    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 10-26-2014, 05:04 PM   #8746
Gpeters66's Avatar
There is one at the track I race at. Looks really good. Problem: the car comes in underweight. My pit buddy drove it and he said it is much more forgiving than his stock B5m. My 2 cents.
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 10-26-2014, 05:41 PM   #8747
Default measuring ride height
Where do you take that measurement from? With the gullwing it is difficult to see flat and level.
mackelby is offline   Reply With Quote
Old 10-26-2014, 08:40 PM   #8748
Originally Posted by kwiksi View Post
Dialed
Am I the only one that is shocked that we have not seen a replacement to the crappy plastic trailing insert that we have to glue in and HOPE the bearings match up correctly when done?
AlmostIllegal is offline   Reply With Quote
Old 10-26-2014, 09:34 PM   #8749
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Make a horizontal line between the inner and outer hingepins if looking for a true "arms level" setting with them
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 10-26-2014, 09:50 PM   #8750
3srcracing's Avatar
Trader Rating: 25 (100%+)
Anyone had problems with bent hinge pins?
Was rebuilding my car, and noticed that my rear hinge pins (the one is very very slightly bent) but the other is diffidently bent. Same with shock shaft (opposite side)... Little irritated but guess it's my own fault.
3srcracing is offline   Reply With Quote
Old 10-27-2014, 04:10 AM   #8751
TomErickson's Avatar
You could say that it is. This car is really tough. I was making mistakes all over the place this past Saturday and bent a rear axle. Our track has two big jumps that can spell trouble for small buggies. One of them a big triple with a sweeper just before it so the car is often flying a little off camber. I have landed that one on the side wall of the rear rim.
I am running the hard arms have had no issues so far. Love this car!! Just need to get the chassis set-up right for the track.
---Thanks to my Sponsors: Novak R/C, and Nankin Hobbies ----
TomErickson is offline   Reply With Quote
Old 10-27-2014, 06:38 AM   #8752
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Those of you running low profile bullets, do you run 14 or 18mm length? Also, I know tight fitment is a good thing but what about too tight. My negative bullet if pressed fully in requires pliers to pull out and I'm not keen on yanking by the wire
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 10-27-2014, 06:52 AM   #8753
Jeepy2013's Avatar
Trader Rating: 78 (100%+)
I ran mine unglued, bearings were crunchy feeling after first day of racing. I glued the inserts (per recommendation from AE) and now after four more race days (since gluing) the bearings still feel like new. So unless something is worn out, gluing them in is just fine, I had no problem with the bearings not lining up when done.
If I need to make a axle trailing change in the front, I bought a spare set of steering blocks with inserts for a whopping $7
Jeepy2013 is offline   Reply With Quote
Old 10-27-2014, 07:28 AM   #8754
Vinny Cancilla's Avatar
Just picked up a used B5M. What gearing are you guys running for a 9.5t motor. Also, what is the best body for the b5m. I'd prefer a more forgiving or easier to drive car, over an aggressive ride. Thanks guys.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 10-27-2014, 07:35 AM   #8755
Trader Rating: 18 (100%+)
I'm running 28/78 with my Speed Passion 9.5T. Comes off around 130-140*
iTz Nicholas72 is offline   Reply With Quote
Old 10-27-2014, 07:44 AM   #8756
I have the speed passion also, I think I was running 23/76. I was going to start with 24 with the b5m. I have a 28 to try, it just sounds like it might be to much.
Serpent Srx8
Old 10-27-2014, 08:04 AM   #8757
MikeXray's Avatar
Trader Rating: 73 (100%+)
Did you get hit from behind hard? I saw a friends car get the shock shaft bent and tower tweaked this way (tower was fine after changing the screws).
Converting my R to M this week..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-27-2014, 08:36 AM   #8758
I need a new body for my buggy, what do you guys recommend?
Socal Stangman is offline   Reply With Quote
Old 10-27-2014, 09:09 AM   #8759
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
On the contrary, when building this car, one of the first things that came to mind was how robust the hingepins are. If you are bending hingepins and shock shafts... im guessing there is an abuse issue with the car.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-27-2014, 09:14 AM   #8760
Me too!
Serpent Srx8
