plastic counterparts.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-26-2014, 07:28 PM   #10025
Trader Rating: 14 (100%+)
Default Soldering
I read through the soldering threads but was just wondering if anyone has some input on this. I bought some 0.050 63/37 rosin core Radio Shack solder and a bottle of liquid rosin flux from the local electronic store but its RA not RMA flux. Will this work for soldering bullet ends and the ESC wires to the motor? Not real familiar with soldering. Thanks.
sstriano is offline   Reply With Quote
Old 12-26-2014, 07:35 PM   #10026
Suspended
I would assume if these saved even a gram of weight, it'd be all over the advertisement.
Edit:
1.3g each. Minimum Weight, Maximum Durability.
What do the stock spring caps weigh?
Old 12-26-2014, 09:58 PM   #10027
Trader Rating: 17 (100%+)
need a little more rear grip, new to offroad but not racing, running kit setup on tight indoor clay track. Tires of choice are super softs or m4 compound, have tried different compounds and inserts but the rear of the car is a bit to free to really push the car. I have managed to tq and win the last 2 races out of the3 i have entered. i removed the ft 2mm spacers under the ball studs looking for more grip. What would be the next step? short rear links? springs? oil? car is not bad but i have to be really smooth or the rear wants to step out, this is in stock buggy.
customss is offline   Reply With Quote
Old 12-26-2014, 10:31 PM   #10028
Cridd's Avatar
Trader Rating: 16 (100%+)
You running rm rear arms?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-26-2014, 10:43 PM   #10029
samnelso's Avatar
The solder alone should be fine. You shouldn't need the liquid flux. Our components are usually fairly clean and don't need more flux than what's included with the wire. Too much flux can just make a mess. Most guys use 60/40, but your stuff is OK. I also personally use finer solder. I believe it's 30mil. Not saying bigger stuff won't work, I just like smaller strands and I'll just feed more as required.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 12-26-2014, 11:22 PM   #10030
Super Moderator
I find that even with RS 60/40 rosin core solder, having paste flux on the surface makes for a FAR better soldering experience. Heat transfers faster, perfectly clean shiny solder joints. I even use to DE-solder something.
- RCSpecialties -
Old 12-26-2014, 11:23 PM   #10031
timannnn6's Avatar
Trader Rating: 124 (100%+)
Read the soldering bible. This has helped me tremendously. Using flux is key.
How to solder correctly (a not so brief lesson)
timannnn6 is offline   Reply With Quote
Old 12-27-2014, 12:28 AM   #10032
slashdad's Avatar
Can anyone recommend an aluminium servo horn from Amain that is a good fit for a SAVOX 1251 and the b5M?
B5M, T5M, B44.2, B4.2, DEX210v2, SC10B, Xray T3 2012.
Savox : Spektrum : Proline : JConcepts : Turnigy : Trackstar Gen II's
Knox OFF Road RCC member, waiting for toddler to grow up...
Please explain roll centres to me one more time...
slashdad is offline   Reply With Quote
Old 12-27-2014, 05:33 AM   #10033
no im running all stock b5m
Old 12-27-2014, 05:57 AM   #10034
Alloy spring cups are heavier. I use them as a tuning option. My local track can be really fast but gets pretty rough too. The weight keeps the inside front wheel more planted while turning when you have a soft enough suspension setting to handle the rough. It eliminates the wheel chatter. Remember the game is about traction. Traction comes from the correct amount of presure on the tire. A heavier sprung weight adds presure to the wheel. Of course common knowledge states the less unsung weight the better, that's not always true.
bambambennett is offline   Reply With Quote
Old 12-27-2014, 06:12 AM   #10035
dbowen's Avatar
Since you don't have the RM rear arms you can push your rear hubs all the way forward, put your shock all the way in on the rear shock tower, go to 0 ballstud washers on the rear inner camber link, go to the 2 hole insert in the rear hubs all the way out (long link) (I did this the other day and my car was almost to locked in), softer oil and spring in the rear, larger hole or more holes in piston.
Those are a few things you can do to get more grip.
I run on a medium bite track usually and I run stock and my setup is basically exactly like what I just gave you but I run 3x1.4s all the way around 32.5 in the front 30w in the rear white springs front and green rear and I have the RM rear arms and my car is pretty much always locked in.
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
