    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 10-02-2014, 08:18 AM   #8236
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
I'm having a hard time getting a good balance between good grip and good steering using the shorty packs right now. I move it back I have awesome grip and horrible steering push, I move it forward I get better steering, then I'm struggling for traction and spinning out.
I also just switched over from SMC shorty packs to the Revtech Formula X shorty, I think the Revtech "brck" is about 100 grams heavier. My car is right around 1576 grams right now with the shorty pack.
Jeepy2013 is offline   Reply With Quote
Old 10-02-2014, 08:24 AM   #8237
I was fighting the same issue with mine as well last night during the first heat. I went and talked with one of the AE Guys at my local track and he suggested adding 3mm spacers under the ball studs on the FT Rear Hubs and then remove the 2mm spacer from under the other ballstud. He also recommended taking moving the upper rear shock mount to the inner most hole and change to white rear springs... Dropped .4secs off my fastest lap time and about the same off my 15 lap average.
I am sitting at 1533grams with a Revtech Shorty. If I need a heavier battery then I just switch to my Orion Saddles because they are about 80grams heavier
Jade67 is offline   Reply With Quote
Old 10-02-2014, 08:50 AM   #8238
Suspended
Originally Posted by Jade67 View Post
Yes
Take a look at the new MIP trans and then take a look at the current B5M trans. Pay attention to the differences then think about what you're looking at for a few minutes and then get back to me.
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 10-02-2014, 08:54 AM   #8239
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
I know this is simple also but I made one of those same adjustments on both of my mm's... Was fighting traction and a horrible push no matter how i locked in my shorty pack. All i did was move my rear shock tower position to inner most hole and went to 3mm trailing on my front hubs and left my smc battery in the rear position and it gave me a very good blend... Car is really dialed now!! No more pushing and I almost have to much rear grip!!
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 10-02-2014, 09:48 AM   #8240
Jeepy2013's Avatar
I'm gonna give that a shot, I believe that is similar to one of Cavalieri's set ups on some indoor tracks.
Old 10-02-2014, 09:49 AM   #8241
They dropped a gear so it is a 3 gear AND MOVED THE MOTOR to face the other direction... Just like the standard Rear motor setup... If they kept the same motor placement/direction and dropped a gear you would be going backwards and in a hurry
Old 10-02-2014, 10:37 AM   #8242
Send a message via ICQ to JiuHaWong
What point are you trying to make?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 10-02-2014, 10:48 AM   #8243
Quick question. Whats the best way to punch an air hole in a tire? I have seen guys use a variety of things. What works the best?
JHKracing is offline   Reply With Quote
Old 10-02-2014, 10:50 AM   #8244
Leather punch
Old 10-02-2014, 10:56 AM   #8245
Originally Posted by JiuHaWong View Post
Leather punch
Thats what I was looking for! Thanks!
Old 10-02-2014, 10:59 AM   #8246
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Unless you reverse the rotation of the motor... which is why I asked if there are any modern ESC's that can't do this. With most of the current ESC's you can tell the motor to spin whichever way you want.
Tekno RC
Matthew_Armeni is online now   Reply With Quote
Old 10-02-2014, 11:13 AM   #8247
None of my comments have been directed at you, I was responding to the "take another look at the MIP setup and think it over then get back to me" from the other person... And you're right, if you could tell the motor to spin the other direction then it wouldn't matter and they could have kept the motor mount setup on the same side as 4 gear trans while only using 3gears, but with the way that MIP 3 Gear trans was designed there is no need for the ability to reverse the motor direction...
Old 10-02-2014, 11:41 AM   #8248
Sorry, I thought Skeeter's earlier post was yours and believed I was re-replying to the same statement/question
Tekno RC
Old 10-02-2014, 02:18 PM   #8249
It's all good
Old 10-02-2014, 03:01 PM   #8250
Ok making the switch to mid motor this month I've decided. The MIP trans looks interesting, I will have to keep my eye on it. We have a local MIP driver here that is really nice so I will have to try his and see how I like it. I can see pros and cons to it but so far MIP hasn't dissapointed with anything so I will give it the benefit of the doubt until we can see how it works. As far as the body goes that's a silly thing to worry about since it will be super easy to trim the other side out. The only bad thing there is you will need another body unless you want a gap on the other side, either way no big deal.
scythe23 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
