    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 09-21-2014, 09:56 PM   #8056
Cridd's Avatar
Trader Rating: 16 (100%+)
Jumping didn't change for me with arm changes.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 09-22-2014, 02:40 AM   #8057
eper's Avatar
Trader Rating: 14 (100%+)
Maybe your landing issue is with the arms rubbing the chassis. I had to clean them up a little on the front inside so they would clear the chassis
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 09-22-2014, 02:26 PM   #8058
Yeah, mine doesn't bind at all. Arms move freely from full compression to full rebound without the dampers attached. Maybe running too much anti-squat?
Scargoes is offline   Reply With Quote
Old 09-22-2014, 02:29 PM   #8059
onefast8's Avatar
Trader Rating: 41 (100%+)
Looking over Cav's Nats setup at Space Coast, he has -1mm marked for steering stop spacing. Anyone know if material is removed from the caster block or the steering block?
http://www.teamassociated.com/pdf/ca..._Cavalieri.pdf
Jake R.
onefast8 is offline   Reply With Quote
Old 09-22-2014, 02:48 PM   #8060
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
The steering block is shaved down 1mm.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 09-22-2014, 07:43 PM   #8061
Trader Rating: 29 (100%+)
Mine jumps and lands just fine with RM arms on jumps that have a take off and a landing. most all the clay indoor tracks in my area have 1 or 2 sections where there is either a big table top with a roller following it or big triple like 25ft with a rounded landing and a single after it and the fast line is a hard flat landing, thats when the car will land hard and bounce. thats where the stock arms are better significantly
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 09-23-2014, 03:35 AM   #8062
eper's Avatar
Our current layabout has a jump that's long distance without much height and it's a flat landing. I didn't notice much landing difference but I run kyosho shocks. I just like the way they bleed better.
new milford ct,
Old 09-23-2014, 07:42 AM   #8063
Send a message via ICQ to JiuHaWong
Originally Posted by Skeeter36 View Post
You always chime in with smart A$$ remarks but never offer any advice. I'd sure love for you to tell me and some of the fastest AE drivers why this is a set-up issue. With the arm swept 2mm further forward it creates a binding effect on hard flat landings and makes the car bounce rather than settle.
If you could please let me hear your side and your findings to justify your set-up issue comment.
Not sure why you took such an offense to what I said. PFKAOG is a lot worse when it comes to "smart A$$" remarks. I'm pretty sure I've given plenty of advice and helpful links in the past.
See the quotes below:
Originally Posted by thecman26 View Post
I just put RM rear arms on mine and it jumps like a dream just has a lil more rear grip... IDK why yours jumps weird. Maybe a shock issue?
Originally Posted by Scargoes View Post
With my setup I don't have any problems landing or squaring up for a jump with the RM rear arms. The car is quite stable on landings even when I miss the downside. I started with box stock setup and worked my way to my current setup. The first two things I did in changes was to go white springs F/R and RM rear arms, I picked up stability and dropped some time. Next was changing shock oil and flat front setup and picked up steering and dropped .3sec lap average. Changed pistons and oil again to drop another .2 sec average. This was all after dropping 1.5 sec lap average with a tire change. In all from the stock setup running barcodes (V2) i dropped over 2 sec/lap average from my races. I'm quite happy with my setup. Sure, I could do with a little more steering but I don't want to sacrifice my stability until I get better. I went from DFL (2-3 laps down) to 4th or 5th and on the same lap as the leaders.
Not everyone is having the same issue you do. That makes me believe there is something else that could be looked at (could be a number of things).
FWIW, I have had no issues when I changed to the RM rear arms. The handling in the turns are different, but the jumping and landing has been fine.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 09-23-2014, 11:22 AM   #8064
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
JPKinsella - make sure you take/post a nice picture of that UNREAL beauty queen of a B5m before you run it!!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-23-2014, 12:30 PM   #8065
JPKinsella's Avatar
Trader Rating: 30 (100%+)
Will do should be totally complete Thursday night and sitting on the scale.. I will post pics and a summary of my results!
AE B5M, Hot boddies D413, Kyosho RB6 mod, Orion ESC, Radio Post servos, Futaba 4pks
NOT HERE FOR A LONG TIME JUST A GOOD TIME!!!!!!!!!!
DON'T HACK ME BRO............
JPKinsella is offline   Reply With Quote
Old 09-23-2014, 03:36 PM   #8066
Super Moderator
Wait till you guys see this thing
- RCSpecialties -
Old 09-23-2014, 06:33 PM   #8067
JuiHaWong: I didnt take offense but to just say its a shock issue without having much information is kinda strange to me. I am not the only one that has noticed this. Gillespie, Yonker, Denney all FAST mod drivers have noticed the same issue. It may not be an issue in stock, But for faster mod drivers it is definately noticeable.
Old 09-23-2014, 06:39 PM   #8068
suby723's Avatar
Trader Rating: 21 (100%+)
I wonder what cherry would say on all this... haha
suby723 is offline   Reply With Quote
Old 09-23-2014, 07:16 PM   #8069
he would tell us that we need to run a custom graphite arm LOL JK. cherry is cool, very eccentric.
Old 09-24-2014, 06:32 AM   #8070
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
I ordered the Avid Triad Slipper setup for mine yesterday, on my test n tune day last Saturday the stock slipper just felt very inconsistent. I also order the AE aluminum transmission topshaft.
Jeepy2013 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
