    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 09-17-2014, 07:59 AM   #7966
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
oh, you probably wont like the saddles in the car for 17.5. The car is already pretty heavy. You might want to actually work on getting the weight down some.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-17-2014, 09:47 AM   #7967
BRSracing's Avatar
Trader Rating: 52 (100%+)
Interesting the B5 and B5m are both in the web special section of the AE website. They seem to put stuff there to close out the inventory...... Makes me wonder if a FT version is in the works to replace them.
BRSracing is offline   Reply With Quote
Old 09-17-2014, 09:51 AM   #7968
Probably. My car is already FT specs. So no point really.
Old 09-17-2014, 09:59 AM   #7969
BRSracing's Avatar
True, if there is one don't see much more they could come out for one. They have a full line of really cool stuff now!
Old 09-17-2014, 10:09 AM   #7970
Every single FT part they could come up with is already out. People would just save some money when buying a new kit. They could improve the slipper or at least put a vented 2 pad back in the car. Because not even the team drivers use the VTS, lol.
Old 09-17-2014, 10:16 AM   #7971
Jeepy2013's Avatar
Trader Rating: 77 (100%+)
I was kinda thinking the same thing, seems like the car is a little on the heavy side. I haven't weighed it yet as I don't have a scale anymore.
Jeepy2013 is offline   Reply With Quote
Old 09-17-2014, 10:21 AM   #7972
given that you added weight with all of that aluminum, lol. I am guessing around 1650g
Old 09-17-2014, 11:20 AM   #7973
Originally Posted by SnotRkt View Post
Can you let me know what you changed specifically? Im running kit setup on high bite clay and I feel like it pushes way too much on power steering. I'm used to driving SCTs with tons of oversteer
For the front I changed from stock setup:
B5R arms and shock tower
3mm trailing axle insert
1mm on each side of the caster block
1mm bump steer
arms flat ride height
For the rear I changed:
B5R arms
2* antisquat
0.5* hub insert
"A" ballstud hole, using the B (2 hole) link insert, B inserted in the down position
Forward hub spacing
0mm inner ballstud spacer (camber link)
1.6 Pistons, 30wt oil, 3 limiters
bones level ride height
This really wakes up the front end. It has very aggressive turn-in. When I have more time at the track I will experiment with front tires before changing anything.
kmags is offline   Reply With Quote
Old 09-17-2014, 11:27 AM   #7974
NoNothing's Avatar
Other than the slipper, what are some of the must haves you are all running off the stock car?
I have heard talk of clamping hexes for the rear, what benefit do those have? My hexes seem to stay locked to the pin.
I know the rear hub ball cup mount can flex on the composite side causing some backing out. Though loctite seems to take care of that.
NoNothing is offline   Reply With Quote
Old 09-17-2014, 11:30 AM   #7975
Super Moderator
Cpt.America's Avatar
Originally Posted by NoNothing View Post
Other than the slipper, what are some of the must haves you are all running off the stock car?.
Only ran the car one weekend so far.. .and the only thing that I found was the slipper. The car was stellar everywhere else.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-17-2014, 12:10 PM   #7976
Jeepy2013's Avatar
Sounds like Avid is probably the way to go as far as slipper is concerned. I'll find out soon enough...lol
Old 09-17-2014, 12:23 PM   #7977
Okay so I have been trying to get through all of this thread and filter through all the drama...haha I am wondering where the grub screws are being installed. Sorry for it has been answered a million times but Hundreds of pages of reading is mind numbing and so I figured I would ask and then go back to my reading
***Looked up the Manual online since I bought my buggy used and found it... I will continue ready.. Only approx 250 more pages to go...haha***
Jade67 is offline   Reply With Quote
Old 09-17-2014, 12:59 PM   #7978
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
There was problems with people snapping axles, the clamping hexes seemed to fix this issue.
All depends on what your looking to accomplish. I can say I have nearly $300 in aftermarket in my car and now am starting to find the setup I need to compete at the Stock Nats next year.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
Old 09-17-2014, 01:08 PM   #7979
Super Moderator
racer1812's Avatar
Read the manual, it tells you where they go.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 09-17-2014, 02:51 PM   #7980
I will have to pick up a manual because I bought my B5M Used and it didn't come with one.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
