Team Associated RC10 B5m Mid-Motor Thread
#8596
For those of you using Lunsford turnbuckles are you using the new ones for the B5 or older ones for a B4? The new ones for a B5 almost seem to short. I'm sure they are much easier to adjust but just don't want them loosening up on their own.
#8598
Sounds good. The Jconcept turnbuckles seem too long to me too. So I guess the Lunsford is the best option.
#8604
I had mentioned before that it was taking twice as much preload on one rear rear shock verses the other to get "bones level". One of the shocks has lots of resistance once the shock is assembled and before oil goes in. I have taken it apart and put back together many times, I am not fixing it. My 15 year old dremel no longer works. Guess I will polish shafts first. I don't have much support equipment. Ordered 2.5 wench instead of 2.0. Using the L wrenches with arthritis is no fun. Broke off neg. wire from bat to ESC. Can't even try to make Hotwire work. Did I mention I don't have much support equipment.
Thanks for reading my
I feel a little bit better.
#8605
because if you want to go lower now you have to flip your arm mount around when adding / removing washers is much easier.
#8608
First time building a 10th and ball diff for that matter, just installed the rear and notice that the t nut is preventing the left arm from moving up. I compressed the spring a bit before building and ball diff feels smooth.
Do I need to just tighten the t nut more to get the movement and make the ball diff tighter?
#8609
