    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 10-16-2014, 06:18 PM   #8506
Big Features's Avatar
Originally Posted by Wildcat1971 View Post
the 410 will be can do 7v on the bec also. the 410 might be the new end all. It is made by skyrc and is based on the toro with obvious changes
What!? Not sure about the link between SkyRC and REEDY, but they are all made in China to some specification or another. What matters are the FETs, Boards, and software. That makes the REEDY unique.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 10-16-2014, 06:28 PM   #8507
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
Tekin and orion for me.... Im all tekin cause i got great deals but thought the orions were alot smoother all the way around. Thinking about switching back!! What sold me on tekin was thier customer service!! A++++
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 10-16-2014, 07:23 PM   #8508
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Mike
yep all true. the firmware features will probably be the same though. I said there were differences, lol. solder posts in the back and i am sure Reedy used better than avg parts.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-16-2014, 08:09 PM   #8509
3srcracing's Avatar
Trader Rating: 25 (100%+)
If I wanted more on power steering but didn't really want to change the off power steering, what would you guys suggest doing?
3srcracing is offline   Reply With Quote
Old 10-16-2014, 09:11 PM   #8510
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
A little more anti-squat
A little less front droop
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-16-2014, 09:31 PM   #8511
Another rumour or do you have proof its based on those? Don't just state because the casing looks the same either please. Means nothing about the internals.
robbie_gtc is offline   Reply With Quote
Old 10-16-2014, 09:55 PM   #8512
3srcracing's Avatar
So I'm currently running:
3+1
And 2 mm spacers in the front shocks.
What would you guys suggest changing?
If I changed anti squat I would have to go back to the plastic toe blocks cause my track doesn't have the arm mount inserts.
Old 10-16-2014, 09:59 PM   #8513
Inside source. dont worry about it. Does not matter who makes it, just how it performs.
Old 10-16-2014, 10:04 PM   #8514
Super Moderator
3+1
You could also move your rear hubs back for a slightly longer wheel base...
- RCSpecialties -
Old 10-16-2014, 11:09 PM   #8515
kdub's Avatar
Originally Posted by dominick i. View Post
i ran my b5m last saturday on a real tacky/slick tire surface and the car had a vicious push...i had the kurt wegner setup on the car and a 7.5 mtr.....
any suggestions?
To get more steering I have done a few things, moved hubs back with RM arms, and then you can lower the rear inner link to flipped with 1mm. Usually on the front you can go to axle up to get more front grip. Hope this helps!
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 10-17-2014, 04:38 AM   #8516
Originally Posted by Millsy97 View Post
Thanks, I had a look at it. Can anyone else shed anymore information about it???
What else do you want to know about it?
AlmostIllegal is offline   Reply With Quote
Old 10-17-2014, 07:48 AM   #8517
Default ideas please
Trying to set ride height. When i get it right one shock spring adjuster is twice as low as the other. What should I be looking for to remedy this problem?
mackelby is offline   Reply With Quote
Old 10-17-2014, 07:49 AM   #8518
do you have the correct spring cups on?
Old 10-17-2014, 08:56 AM   #8519
Super Moderator
One shock collar is TWICE as low as the other? Has to be either mismatched spring cups, or mismatched springs.
- RCSpecialties -
Old 10-17-2014, 09:18 AM   #8520
I agree, Cup or spring is wrong. Should be easy to find once you strip them down and compare parts.
FWIW, I am loving my inline setup. One of the really fast guys in Expert stock at my local track is running a 15.4 best lap. My best lap was a 15.7 and he is a MUCH better driver than I am. So for me, this setup is working well.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
