    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-08-2014, 01:59 PM   #9556
Mizchief's Avatar
Originally Posted by 3D-Seth View Post
My local track has a lot of rocks in their dirt. Scratches up the alu chassis pretty good/quick.
Also, I know for myself, I go through chassis protectors not from use, but from maintenance on the car, having to get to screws and such. I won't cut holes in the protector for the screws. I will usually just replace the protector when I have to get to screws. I'm a little picky when it comes to my cars though.
Seth
I just cut the holes about dime-sized around the screws then replace them when done or cut a fresh patch from the excess material around pre-cut on the sheet.
Would probably be easier to use some kind of small hole saw bit if you could find one small enough to get the cleanest fit.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 12-08-2014, 06:44 PM   #9557
vito's Avatar
is the shelle ball stud mount I have the thin side up with 2 mm spacer in the middle hole?
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 12-08-2014, 07:13 PM   #9558
Originally Posted by lbckevin View Post
They are not allowed per team rules.
So then why is it ok for cavalieri to drill holes and mount servo on opposite side on his b44.3 or drill new holes in the front arms for shock mounts?
Or the t4.2's drilling 4th holes in the rear towers?
B4's grinding rear ballstud mount down.?
I am sure AE would prefer they not hack up a car. Cavalieri did testing on preproductions. I bet they tried the inline at that time and found the stock setup to be preferred for most situations.
robbie_gtc is offline   Reply With Quote
Old 12-08-2014, 09:07 PM   #9559
I would have to agree. ^^^^^^
I have seen a few of them try different things but most went right back to their stock layout.
flintTRDTC is offline   Reply With Quote
Old 12-09-2014, 06:37 AM   #9560
Mizchief's Avatar
I would think winning would be more important than remaining stock. Then they can use some of the mods to sell upgraded parts, but wouldn't want to go so far as to give the impression that the car isn't any good. Since the Losi is an inline setup, it may suggest to some people to just by the Losi vs having to hack up a brand new kit.
Tekno Team Driver
AKA Racing
Old 12-09-2014, 07:57 AM   #9561
Cavalieri Burns Up Some Carpet In Pacific NorthwestCavalieri Burns Up Some Carpet In Pacific Northwest
http://www.teamassociated.com/news/r...ific_Northwest
asier is offline   Reply With Quote
Old 12-09-2014, 08:59 AM   #9562
You guys need to look into the epic1DESIGNS chassis armor sheets. You can peel and re-stick them when needing to access screws.
http://www.discountrcstore.com/epic1...mor_s/1328.htm
Jason Pietsch
REDS Racing | Sanwa | Big D's Juice Packs | MIP | LiveRC.com
J.Pietsch is offline   Reply With Quote
Old 12-09-2014, 09:06 AM   #9563
Jordan Anderson's Avatar
Is the gyroscopic effect of the motor being reversed with the 3 gear transmission in the B5M a good thing?
What does the gyroscopic effect of the motor do with the 3 gear vs. the 4 gear?
I remember there being some discussion on this effect with the old SC10 4x4...
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 12-09-2014, 09:27 AM   #9564
RCBuddha's Avatar
Trader Rating: 35 (100%+)
See if this helps: http://www.team-durango.com/blog/201...onfigurations/
RCBuddha is offline   Reply With Quote
Old 12-09-2014, 09:38 AM   #9565
Originally Posted by RCBuddha View Post
Thanks!
JORDAN // EVAN
Old 12-09-2014, 10:48 AM   #9566
Regional Moderator
RobsRacin's Avatar
Any body have a link to a setup sheet they like for medium grip smooth track? Just want to get a baseline for when I build my kit.
RobsRacin is offline   Reply With Quote
Old 12-09-2014, 10:57 AM   #9567
Razathorn's Avatar
The setup I posted a day or so back was done specifically for a medium grip track. You would want to try white springs as an option if you think your surface has enough grip, but I run greens just because we tend to get stuck with really dry main events and it's a huge advantage at that point.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 12-09-2014, 11:11 AM   #9568
Regional Moderator
RobsRacin's Avatar
Great thank you
Old 12-09-2014, 11:24 AM   #9569
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
I would be very interested to see his setup, as one of the local tracks I race at has a rule against mini-pins on carpet. I found running slicks or ghosted tires to work best- but would be interested to see Cav's setup for this track.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 12-09-2014, 12:32 PM   #9570
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Socket View Post
Instead of lap times that lack basic scientific method, can I just get pictures and numbers from a corner weight setup?
I'm now tempted to pickup 4 scales and see for myself, but I would like to see what changes the numbers show, and then run the setup that reflects the numbers I'm after.
The effect they are going for wont show up on corner scales. It's more of a polar moment of inertia type of thing.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
