    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 10-08-2014, 03:45 PM   #8341
Originally Posted by Cpt.America View Post
This is a tiny adjustment to the overall leverage the arm has against the shock. Just start in the middle.
Here is what I ran in 17.5 this last weekend at the gold cup
Front Shock:
Carbon Flat RM arms
Stock MM tower
Middle hole tower mount
Outer hole arm mount
White Spring
Stock Piston
37.5 Oil
4mm Shock limiters (this is because I am running the MM tower, which would create too much droop without the extra limiters. the stroke listed below is key)
18mm stroke
23.5mm ride height
Rear
Stock everything, tower/arms/piston with 32.5 oil
Inner hole arm mount
~26mm stroke (taken from Luke Smith's setup.. i don't recall mine off hand)
23mm ride height
What spring cups are you using?
sealander is offline   Reply With Quote
Old 10-08-2014, 09:24 PM   #8342
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Some B5m / pitspot pron from the gold cup. Lots of blue in my pit!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-08-2014, 10:32 PM   #8343
TOO-TALL's Avatar
Very clean......where did you get the pit light?
TOO-TALL is offline   Reply With Quote
Old 10-08-2014, 11:12 PM   #8344
Trader Rating: 29 (100%+)
Has anyone tried the offset gold caster block bushings?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 10-08-2014, 11:34 PM   #8345
Cridd's Avatar
Trader Rating: 16 (100%+)
I have heard some are for more steering. I have a set not yet tested though.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 10-09-2014, 07:28 AM   #8346
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default This car is amazing!
I have been stuck on my RM car because our two local track are somewhat medium to low traction and tight indoor tracks. My RM car has been rock sold at these two locations, but I had been wanting to build up a MM car to see how well it worked in these conditions.
I hit the track with it for the first time last night and am completely blown away! The MM car did everything better than the RM car did hands down! I struggled with my Centro in these conditions but the B5M is the money!
Current Mod Setup:
Box Stock Setup Other Than These Changes:
Brass C & D Blocks
1.6 Rear Piston with 27.5 Rear Shock Oil
RM Rear Arms
Shorty pack thick pad in front, thin pads in back
Schelle Slipper
Schelle Rear Camber Block
FT Front Pin Brace
I actually need just a little more mid and exit steering on the tight corners but don't want to give up any rear traction. Any suggestions?
I was going to try running 3mm or 2mm trailing on front steering blocks to make front end just a tad more aggressive.
May be parking the RM for good...
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 10-09-2014, 07:29 AM   #8347
Guys that are running an "inline" setup, are referring to the ESC, and shorty battery, being run down the middle of the car. Drivers will cut out the inner webbing of the rear waterfall AND the chassis pod, so they can literally tuck their ESC inside the waterfall almost up against the motor. Then the shorty battery sits directly in front of the ESC lengthwise.
If you are looking for slightly more rear-tire weight bias, you can run your setup like I do... which is the shorty run horizontally in the back up against the waterfall, and then the ESC dead center right up against the battery. This requires you cut away the section of the chassis pod in-between the battery posts.
If you want a little more weight forward, you can run the battery horizontal against the waterfall, and then run your esc and reciever forward of the battery posts. Or you can even run the battery slightly more forward.
Static weight bias balance is a great tuning aid.
Any chance of seeing your setup? lol
JHKracing is offline   Reply With Quote
Old 10-09-2014, 11:08 AM   #8348
Krio's Avatar
Trader Rating: 150 (99%+)
Try going back to the plastic D block or the aluminum one. Helps the car rotate just a smidgen more.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 10-09-2014, 03:06 PM   #8349
Super Moderator
Lets keep the discussion to the B5m please. No need to give users a hard time.
- RCSpecialties -
Old 10-09-2014, 03:45 PM   #8350
TOO-TALL's Avatar
So is the inline set up more for or stock(17.5) or a mod setup
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
Old 10-09-2014, 05:38 PM   #8351
ridgerunner1's Avatar
Trader Rating: 21 (100%+)
At our track the in line is run mostly by the 17.5 stock racers but there are a
few running in mod also and it works very well in both, the in line setup
works very well on a high bit track such as ours.
Mike Craig
A&E B5M - Viper ESC
New Home Track Tacoma TRCR http://www.tacomarc.com
RIP Beremerton RC race way
ridgerunner1 is offline   Reply With Quote
Old 10-09-2014, 07:04 PM   #8352
3srcracing's Avatar
Trader Rating: 25 (100%+)
Are most just running the shorty rearwards with the esc pushed up against the battery.
Like:
http://www.petitrc.com/setup/associa...14041113/5.jpg
3srcracing is offline   Reply With Quote
Old 10-09-2014, 07:09 PM   #8353
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Like:
that is how I run mine.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-09-2014, 07:57 PM   #8354
I ran mine that way for a couple race nights but had a HELL of time getting the esc and battery to stay stuck to to the chassis. I tried 4 different brands of servo/double stick tape and always had an issue so I went to a different setup. I would say that the PARMA PRO servo tape was the best.
Old 10-09-2014, 07:58 PM   #8355
I would be curious to know what hartson uses to get his to stay? Anyone know for sure? We can all speculate!
