    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 12-21-2014, 08:59 AM   #9901
Originally Posted by Cridd View Post
I was looking for information on what the difference in new firmware / upgrade was but it doesn't show anywhere. Feels really slow and times confirmed. Last night was ugly, thought I had a 21.5. Going to drop back and check times. New to Orion so playing with it. Any luck with mod firmware in B5m or better to stick with stock firmware for stock?
Don't run the stock firmware as it is meant for touring car, stick with the mod firmware that came pre-installed on the Speedo. I got a stock setup from Joe Pillars the Team Manager for Orion that he recommended if you will not be running boost or timing. It's the setup that Cav and a few other Team Drivers used at this year's Stock Nationals at OC/RC. All you do is use profile 4 under running mode
- forward/brake/-zero timing
On the DRRS punch setting
- set it to 9
Everything else you leave as is.
flintTRDTC is offline   Reply With Quote
Old 12-21-2014, 09:29 AM   #9902
Trader Rating: 14 (100%+)
Originally Posted by Wildcat1971 View Post
The top shaft bearings dont always seat the best. use the topshaft and try to press them into place.
The weird thing about it is that it is smooth all the way around except for a couple tight spots for like to or three "clicks" on the spur gear.
So I guess what I am say is that if you turn the spur really slow, it is smooth until you hit the spot where there are two or three spots (I would say like clicks or teeth on the spur) where it is not smooth.
If you grab the slipper clutch nut and spin it from there, it is smooth and you can barely feel the "clicks" at all... Almost like there is a mesh of the geras that needs to be broken in.
It is not the whole rotation of the spur that is "clicky" at all, just that one little spot in the system...
Only way I could explain it. I am a rookie!!
Thanks!
sstriano is offline   Reply With Quote
Old 12-21-2014, 09:32 AM   #9903
roadblock's Avatar
Default Weight difference between B5 and B5M
Is there a big difference in weight between the B5 and the B5M? Just picked up a B5 and noted how light it is compared to my Schumacher SV2 and was wondering if the B5M was heavier with the aluminum chassis.
Running 17.5, the SV2 is a bit too heavy to make short run up jumps. Rotates awesome and is very planted but needs more motor to make it shine.
Kevin Porchia
No team, no sponsors
Island Raceway, Lindenhurst NY
roadblock is offline   Reply With Quote
Old 12-21-2014, 10:01 AM   #9904
Graham11's Avatar
Trader Rating: 21 (100%+)
Guys, how do I stop my rear drive cups from hitting the cva driveshafts and breaking them? Limiters inside the shocks or limiter above eyelet to stop up travel?
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 12-21-2014, 10:18 AM   #9905
huzzler's Avatar
Thanks!
Pretty normal for a stock spur. They aren't perfectly round. The way I set the mesh with a gear like that is to find the "high" spot and set the mesh there. If you get an aftermarket spur like a Jconcepts they are machined and are more precise.
Tekno EB48.2,Associated B5,Losi SCTE Pro8,Losi xxxsct,Jammin X2 ,Jammin scrt10,RC10.
huzzler is offline   Reply With Quote
Old 12-21-2014, 10:21 AM   #9906
huzzler's Avatar
Depends. Are they hitting when compressed? Then limiters above the eyelet. If they are binding when lifted in the air then limiters IN the shock.
Old 12-21-2014, 10:29 AM   #9907
Graham11's Avatar
Haha Thanks I knew the options and when to use them haha,the thing is that I'm not certain when they are hitting, was hoping someone else had encountered the issue so I wasn't guessing.
Old 12-21-2014, 10:47 AM   #9908
Trader Rating: 29 (100%+)
So correct me if im wrong but you are breaking the outdrive? If so i have never heard of that and when are they breaking? After a cartwheel in the sweeper or just landing off a double or something?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 12-21-2014, 11:05 AM   #9909
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
You would be perfectly correct. IF the guy you quoted was talking about his pinion/spur gear mesh. He's not, he's talking about the gears IN the tranny. Which IMO simply need to break in.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 12-21-2014, 11:09 AM   #9910
huzzler's Avatar
Sounded to me like you were asking.
"Guys, how do I stop my rear drive cups from hitting the cva driveshafts and breaking them? Limiters inside the shocks or limiter above eyelet to stop up travel?"
Anyway never had that problem but I do have scrape marks on the shafts though. Most likely they are hitting on the way up. Probably binding when landing kind of sideways off a jump. It will fully compress the shock and even flex the a arm a bit. If you are consistently having this problem I don't see why a 1mm spacer or two would hurt.
Old 12-21-2014, 11:11 AM   #9911
huzzler's Avatar
Ha I thought he was talking about pinion/spur mesh.
Old 12-21-2014, 11:46 AM   #9912
Graham11's Avatar
No, I'm breaking driveshafts. And no it's not after catastrophic crashes. On my drive shafts you can see what I can only analogize to the marks of an axe on a tree, slowly overtime it looks as tho the edge of the out drive cup is hitting the shaft and eventually it's hit so many times it breaks, I'd take a pic but it's on in my car at the moment.
Old 12-21-2014, 11:53 AM   #9913
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
are you using gear diffs?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-21-2014, 12:02 PM   #9914
would a fully upgraded b4.1 still be able to compete with the b5m? or time to hang up the b4.1 and move on?
NewbieRacer30 is offline   Reply With Quote
Old 12-21-2014, 12:19 PM   #9915
Graham11's Avatar
Yes sir
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
