    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 12-13-2014, 01:55 PM   #9631
Trader Rating: 16 (100%+)
Originally Posted by Bubonic-X View Post
How does the throttle stick with a speed control?
Set your endpoints or if your using spektrum and savox you need to buy a glitch buster. Your rx is loosing power to the servo.
krawlingxj is offline   Reply With Quote
Old 12-13-2014, 02:40 PM   #9632
Actually spektrum/savox issues just point out that the bec is weak or failing on your esc
robbie_gtc is offline   Reply With Quote
Old 12-13-2014, 04:00 PM   #9633
Mason's Avatar
This was the second change i made behind going to the b pill in the hubs. Can always add the .5 in the stock hubs. Now with the c/d alum set you have better control over the antisquat.
Originally Posted by skrichter View Post
For those folks looking for more corner speed, I would suggest trying 2.5deg of rear toe.
I see Thielke has been using it on all of his setup sheets, so I gave it a shot. I really like it!
Mason is offline   Reply With Quote
Old 12-13-2014, 04:02 PM   #9634
Mason's Avatar
Recently went to the outer hole on the front hub. Like butter.
Originally Posted by RobsRacin View Post
Looking for some more front end traction while turning. Medium traction compact topsoil. Any suggestions? Running the out of the box setup right now but would like a direction to go. Plenty of rear traction just seems to be pushing. Thanks
Old 12-13-2014, 05:42 PM   #9635
Regional Moderator
RobsRacin's Avatar
I'll give it a shot! Thanks
RobsRacin is offline   Reply With Quote
Old 12-13-2014, 06:39 PM   #9636
billdogg's Avatar
Trader Rating: 15 (100%+)
What kind of servos are you guys running? I'm running a Savox 1251 low pro that I used in my MM 22 2.0. I used that to gain room on the chassis. The B5M has plenty of room, and I could use a Savox 1257 I have laying around. Their speeds @ 6.0v are .09 - .07, and torque 125 - 139.
billdogg is offline   Reply With Quote
Old 12-13-2014, 06:58 PM   #9637
RCBuddha's Avatar
Trader Rating: 33 (100%+)
http://www.amain.com/team-associated...eatsink/p18449
RCBuddha is offline   Reply With Quote
Old 12-13-2014, 09:14 PM   #9638
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
mine are .07 240oz... protek and hitec 8360
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-14-2014, 12:35 AM   #9639
Trader Rating: 29 (100%+)
A savox 1257 is plenty of servo for this car. Most people I race with that have the really fancy $150 servos, turn the speed or dual rate down so that its drive-able. There is a benefactor to having a nice servo and thats if you hit something or land a jump funny it wont shred the gears. I have had good luck with a few brands of servos Savox being one of them.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 12-14-2014, 12:54 AM   #9640
onefast8's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Cridd View Post
Anybody running exotek slipper eliminator have a hard time getting it slipped over and alum topshaft? I know top shaft has two flat sides and so does exotek but man it was tight had to push on pretty good, wonder about others experience.
I have the MIP top shaft. It was a tight fit but after taking it off to inspect nothing was scratched, dented or binding, just super snug.
Jake R.
onefast8 is offline   Reply With Quote
Old 12-14-2014, 07:48 AM   #9641
Cridd's Avatar
Cool. It is a nice piece for 17.5 racing. I think my brain likes it more then the performance upgrade, just knowing my slipper is not an issue or something I need to tinker with.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-14-2014, 10:03 AM   #9642
bigcracing's Avatar
Trader Rating: 32 (100%+)
What is the best battery location all the way forward with ESC behind it or sideways forward or back. I am running stock 17.5 and looking for more front bite. I have a lot of push even with blue jc dirt webs. Does forward battery location help? Thanks Chris
bigcracing is offline   Reply With Quote
Old 12-14-2014, 10:34 AM   #9643
I find battery forward, in line, esc behind is the best. Good forward bite, good stability in cornering, and it helps pitch nose down a bit after takeoff on a jump to land the backside, especially in 17.5 when the motor and gyroscopic effect isn't as great.
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 12-14-2014, 10:39 AM   #9644
This situation could be tricky, I would run the battery back and look at changing rear hub location and front shock package to gain the steering at first. Moving the weight forward will cause you to lose some forward bite but you will gain some steering. What front arms and tower are you using?
Old 12-14-2014, 10:59 AM   #9645
bigcracing's Avatar
Every thing is stock even the settings? Running indoor clay medium traction.
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Dmkiefer
