    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 10-24-2014, 09:57 AM   #8716
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Cameron Kellogg View Post
I removed the 1mm nub off the bell cranks between the rack and bell crank. Basically moving the rack up 1mm. Seem to do the same thing just do not over tighten the screws. I run on carpet off-road with non moving track dividers. Cutting more off the steering block seemed like it would create a break point for me.
that is my exact plan... work out getting the steering rack moved up 1mm instead of removing material from the steering block.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-24-2014, 09:58 AM   #8717
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
All depends on type of track and surface... I run high bite clay so usually have the smaller pad in back and larger in front... If im running on low bite ill put all the way to back position
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 10-24-2014, 10:12 AM   #8718
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Originally Posted by williamsfw2427 View Post
What would be the best battery to run in this buggy? A shorty or a square pack? I'm trying to gather up all the parts needed to complete the kit the misses bought me for Christmas.... To me it looks like both are used in this buggy but I could be way wrong... and I just dont know...
thanks
The 2 different batteries serve 2 different purposes.
If you're running 17.5, then most go with shorty packs for weight concerns.
With mod buggy, the weight of a square/saddle pack can help keep with traction when putting more power down.
You could also just run the shorty with weight placed where you want it too.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 10-24-2014, 10:19 AM   #8719
Thats exactly what i do.... Outdoor season i still run shortys with the brass mounts for better traction
B5 NATION BABY!!
Old 10-24-2014, 12:52 PM   #8720
Nat Maniac's Avatar
Can anyone confirm if the rear sway bar meant to be slightly loose across the back section? After installing with grubs and screws it's still got a significant amount of play compared to the b4.2 and b44.2 which has none whatsoever.
Also is there an optimal length for the turnbuckle?
Seems odd it comes with no instructions...
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 10-24-2014, 12:53 PM   #8721
TomErickson's Avatar
I have always liked Hot Racing parts. They look great and I may get a few of these upgrades for my B5M.
What I want to know is why are the various aftermarket parts guys making mostly copies of the stock parts. The rear hubs have carbon tabs that require the use of the stock inserts. Please make flat tabs like the B4.2/B44 use or change the design of the ball stud. The inserts are not as durable. That goes for the steering knucke too. Could you make 2,3, and 4 degree parts that don't use the inserts? That would eliminate the play that is bound to happen over time.
---Thanks to my Sponsors: Novak R/C, and Nankin Hobbies ----
TomErickson is offline   Reply With Quote
Old 10-24-2014, 02:49 PM   #8722
shannow's Avatar
Indeed I have the kit as well but it's very much "deal with it"...
Can't help you much with the length I made it so that it's just 1/4" over the turnbuckles so about 1inch1/2 center to center if it can help.
When you screw the grub screws in the plastic "retainer" you must push it slightly so that it taps (or rather screws itself) a little bit in the shock tower otherwise it just pushes the retainer and doesn't close the gap between the grub and the bar.
shannow is offline   Reply With Quote
Old 10-24-2014, 04:40 PM   #8723
Nat Maniac's Avatar
Thanks. I've done exactly the same. I know what you mean about having to press in the retainer. .
Seems like quite a bit of effort has gone into the design when a simple screw and washer would be more effective. The mind boggles. Would be interesting to hear from the engineers on this one.
Old 10-24-2014, 07:01 PM   #8724
Question guys... When turning your rear tires freely should both tires spin in the same direction or opposite. Trying to figure out how tight my diff needs to be...
B5 NATION BABY!!
Old 10-24-2014, 07:13 PM   #8725
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
That is a hard way to check it. They should turn opposite directions but it depends on the motor you are running an the magnet bump it has. (If it can hold the spur gear) normal setting is as per the kit instructions and should get the diff tight enough to not slip.
Cameron Kellogg is offline   Reply With Quote
Old 10-24-2014, 07:17 PM   #8726
Running 17.5 reedy. When i spin the tires the both spin the same way. On my mod buggy with a 10.5 they spin in opposite directions. I have both diffs pretty tight. Was just wondering why one spun the same and other was different
B5 NATION BABY!!
Old 10-24-2014, 07:34 PM   #8727
Motor rotor magnet and gearing is causing it. Not to worry either way.
Old 10-24-2014, 07:59 PM   #8728
MikeXray's Avatar
Trader Rating: 73 (100%+)
If you hold the spur, they should spin in opposite directions, but the 17.5 doesn't have enough "cog" so it spins before the diff.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-24-2014, 08:53 PM   #8729
williamsfw2427's Avatar
Send a message via Yahoo to williamsfw2427
Thanks for all the info
B4.1, B5M, SCX10, RC8T, Bomer RR10, TA 06, TT-01E, SC10, SCT410
williamsfw2427 is offline   Reply With Quote
Old 10-24-2014, 09:25 PM   #8730
My reedy 17.5 spins tires in opposite direction when checking diff...sounds like there's more to it than that. ..
nordfink is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
3n90t
