    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 11-07-2014, 08:14 AM   #8971
SnotRkt's Avatar
Aluminum arms!?!!? What are we racing these with T-Maxx's now?
AE RC10B6, TD DEST210R
SnotRkt is offline   Reply With Quote
Old 11-07-2014, 08:19 AM   #8972
LMAO !!!
sbuck10 is offline   Reply With Quote
Old 11-07-2014, 08:38 AM   #8973
heinen81's Avatar
lol! allot of it looks cool, but I cant image what else would all snap with aluminum towers, arms and wing mounts. But if you're into customizing, sweet. nothing i would want to compete with though.
-Speed Passion- Team Associated B5M; SP PRO 1.1 & 17.5 FANTOM TEAM HT
-Speed Passion- Team Associated B44.3; SP Reventon PRO 1.1 & 7.5 v3.0/13.5 MMM
heinen81 is offline   Reply With Quote
Old 11-07-2014, 09:10 AM   #8974
Trader Rating: 14 (100%+)
I actually have the aluminum wing mount (Exotic) Its fine. did manage to crack the new proline indestructo wing though.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 11-07-2014, 09:11 AM   #8975
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I really wish AE would release molder screw on wing mounts. I dont like adding aluminum up that high
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-07-2014, 09:33 AM   #8976
Jim Hustins's Avatar
Just use these http://prolineracing.com/performance...umbwasher-kit/
Cut the plastic nubs where the body clips go thru. Drill a hole just a little smaller than the set screw in the center of where the nub was. Install the set screw and oring and remount your wing. Easy mod.
I owe it all to Papa Lou.
Team Driver: Pro-Line, Maclan Racing, Xpert Servos, RC Soup, MIP, ARC
http://www.prolineracing.com/blog/team/jim-hustins/
http://www.youtube.com/user/jjlove1217?feature=mhee
https://www.facebook.com/jim.hustins.rc.racer
Jim Hustins is offline   Reply With Quote
Old 11-07-2014, 09:38 AM   #8977
On my B44.2
Old 11-07-2014, 09:53 AM   #8978
Trader Rating: 18 (100%+)
I just cut the nipples off then drilled holes for a 4MM screw. Only had too replace one because I overtightened the screw...
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 11-07-2014, 10:32 AM   #8979
Anyone know anything about this charger?
http://www.teamorion.com/advantage-t...n-2.html?sl=EN
millsj2 is offline   Reply With Quote
Old 11-07-2014, 11:48 AM   #8980
samnelso's Avatar
this thread should help you out
Team Orion Advantage Touch charger
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 11-07-2014, 12:12 PM   #8981
Jmuck69's Avatar
I like the wing mounts that use the simple body clips to attach the wing...oh wait, it comes with that.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-07-2014, 03:27 PM   #8982
anyone tried bladder build shocks on their cars?
mackelby is offline   Reply With Quote
Old 11-08-2014, 08:41 AM   #8983
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Jim Hustins View Post
On my B44.2
Those giant knobs look hideous..IMO
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 11-08-2014, 09:35 AM   #8984
TonyWest's Avatar
Trader Rating: 50 (100%+)
Default Thanks for the info on the slick track guys
I am currently running the rear motor front end and rear end pretty close to the setup that was run at the Nats. I am going to try the brass blocks I was also considering cutting out some of the chassis braces. Has anyone had any luck with that.
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 11-08-2014, 02:41 PM   #8985
MikeXray's Avatar
Trader Rating: 73 (100%+)
I ran my converted 5M for the first time last night and it was good right from the start. I built wit the 5R F arms and tower, and rear arms with the hubs all the way back. I also had both brass rear blocks, and went back and forth with shorty/square pack. I tq'd and won 17.5, but a few of the regular fast guys weren't there, and they can run as much as .5ths faster than I was able too, so I need to get some more steering.
What are the wheelbase settings for the 5R and 5M arms, I know the R can produce a shorter wb, but how much 1 or 2 mm?
I need to work on a bit more mid corner steering without loosing too much rear bite.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
