    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 11-19-2014, 07:17 PM   #9196
Nat Maniac's Avatar
Originally Posted by 3D-Seth View Post
This brings up another thought; try binding the car to the 4wd slot on your radio. I have seen issues with different model memory's in radios and the bug follows that model memory...just another thing to try and eliminate.
Good idea!
Ive just had someone from my local track suggest the same thing. It hadnt occurred to me to try binding on the same channel as my b44 because that would mean the radio is junk and its a brand new Futaba 4PX so I wasnt expecting it to have any issues.
I really hope its a simple as that because ive got a long list of trouble shooting tasks to get through tonight!
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 11-19-2014, 08:43 PM   #9197
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
Did it work? Has to be a faulty memory or channel
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 11-20-2014, 05:05 AM   #9198
Default what fun
Well I entered my first race last night in 22 years. Ran it in a oval class and a off road. I am novice in every sense of the word. There was the normal small turnout on Wed. There where 3 of us in oval, I placed 3rd. Was getting faster every every lap, if I slow down. Had some issue on both heats and the main on offroad. Came home with a running car though. My goal for next week is to finish an offroad heat. Glad I am back!
mackelby is offline   Reply With Quote
Old 11-20-2014, 05:10 AM   #9199
I am running Marcus's 2 stage pistons at the moment. I put those in before it ever moved under it own power. Don't ask me why? Like I would know the difference. The slipper, is it good for mod motors. Running a Tekin 9.5 which by the way to powerful for my driving prowess. My hobby shop had the Avid brg in stock, picked them up on the way to race last night.
Originally Posted by Wildcat1971 View Post
The machined pistons are nice. i like the 1.5x1.1's in the front with machined 1.6s in the rear. Also, the Avid Evo slipper is the BOMB. If you dont have one, I highly recommend it. If you order hits $40, I think shipping is free. Unless you order something big like a chassis or body. The Avid 2.2 wheels are pretty stiff also and hold up much better than most.
Old 11-20-2014, 05:30 AM   #9200
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
yeah, I trie the stock skipper and the AE 2 disk and didnt like either. tHE aVID evo IS BETTER IN BOTH STOCK AND MOD. caps lock
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-20-2014, 05:30 AM   #9201
yeah, I tried the stock skipper and the AE 2 disk and didnt like either. tHE aVID evo IS BETTER IN BOTH STOCK AND MOD. caps lock
Old 11-20-2014, 07:41 AM   #9202
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Dang....Caps Lock and double post...That's how you know Wildcat means business
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 11-20-2014, 07:50 AM   #9203
Oh yeah Wildcat, using Marcus's Garodisk also. Once again I put those on before ever running stock goods.
Old 11-20-2014, 08:52 AM   #9204
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Default Exotek B5 Flite motor plate & rear ballstud mount
Exotek have two new aluminium option parts for the Team Associated B5 and B5M buggy available in the form of the vented Flite motor plate and an aluminium rear ballstud mount for the B5M mid motor buggy. Starting with the motor plate, the CNC-machined part sports aggressive machining to make the part not only 6.5g lighter than the stock motor plate but to also improve motor and slipper heat dissipation. The critical motor mounting area was left out with machining to maintain a solid base for motor mounting and gear mesh adjusting. The part, that is available in blue and black colour, is designed for the use on indoor clay and carpet environments but a shaved bottom allows for debris discharge if needed.
The second new part is the rear ballstud mount for the mid motor B5M. Machined down to 6 grams to minimise weight but made with 7075 alloy to increase the strength over the stock piece, the 2-sided design has the stock roll centre height on one side and a -2mm roll centre setting on the other side by simply flipping the part 180 degrees. The mount comes in black or blue colour, polished and laser-etched.
RCBuddha is offline   Reply With Quote
Old 11-20-2014, 09:21 AM   #9205
Mason's Avatar
Nat Maniac, other oddly things to check are throttle channel reversing before you calibrate esc. Straws..
oh one other thing - is there some sort of anti lock braking setup you have/have not done?
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 11-20-2014, 10:15 AM   #9206
Trader Rating: 20 (100%+)
Hi all I plan to run a b5m with a tekin rs and a trackstar 17.5 motor at my local indoor clay track just for practice and for fun, what pinion and spur would you recommend? any input would be great. If the car is too slow I was planning to go to an 8.5 or a 9.5.
I am not new to the hobby and been in it for a long time so I can handle the power of the hotter motors. must wondering about gearing if I also go:
9.5 or 8.5 motors. what mod motor would you recommend? I was just going to buy a trackstar versions of those since they are priced right! I would probably have to get the x car 120 amp esc to go along with the mod motor since the tekin RS I think only supports down to a 13.5.
any input would be appreciated.
Nissanguy8 is offline   Reply With Quote
Old 11-20-2014, 10:55 AM   #9207
heinen81's Avatar
I have the 72 spur and settled on a 33 pinion, in blinky with 15* motor timing. Seems to be the right balance between torque/speed for the Speed Passion Reventon R and 17.5 MMM motor.
Motor temp is 135* after 7 minutes. I would start around a 32 pinion and you'll probably settle between there and 35.
-Speed Passion- Team Associated B5M; SP PRO 1.1 & 17.5 FANTOM TEAM HT
-Speed Passion- Team Associated B44.3; SP Reventon PRO 1.1 & 7.5 v3.0/13.5 MMM
heinen81 is offline   Reply With Quote
Old 11-20-2014, 11:17 AM   #9208
thebombster's Avatar
Just get the trackstsr 120a turbo esc and a trackstar 8.5 motor and if your using a spur that comes with the kit run a 23/81
thebombster is offline   Reply With Quote
Old 11-20-2014, 11:26 AM   #9209
Trader Rating: 123 (100%+)
Does anybody know the weight difference between the Factory Team aluminum rear hubs and the stock hubs?
Chris Gierse is online now   Reply With Quote
Old 11-20-2014, 12:24 PM   #9210
thanks for the input guys!
I was told the x car 120 amp esc is better than the trackstar turbo 120 amp unit, does anyone had any experience with either?
