Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#9424
@ the track
Just installed the new Ae alloy hubs...(black)
Number's facing same side as shocks.
middle of arm
Camber location is inside hole
using 3mm spacing under stud & 4mm spacing under alloy chassis camber stud
middle of arm
#9426
Check out the relation to the lower shock mount and pivot points of lower arm. Also check out tower mounting bolts vs upper shock mounts.
#9427
Ebay. I just bought both today $7 each
#9429
WINGS WINGS WINGS
Ive been watching on the wing debate. I Took a pair of 4-40 Scoket head screws(I think 1/2 in) Ground off the nubs on the wing mount, drilled a 2.5mm hole, ran the socket head screws up from the bottom. Then used a standard set of thumb screws, which seat perfectly snug in the holes and prevents the wing from moving. And provides a easy on/off installation of the wing.
Hope this helps.
Hope this helps.
#9431
Ya, I could see that, But it's a toss up between that and the wing shifting. I just happened to choose the higher profile because I would rather have a stabler wing. If I was on a constant high speed track, then it may bother me. If I ever need lower profile, Ill put on a new wing and drill smaller holes.
#9433
So, after trying to get out of the hobby I am pulled back in and have a B5M on the way. I just wanted to make sure all my basis are covered after reading through so many pages of this thread. As of now I am not going to do the little things that I see the more vet people doing (cutting and what not). I plan on racing this in stock and as of now my driving skills are still whats slowing me down. So here is what I got for the B5M.
Lunsford Ti Turnbuckle
B5 Front Shock Tower and Arms
Any other things I am missing?
#9434
#9435
