    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 10-09-2014, 08:04 PM   #8356
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I use a battery strap. Works just fine. Schelle FTW.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-09-2014, 08:17 PM   #8357
3srcracing's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Skeeter36 View Post
I would be curious to know what hartson uses to get his to stay? Anyone know for sure? We can all speculate!
Mine stays just fine, unless I do my motor wires really short, then it pulls off when I take out the battery. Just clean the chassis with motor spray, and on the esc, then let it dry. Then just put the 3M sticky tape on.
Then if you want it to stick even better heat up the sticky tape. This time around I ran my motor wires long and I haven't had one issue.
3srcracing is offline   Reply With Quote
Old 10-09-2014, 09:37 PM   #8358
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I use 3m clear tape. clean both surfaces with alcohol. And if it is chilly, I will warm both surfaces with a heat gun
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-10-2014, 02:28 AM   #8359
Trader Rating: 23 (100%+)
Use shoe goo to keep your electronics securely to the chassis. It's strong, don't have to worry about the electronics coming loose, and easily removable.
bmcallister is offline   Reply With Quote
Old 10-10-2014, 08:25 AM   #8360
Default Almost!
Getting very close to having my b5m built. Glued up some tires yesterday, one front tire spins like it has a shotgun shell in it. Got a big pump knot in it. Using the AKA red closed cell inserts. I may have got some of the side wall glued down also. Are they ruined? Hate that little flexible tube that comes with the AKA tire glue. Had to use a hypodermic needle to apply. The push on needles work well. Use a little glue to hold the needle in place. I kept knocking it off by squeezing bottle to hard. Might need to go to 19 gauge. Is tire ruined? Please tell me it can be saved!
mackelby is offline   Reply With Quote
Old 10-10-2014, 09:57 AM   #8361
Send a message via ICQ to JiuHaWong
From MIP's Facebook page:
MIP B5M Three gear transmission had a flawless outing as it won it's first club race in preperation for this year's JC Nationals! Rudy Rico piloted the B5M commenting that the car had much more acceleration and felt as if driving a rear motor with the same launch but none of the ill effects of having a ballast weight to deal with and all the benefits of a mid motor vehicle. Definitely the best of both Worlds. Looking forward to this weekend.
And for all the guys asking about the weight differential is about 8 grams (tad more than one of the square weights we use).
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 10-10-2014, 10:51 AM   #8362
Guess I will be heading back to the LHS, 90 mile round trip.
Old 10-10-2014, 11:15 AM   #8363
What are these offset shoulder bushings?
Anyways, back on topic. Can't wait for the offset shoulder bushings to come in..[/QUOTE]
Old 10-10-2014, 11:19 AM   #8364
So what "inline" setup is the one to use? I only know of the Hartson one he used at TRCR or Wild Cherry's? I'm thinking of WC's just because I can use my battery strap.
daveb is offline   Reply With Quote
Old 10-10-2014, 07:41 PM   #8365
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Need some ESC advice - background is all tekin 8th scale. Been looking at the rs gen2, the hobbywing v3.1 and the orion vortex r10 (do guys run the 120 or 160 version?)
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 10-10-2014, 07:44 PM   #8366
lbckevin's Avatar
Trader Rating: 89 (99%+)
The Hobbywing has been flawless for me.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-10-2014, 08:11 PM   #8367
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Hobbywing all they way...
I have been running the Hobbywing V3.1 for over a year now and been very happy with them.
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 10-10-2014, 08:31 PM   #8368
ironzgti35's Avatar
I see you are sponsored and understand where your coming from, but did you test others other before hand? I assume using the hobbywing motors too?
Old 10-10-2014, 09:20 PM   #8369
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
I personally run the R10 and have had no complaints. It has a great feel to it. I have never owned, but have run a friends car with a rs gen2 and it just didn't feel as nice- as others have stated- kind of like driving an on/off switch. As far as the R10 goes the 160amp version is the full racing version, 120amp being more for stock/super stock. They do have a newer R10.1 that I believe is 180amp.. just fyi
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 10-11-2014, 03:40 AM   #8370
Trader Rating: 29 (100%+)
[/QUOTE]
The offset bushings raise and lower the spindle height to give more or less steering in certain spots in the corner. I was just curious if anyone running med to high indoor clay had tried them. As far as your tire I would sauce em to soften them up and if it's still way bad I would cut tire fix foam and 're glue.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
