    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-11-2014, 09:46 AM   #9586
Regional Moderator
RobsRacin's Avatar
Originally Posted by Matt Trimmings View Post
Make sure you put the screw in the correct side when building the diff. There is only one correct way to do it and it sounds like you have it swapped.
Thanks I'll pull it apart and try again
RobsRacin is offline   Reply With Quote
Old 12-11-2014, 09:59 AM   #9587
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
As you break the diff in, you will end up tightening down the diff bolt more and more.. which will pull the nut farther into the outdrive.
Also make sure you pre-compress the spring per the manual, before building the diff.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-11-2014, 10:32 AM   #9588
Regional Moderator
RobsRacin's Avatar
Yep got it all set now. Thank you
Old 12-11-2014, 02:30 PM   #9589
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
With all these treadless slick tires coming out, anyone try their b5m on asphalt onroad tracks?
Looking forward to try out some slicks, putting a sway bar, stiffer springs and heavier oil to run through it paces at the local onroad track.
lagcisco is offline   Reply With Quote
Old 12-11-2014, 02:46 PM   #9590
Graham11's Avatar
Trader Rating: 21 (100%+)
Confused... On this set up do I mount the rear camber block so it's +2mm or thick side up or bevel side on the Schelle or do I do -2mm. His notes say "aluminum ball stud mount -2mm up" which confused me.
http://www.petitrc.com/setup/associa...ks_SDRC201409/
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 12-11-2014, 02:50 PM   #9591
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Since he is running a 3mm ballstud spacer there, it's safe to say its down. So its like stock +1mm spacer. Otherewise it would be like a 5mm spacer
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 12-11-2014, 03:18 PM   #9592
Graham11's Avatar
That's part of why I was confused as well haha, I thought to myself why run -2mm w 3mm spacer instead of stock w 1mm but ok thanks. I assume he's running no spacers on the hub?
Old 12-11-2014, 03:26 PM   #9593
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
It specifies which hole is used on the hub but not how many washers. You can clearly see some ballstud washers on the rear hub (but not how many). For what its worth I am running the same link and have 3mm on the hub.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-11-2014, 03:40 PM   #9594
rigor's Avatar
Trader Rating: 37 (100%+)
Questions??
Originally Posted by heinen81 View Post
Yeah the whole inline battery or battery and electronics topic has confused me. Maybe its just personal preference, or believing something feels better because you want it to... but any of the big races I've been to, Cav and those guys have their batteries and electronics in the stock locations, and not hacking up their cars to relocate anything. I did see Cav moved his steering servo to the opposite side on his B44.3... but other than that, if the pros aren't cutting cars apart to get them to handle, I cant believe they don't work without re-configuring everything.
Originally Posted by lbckevin View Post
They are not allowed per team rules.
Inline config capability from AE in the B5.1m perhaps?
* Jesse H. *
rigor is offline   Reply With Quote
Old 12-11-2014, 03:59 PM   #9595
Just switched back from Inline to stock to see and for my current track layout it worked much better
Jade67 is offline   Reply With Quote
Old 12-11-2014, 04:36 PM   #9596
Zaxbys's Avatar
There's a local asphalt oval where I live that has some electric offroad classes. The soft compounds are too much for that track. You get a ton of speed in the straights, then come into the corner a bit fast, flip, and tumble into the chainlink fence (don't ask me how I know...). There was a guy there that tried out the aka slicks and didn't like them at all. I ran the dirt hawgs on my buggy and they do just fine grip wise. My father likes to buy some used pin or bar tires from off here and run them. after a heat or two, they are starting to turn into a slick anyway
Zaxbys is offline   Reply With Quote
Old 12-11-2014, 10:24 PM   #9597
Cridd's Avatar
Trader Rating: 16 (100%+)
What ride height out of curiosity on the asphalt?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-12-2014, 12:11 AM   #9598
ckoetsch's Avatar
Trader Rating: 18 (100%+)
battery location is personal preference inline and stock positions both work, depending track and driver. i like mine inline for now less chassis roll and more corner speed for me. it would be nice if we didn't have to cut the car but it not to much trimming.
Sick Graphics - KYOSHO RB6.6 - "If you ain't first you're last" R. Bobby
NW Hobbies of Albany and Dave's RC Tracks of Hubbard.
ckoetsch is offline   Reply With Quote
Old 12-12-2014, 06:49 AM   #9599
bigcracing's Avatar
Trader Rating: 32 (100%+)
What trimming are you talking about? Any pics?
bigcracing is offline   Reply With Quote
Old 12-12-2014, 12:40 PM   #9600
Zaxbys's Avatar
I didn't lower my buggy that much because A. it didn't feel like it needed it and B. if I got messed up or had to avoid someone and ended up in the grass, I didn't want to get stuck.
I honestly never measure my ride height. I tweak it a little here and there, but it's probably something I overlook a lot.
Also, this wasn't a b5m either; It was a GT2 rear suspension converted to electric and buggy arms plus a b4 front end with a delrin chassis connecting the two
