    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 11-11-2014, 05:21 PM   #9031
anyone heard dates on the 3 gear transmission yet?
scythe23 is offline   Reply With Quote
Old 11-11-2014, 08:14 PM   #9032
i heard like nov 14th
-Team Xray-Speed Passion-AKA Racing-Sweep Racing-
QuadCamd is offline   Reply With Quote
Old 11-11-2014, 08:58 PM   #9033
Originally Posted by heinen81 View Post
^ ^ True. My bad, sorry everyone. I try to help anyone who may be looking for help, regardless if it seems obvious or not. I understand testing is the obvious way to determine what works, however with a limited schedule, I wanted to make sure I was at least starting on the right path to keep from wasting time on race day.
I hear you on limited time. I try to get to the track as early as possible and do my testing before quals start.
Also definitely reccomend the AE app. RC Cheat Sheets app. Will help give you a guide of what tuning to try under limited timeframes.
robbie_gtc is offline   Reply With Quote
Old 11-11-2014, 09:04 PM   #9034
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Anybody running the xfactory carbon fiber chassis? Looking for any feedback
pink_sleeve is offline   Reply With Quote
Old 11-11-2014, 10:48 PM   #9035
I've had mine for awhile now but have only ran it a number of times. I'm just starting to test some things and possibly fine tune it. I just have a hard time leaving my stock M for some reason. I did however race it last week and was pretty happy with it.
daveb is offline   Reply With Quote
Old 11-12-2014, 02:58 AM   #9036
slashdad's Avatar
Trader Rating: 33 (100%+)
Gents.
Just bought myself a kit to build. Looking for any tips you gents have gleaned in the last 603 pages and counting on RCTech for the B5M build. Going to run the car on medium traction clay dirt outdoors. 8.5turn motor. ANY SUGGESTIONS and TIPS on the build would be much appreciated. Thank you in advance.
B5M, T5M, B44.2, B4.2, DEX210v2, SC10B, Xray T3 2012.
Savox : Spektrum : Proline : JConcepts : Turnigy : Trackstar Gen II's
Knox OFF Road RCC member, waiting for toddler to grow up...
Please explain roll centres to me one more time...
slashdad is offline   Reply With Quote
Old 11-12-2014, 03:29 AM   #9037
Trader Rating: 89 (100%+)
Slash dad.... First page is your Friend. It has all you need! Good luck!
dan-o is offline   Reply With Quote
Old 11-12-2014, 04:24 AM   #9038
slashdad's Avatar
Yes it is! Thanks to all for the distillation of all the knowledge on this car.
Got me some research to do.
Old 11-12-2014, 07:40 AM   #9039
heinen81's Avatar
Slash dad, I would recommend addressing the ball cup issue during the initial build. Chuck the ball studs in a cordless and spin them in some scotch brite and make sure they are free. Also when building turnbuckles, I used a drill to run the turnbuckles into the ball cups and then backed them out. Seems to make adjustments easier without ball cups popping off. Remember ball dif adjustment screw should be opposite the motor plate. Also if you are not using front clamp hexes and axles, use a dab of remove able loctite on the screw on the backside of the front axles... They like to back out.
-Speed Passion- Team Associated B5M; SP PRO 1.1 & 17.5 FANTOM TEAM HT
-Speed Passion- Team Associated B44.3; SP Reventon PRO 1.1 & 7.5 v3.0/13.5 MMM
heinen81 is offline   Reply With Quote
Old 11-12-2014, 07:52 AM   #9040
Mason's Avatar
Build slowly. Think about what you are doing, how things are suppose to go together and how they are suppose to act. Do not just slap it together. Don't RTR it.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 11-12-2014, 11:35 AM   #9041
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Slash dad, I would recommend addressing the ball cup issue during the initial build. Chuck the ball studs in a cordless and spin them in some scotch brite and make sure they are free..
Not necessarily necessary. You can check to make sure they are free before doing anything with a drill or scotch brite. My build had 0 issues with any ballcups or ballstuds.
Only worry about this if your ballcups cause binding on your ball studs.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-12-2014, 01:05 PM   #9042
mxnickj's Avatar
Trader Rating: 51 (100%+)
Yea, I second this. I built my kit and never "prepped" the ballstuds at all and have had zero issues so far (knock on wood)
mxnickj is offline   Reply With Quote
Old 11-12-2014, 01:23 PM   #9043
heinen81's Avatar
True.
You guys are lucky, I didn't have one arm that fell under its own weight. They were way too tight on mine. Anyone ever here of this pinch method? I can't see how pinching the cups would be the way to fix it... But maybe?
Old 11-12-2014, 01:25 PM   #9044
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
True.
The pinch method works pretty good. but you have to do ti correctly, there was a video posted.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-12-2014, 01:31 PM   #9045
Trader Rating: 18 (100%+)
Pinching worked great for me!
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
