    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 09-05-2014, 11:14 AM   #7711
skrichter's Avatar
Send a message via AIM to skrichter
Anyone else have clearance issues with the servo link on your servo case?
I've tried a shorty airtronics and a full size spektrum servo -- they both rub the servo link on the case.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 09-05-2014, 11:18 AM   #7712
bilster44's Avatar
Have you tried the two different thickness spacers that come in the kit, to move the servo forward a bit?
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 09-05-2014, 11:20 AM   #7713
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
remove the washer under the stud and put an oring on the stud on the servo arm. this keeps the arm flatter and less likely to run
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-05-2014, 11:20 AM   #7714
bilster44's Avatar
Originally Posted by MODELTECH22 View Post
What associated standerd piston is the closest to a 3 hole 1.4??
Probably going to be the 1.7's beings the 1.6's give the shock more pack than a 1.4 3 hole.
Old 09-05-2014, 11:25 AM   #7715
bilster44's Avatar
Be careful not to get the servo to bell crank drag link in a bind though (because of it's angle)...untamed kitty's idea may get you in the ball park though
Old 09-05-2014, 11:34 AM   #7716
MODELTECH22's Avatar
Trader Rating: 20 (100%+)
Thank you much for the answer..
22 3.0 Hobbywing
22 2.0 W/exotek chassis TEKIN
22T 2.0 Lrp Flow
SCT 22 2.0 Hobbywing
MODELTECH22 is offline   Reply With Quote
Old 09-05-2014, 11:55 AM   #7717
skrichter's Avatar
I'm already not running the stud on the arm. I think the oring will help, but its still tight.
There has to be something going on here? I saw other folks post they were having issues. Some folks are shaving the horn a bit, others are spacing out the horn to move it away from the servo. But I think we are missing something.
Old 09-05-2014, 12:54 PM   #7718
my savox is definitely tight but without spacer it fits - if the arm were to go full throw there may be rubbing but since it doesn't it works well.
hcopp is offline   Reply With Quote
Old 09-05-2014, 01:15 PM   #7719
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
This chart courtesy of Ray Munday in the Australian Forum section is exactly what you are looking for!
http://www.rctech.net/forum/attachme...r-chart_v3.pdf
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 09-05-2014, 01:19 PM   #7720
Jeepy2013's Avatar
Trader Rating: 78 (100%+)
First little issue....
Found a ball stud without threads on it....
Jeepy2013 is offline   Reply With Quote
Old 09-05-2014, 02:00 PM   #7721
onefast8's Avatar
Trader Rating: 41 (100%+)
Decided to live life on the edge and try the Savox 1251.
Had to do a few things:
1. Remove servo arm ballstud spacer.
2. Remove grommet from servo lead/case. I used a dab of silicone to fill in.
3. Position servo slightly to the left of the car so as to leave a slight gap in the right side mount to clear the servo lead. No case mod/cutting was required. No pinching here, its "just" enough to let the lead come out at 90 Deg.
4. Used one very thin rotor shim to move the arm very slightly off the servo output spline. Under the horn/on top of output spline.
5. Slight shaving on the servo side bottomish side steering link to clear the case. Does not touch at all under full lock.
YMMV.
Jake R.
onefast8 is offline   Reply With Quote
Old 09-05-2014, 02:02 PM   #7722
Trader Rating: 137 (100%+)
The D413 I got had no teeth on the spur gear.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 09-05-2014, 02:57 PM   #7723
lol
Old 09-05-2014, 03:04 PM   #7724
Jeepy2013's Avatar
lol
LoL is right!
Mine was kind of a chuckle when I went to install it. The only issue is I don't have another ball stud to replace it with. I called AE and they told me I needed to fax them a copy of my receipt and a picture of the issue.....geez....
I did that yesterday and haven't heard anything back.
Old 09-05-2014, 03:05 PM   #7725
this looks interesting...
