    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 12-07-2014, 09:53 AM   #9526
Default Best Weight for 17.5 Stock Buggy
Tried running the buggy at approx 1500g but handled better at 1550. Weight diff was lighter battery. Set ride height per each battery weight. Would be interesting to hear what other 17.5 stock buggy drivers are weighed at.
Micah123 is offline   Reply With Quote
Old 12-07-2014, 10:16 AM   #9527
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
I have tried weight focused testing over several generations of buggies. There is always a compromise between a single super fast lap and driveability. My over all time and best average lap are always with a car 3-5 ounces over minimum weight. My best single lap time is always with an edgier feeling car that was at the lightest weight.
This is with shock spring and valving adjusted for weight changes and balance almost entirely unchanged.
There could be other factors, like tire insert changes to suit each weight as well, but I preferred to keep as much the same as possible.
The major grey area, imo, is a lighter car might like different roll centers and camber link lengths(RCM), since it would transfer less weight.
Lots of variables.
Biggest thing, I found, not hitting stuff.
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 12-07-2014, 01:56 PM   #9528
vito's Avatar
whats a good starting point for the shelle bull stud mount in the rear b 5 m?
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 12-07-2014, 03:50 PM   #9529
tc1
Trader Rating: 15 (100%+)
I run mine "up" position middle hole with no washers. If you like to mess with roll center a bunch run it down with two spacers. It is easier to add/remove spacers than to flip the mount.
Travis
tc1 is offline   Reply With Quote
Old 12-07-2014, 05:53 PM   #9530
Trader Rating: 25 (100%+)
To anyone with the Xfactory Chassis, I have the aluminum rear a-arm mounts and it doesn't sit flush inside the chassis... Has anyone come across this? I noticed this when I went to tighten the mount into the chassis and saw it flexing.
B5M - Hobbywing v3.1 Stock Spec, Team Scream 17.5, Team Scream Battery
B6 - Hobbywing v3.1 Stock Spec, Team Scream 17.5, Team Scream Battery
Ronisonce is offline   Reply With Quote
Old 12-07-2014, 06:48 PM   #9531
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
Ran the inline battery setup today and all i can say is wow... Didnt feel like a dog in mid and exit cornering anymore!! Rotates so quick. Knocked .5 second off my laptimes!! Buggy was unbelievably so easy to drive!! It fealt so much more better jumping also... Could tailwhip so easy and readjust mid air if you launched off position. What an unbelievable change of heart cause I kept on switching back to the rear motor car. So glad i stayed with it and found this setup!!! Thank you guys!!
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 12-07-2014, 07:16 PM   #9532
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
which inline setup? electronics or battery
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 12-07-2014, 07:25 PM   #9533
Battery
B5 NATION BABY!!
Old 12-07-2014, 07:28 PM   #9534
Still need to clean wiring up but this is how I ran it...
B5 NATION BABY!!
Old 12-07-2014, 07:51 PM   #9535
Zaxbys's Avatar
I don't have the chassis, but I follow the company and IIRC the first batch or two didn't have enough material removed for certain rear a-arm mounts. You should contact them and I'm sure they'll help you get this figured out.
Zaxbys is offline   Reply With Quote
Old 12-07-2014, 07:52 PM   #9536
Razathorn's Avatar
My setup from testing and tuning today. After moving to the shorty, my car felt great, but it was "too stood up" and rotated way too much in corners. It also lacked traction in general. After going to green rear springs for our track that can get pretty slippery, I played with the front and determined I really needed to go back to the gray springs as it was just not stable enough with the whites I as running previously from outdoor racing. That got it better, but it still felt like it had inconsistent rotation. It wasn't a traction thing, it was rotation under braking was not like it should be. I started playing with rear droop and went from 26.5 to 27.5 and that was the ticket.
Wayne
Official Team Associated RC10 B5m Mid-Motor Thread-rc10b5m_wayne_20141207.jpg
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 12-07-2014, 08:08 PM   #9537
I ran that setup with 1.5 fronts and 1.6 rears. White rear springs with grey front springs also...absolutely glued.
B5 NATION BABY!!
Old 12-07-2014, 08:38 PM   #9538
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
So I just picked up the Schelle Nova Slipper! I've noticed a lot of comments about stock pad set-up, but what are you guys running for mod?
I run on carpet and high grip clay- so would white-red-red be good? Or would it put down too much power from my 7.5?
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 12-07-2014, 08:50 PM   #9539
raceguy13's Avatar
Originally Posted by Chris Gierse View Post
Has anybody tried the Associated titanium screws yet? Was wondering how the quality compares to Lunsford.
The Lunsford screws are grade 5 made in the usa with ti made in the usa, others are grade 2. I would prefer a grade 5 over grade 2 any day!
raceguy13 is offline   Reply With Quote
Old 12-07-2014, 08:52 PM   #9540
Trader Rating: 29 (100%+)
White red white
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
