    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 09-30-2014, 11:44 AM   #8176
Default Front Steering Blocks
Originally Posted by TomErickson View Post
I have seen a lot of comments about kit bearings. I just got my B5M kit and was assembling it yesterday and noticed that the small wheel bearings for the front spindles are not very smooth. I think I will be getting better bearings right away. I am using the stock steel spindles and glued in my inserts. So my bearing seem stiff and one side is gritty out of the box. Is THIS what everyone is seeing with their stock kit?
I have noticed the same thing. In my instance, the bearings are very smooth until the axle is inserted. That tells me that the plastic inserts that hold the bearings don't locate the axis of the axle properly. Basically side loading the bearings when you force the axle through. That causes these plain bearings to bind up a bit and feel gritty. I have tried many different bearings and new plastic bit with the same observation. You can feel the bit of resistance as the axle is pushed through the bearings. It seems a bit better with the 3mm (centered) position though.
jehjr68 is offline   Reply With Quote
Old 09-30-2014, 11:52 AM   #8177
TomErickson's Avatar
OK, I understand this and it is exactly what I experienced. What can be done to align the bearings to reduce side load on the bearings. I would like to have a one piece spindle to eliminate this issue. I am really loving this chassis and this is the only area that I feel needs some attention. The old architecture was very good for bearing alignment.
I am going to look at this tonight to see what I can do.
---Thanks to my Sponsors: Novak R/C, and Nankin Hobbies ----
TomErickson is offline   Reply With Quote
Old 09-30-2014, 12:03 PM   #8178
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Do you have the updated crush tubes?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-30-2014, 12:06 PM   #8179
Jmuck69's Avatar
Could be the crush sleeve issue.... I slipped a .02mm shim between the crush tube and the axle (using the axle with clamping hex) and all side load and bearing issues solved
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 09-30-2014, 12:36 PM   #8180
JatoTheRipper's Avatar
The other night I noticed mine felt gritty. What's the length of the updated crush tube?
Leaf Spring Mafia - Member #1
https://www.shapeways.com/shops/leafspringmafia
https://www.facebook.com/LeafSpringMafia
https://www.instagram.com/LeafSpringMafia
JatoTheRipper is offline   Reply With Quote
Old 09-30-2014, 12:56 PM   #8181
Jmuck69's Avatar
I think it's .02mm longer.
B6D | B64D
Old 09-30-2014, 01:23 PM   #8182
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Do you remember what the original value was by chance?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-30-2014, 01:24 PM   #8183
this made me laugh, lol.
Old 09-30-2014, 01:42 PM   #8184
lala4fire's Avatar
Default Schelle battery strap
For my in-line setup I was looking for a way to eliminate the front battery spacers and Schelle came through. Know I can move my battery forwards and backwards without having different size front spacers. Quality is top notch and and it does what it advertised.
Associated FT SC10.2 SCB/ tekin rs/gen2 10.5
Associated B6/ tekin rs 2/gen3 8.5 B5 rear motor
Tekno EB48.4/tekin rx8 2/gen2 1900kv
Tekno NB48.4/ Alpha Dragon III
HB D413/tekin rsx/gen3 6.5
lala4fire is offline   Reply With Quote
Old 09-30-2014, 02:07 PM   #8185
Well got the rest of the goodies installed... Atleast until my FT bearing kits get back in stock. I also have a set of Acer Ceramic Bearings to compare to the FT kit.
After installing the Exotek Axles, Triad Slipper, CB Cut Gears, D4 17.5 and FT Motor Plate it came in at 1533g RTR
Jade67 is offline   Reply With Quote
Old 09-30-2014, 02:14 PM   #8186
I noticed today after I installed the new parts that it seems to pull to the right pretty hard on heavy breaking. Does it a little bit on heavy acceleration also but not as bad. Any ideas??
I also have all the RM Arms F/R as well as the tower that I am debating on throwing on to see. I run high traction clay at IRCR and have read that the RM arms work really well on the high bite stuff.
I am pretty happy with the weight where it is at right now. Just hoping that it doesn't mess with the setup too much because it ran really well.
Old 09-30-2014, 02:14 PM   #8187
Jeepy2013's Avatar
Trader Rating: 78 (100%+)
Nice, I like that!
Jeepy2013 is offline   Reply With Quote
Old 09-30-2014, 02:27 PM   #8188
Diggity's Avatar
Trader Rating: 29 (100%+)
Default Diggity Designs Mid Motor Carbon Battery Strap
Diggity Designs has released their version of the B5M mid motor carbon fibre battery strap. Check out the website for more info.
http://www.diggitydesigns.com/produc...ciated_B5.html
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 09-30-2014, 02:39 PM   #8189
I hope you mean 0.2mm. 0.02mm seems too small.
Old 09-30-2014, 03:17 PM   #8190
Nemaris's Avatar
Trader Rating: 18 (100%+)
Originally Posted by davetamiya View Post
Have got a fair bit of slop in the front hub bearing inserts. Any thing I can try to remove this? Second set of hubs and inserts on the car along with new bearings
Go with this
http://www.amain.com/JConcepts-B5-B5...le-Set/p360097
and
http://www.amain.com/JConcepts-B5-B5...s-Blue/p360098
or
http://www.amain.com/Lunsford-Associ...-Axles/p291810
The FT setup is good too, just heavier. It seems a lot of people have slop in the front hub assembly. You can CA glue your inserts in place, I would recommend buying spares so you can have a glued set for 2 3 and 4mm trailing. By upgrading from the stock setup you will help take a lot of that slop out, and your bearings won't get gritty as fast.
Nemaris is offline   Reply With Quote
