    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 12-18-2014, 10:34 PM   #9841
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by user1 View Post
I just built my B5M and have to say I am disappointed in the design of the suspension. Tuning droop with spacers under the shock pistons?!?! Come on. Looking it over, it would have been so easy for them to put droop screws in the back A arms. The chassis is could have had ears coming out like on the RC8.2e and wouldn't have cost them a penny. The front is a little trickier but with a little design work they could have incorporated the ears in the front hinge pin mount. It really is disappointing. Let’s face it, spacers under the shock piston is a very amateur design. I would rather turn a screw to adjust droop instead of tearing apart a set of shocks in between rounds. That is assuming you have time to do that. With droop being such an important tuning tool, I would think Associated would have made it better for their customers. Don’t get me wrong, I like the car in general, but with just a little effort, it could have been really nice.
Shock limiters are superior to droop screws in an off-road vehicle, even though it would seem counter-intutive. In an offroad car, as dirt runs through the car (even little bits)... the droop screws slowly but surely start to dig into the chassis, and your droop actually changes as you run. When I ran the DEX, I found the droop screw system to be flat out terrible. It was OK to find a droop setting that worked, but then it was always better to pull the screws out, and replace them with shocker limiters.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-19-2014, 12:03 AM   #9842
ckoetsch's Avatar
Trader Rating: 18 (100%+)
i tried ceramic trust balls last week and it felt like there were rocks in my diff, went back to the steel balls and the diff feels like glass.
Sick Graphics - KYOSHO RB6.6 - "If you ain't first you're last" R. Bobby
NW Hobbies of Albany and Dave's RC Tracks of Hubbard.
ckoetsch is offline   Reply With Quote
Old 12-19-2014, 12:15 AM   #9843
Originally Posted by chef88 View Post
Building my first Off Road in 15 years.
Everything going smooth so far...
I was wondering does anyone make a diff Thrust Ball Assembly w carbide balls for the B5M?
Really do need to improve what comes in the box.
Actually found one...........
Schelle Racing Innovations
like this or like this?
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 12-19-2014, 08:54 AM   #9844
Razathorn's Avatar
Lol, the only upgrades I have done are ft turn buckles and longer ball studs in the plastic rear hubs so I could use a washer on the plastic side and a locknut on the metal side.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 12-19-2014, 08:55 AM   #9845
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
The box stock ball diff assembly is super smooth when built and broken in correctly...what did u not like about it?
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 12-19-2014, 09:52 AM   #9846
Originally Posted by sstriano View Post
Are the aftermarket parts (Associated or not) worth the money or are they just "bling". Like rear ball mount, hinge pin brace etc?
Or should I just get a good slipper and run the stock build?
Just wondering if there is any advantage to the aftermarket parts besides look?
The rear ballstud mount is a must IMO.
sheeldzy is offline   Reply With Quote
Old 12-19-2014, 10:27 AM   #9847
Originally Posted by Razathorn View Post
Droop screws are not ideal either--their setting drifts and being so close to the chassis, they're not very much of a hard stop compared to limiting the shock stroke. You'll find that the pros run limiters and unscrew the eyelets even in 1/8 scale racing now days and many times throw those droop screws out.
The proper way to adjust droop on these cars is not to rebuild the shocks, but run the limiters that allow you to adjust the shock eyelets (screw in vs out) to get the droop you want. This is how it is done on most 1/10 scale cars, and certainly every platform that currently holds a world title.
For example, run 1 limiter in all shocks and you can easily reach all shock droop settings with the eyelets. Popping a shock off and unscrewing the l eyelet is super simple and a very hard stop for the suspension.
Wayne
That is good input Wayne. Thanks. I will try to get the shock spacers set up so I have enough adjustment with the eyelet.
user1 is offline   Reply With Quote
Old 12-19-2014, 11:58 AM   #9848
bigcracing's Avatar
Trader Rating: 32 (100%+)
If I bought all the aluminum and titanium upgrades for the buggy how much weight am I saving? Has anybody done this yet? I would like to bring the weight down to the minimum allowed.
bigcracing is offline   Reply With Quote
Old 12-19-2014, 12:03 PM   #9849
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
you can knock 100-200 grams off the car
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-19-2014, 12:19 PM   #9850
bigcracing's Avatar
Second question from part one is the minimum weight 1500grams
Old 12-19-2014, 12:27 PM   #9851
Suspended
Trader Rating: 61 (100%+)
Alloy upgrades over plastic add weight.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 12-19-2014, 12:36 PM   #9852
bigcracing's Avatar
What are you guys doing to drop weight?
Old 12-19-2014, 12:52 PM   #9853
Mizchief's Avatar
Diet and exercise...
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 12-19-2014, 01:10 PM   #9854
thecman26's Avatar
Trader Rating: 98 (100%+)
cut gears, machined motor plate, pucks, turnbuckles, screws, and X-Factory carbon chassis. From what I have seen. I did all that but not the chassis, yet.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 12-19-2014, 01:16 PM   #9855
Jmuck69's Avatar
+1 hahahahaha!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
