    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 12-18-2014, 05:55 AM   #9796
triplesix's Avatar
Running mod on carpet, I have my slipper pretty tight and a gear diff. My stock slipper unit was wildly (no doubt!) inconsistent as well, so I put in a Schelle. What a difference!! I'm not saying the stock slipper isn't working at all, but after installing the Nova - all questions answered. It drives the same every lap after lap after lap, in every situation.
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 12-18-2014, 06:27 AM   #9797
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by Razathorn View Post
Wow, my stock slipper has been amazing. I run my slipper tight though and only use it to protect my diff.
I tried the stock slipper and the 2 pad setup. Bother were terrible. I try to set my cars for 3 inch lift.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 12-18-2014, 06:57 AM   #9798
Mizchief's Avatar
+1 my slipper is my finger
/that didn't sound right...
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 12-18-2014, 07:08 AM   #9799
Suspended
Trader Rating: 61 (100%+)
Originally Posted by sstriano View Post
Where is the best place to buy the Avid?
And what does the Exotek Eliminator do?
Thanks!
Straight from avid, or your local shop. My local shop stocks the Schelle stuff.
http://www.avidrc.com/
The exotek eliminates the slipper altogether. If I continued running 17.5, I was going to opt for this, as it will give the most power at the risk of hurting spur gears or a badly adjusted diff. If you're accustom to hitting things,or are new, don't go this option just yet.
Socket is offline   Reply With Quote
Old 12-18-2014, 07:10 AM   #9800
Suspended
Originally Posted by BRSracing View Post
I run 17.5 recently purchased a new motor. Same brand same turn however is slower than the one I replaced . The seal on the box was broken but did not think much as there was no solder and looked new. Reading I see where shops pick motors and piece together best parts. How much difference does it make to do that?
Back in the day we called it the mail order gamble.
You never know what you'll get!
Even back then, you bought the aftermarket "tuned" motors, and that's what I'd continue to recommend if you're serious about 17.5. There's a couple companies that build mass produced numbers and can hand pick them for you. Trinity does this with their "certified" line, as does Express as well. I believe R1 wurks does, but I don't have any experience with their stuff.
Old 12-18-2014, 07:12 AM   #9801
Suspended
If you're running it tight, then I don't see how it does much of anything except what you need, protect the diff and weigh down the drive train.
I was told not to run the OEM slipper. I spent the few bucks to go with the avid on my RM car, and the Schelle on my MM car. They've worked fine for me, and been super consistent.
Everyone has their own experience, and that's really all we can lean on when giving opinions.
Old 12-18-2014, 07:12 AM   #9802
Fantom is another big one
Old 12-18-2014, 07:13 AM   #9803
Suspended
Which combo did you put in the schelle? Right now I'm running the smooth setup, and would like to play around with it.
Old 12-18-2014, 07:14 AM   #9804
Suspended
I somehow got lucky with the D4 I mail ordered. It ran cold, and was a rocket.
Old 12-18-2014, 07:16 AM   #9805
Nice.
Old 12-18-2014, 07:18 AM   #9806
mjbtaco's Avatar
i run two red pads and one white pad in my schelle slipper.
mjbtaco is offline   Reply With Quote
Old 12-18-2014, 07:23 AM   #9807
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Schelle Slipper Setup on Carpet
When I ran my B5m in Mod on Carpet I ran the pads on my slipper Red White Red and really liked how that felt. I was running a 7.5 turn motor and was able to get the slipper set where the car would only go forward and never pull front wheels off the ground but never felt the slipper was really slipping either... Just that perfect mix of both!
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 12-18-2014, 07:25 AM   #9808
Suspended
What surface are you racing on? Mod or 17.5?
Best Avatar on rc-tech
Old 12-18-2014, 07:26 AM   #9809
JFuel11's Avatar
Default The last pad counts...
Depending on what you run on the very outside for pads makes a huge difference on the slipper because it has a plate on both sides of the slipper pad. So running a white vs a red is a big change in how the slipper operates. On slick to med traction I like Red (Inside) White White. On Higher grip surface medium to high, I like White White Red and then on carpet Red White Red. At least for me on the Nova Slipper from Schelle.
Sponsors:
Old 12-18-2014, 07:26 AM   #9810
Suspended
I'm still taking it easy with a 9.5, but I'm also running on dirt.
