    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 09-01-2014, 06:10 PM   #7636
xrayracer1's Avatar
Ok, quick question about the slipper clutch. Do you set it and forget it or do you still tune it to the conditions like the "old school" slipper clutches? This is slipper clutch is new to me and I'm hoping to have my debut race with it this weekend.
Gavin.
Converting nitro to electric is utter blasphemy.
xrayracer1 is offline   Reply With Quote
Old 09-01-2014, 06:14 PM   #7637
hlpressley's Avatar
Trader Rating: 209 (99%+)
I have a conversion kit on the way to convert my RM to MM. Is there anything specifically that you guys would recommend I pick up for the MM car? My RM car has the majority of the available upgrades but wasn't sure if there was any MM specific upgrades that I should look into? Thanks in advance!
Pressley Racing Products
hlpressley@gmail.com
hlpressley is offline   Reply With Quote
Old 09-01-2014, 06:17 PM   #7638
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
the alum rear camber block is nice for durability. the alum C block is nice for tuning. Not sure what other upgrades your RM has, so that is my 2 cents.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-01-2014, 06:26 PM   #7639
TOO-TALL's Avatar
Originally Posted by QDRHRSE View Post
There's no way we can give you spot on advice without knowing more about the track you plan on running on. You can't go wrong starting at 69/30 or 72/31. Our track is 110 x 70 or so and its been really hot. I'm running 69/32 with a 17.5 (can timing cranked). A friend of mine runs 69/34 w/his 17.5. Generally speaking I've heard the D4 likes to be geared a little tall.
Track is 125x65 high traction.were running slicks now .I'm new to 17.5 I'll start with 72/32 .
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
Old 09-01-2014, 06:27 PM   #7640
hlpressley's Avatar
My RM has the following...
JC turnbuckles
JC aluminum hexes
AE C & D plate
AE brass front bulkhead (25 degree)
AE aluminum front pin brace
AE aluminum shock bushings
I am probably forgetting something. FWIW, I will be running mod.
Old 09-01-2014, 06:37 PM   #7641
moto44's Avatar
Trader Rating: 9 (91%+)
Just picked up a B5M. What is the hot battery setup for this car? Also looking for a good steering servo. Was looking at the Savox any good? Which model? I will be racing on a indoor clay track. Thanks
Barnstormers Raceway
Critters
________________________
moto44 is offline   Reply With Quote
Old 09-01-2014, 09:00 PM   #7642
Trader Rating: 23 (100%+)
Does anyone know if Associated is plan on releasing a factory team version?
bmcallister is offline   Reply With Quote
Old 09-01-2014, 09:03 PM   #7643
JC turnbuckles
JC aluminum hexes
AE C & D plate
you cant reuse the RM C & D plates, but you can use the inserts. The brass front bulkhead may not be very good. As the MM does not need the weight up front like the RM car.
Old 09-01-2014, 09:04 PM   #7644
lol, I was thinking about this today. I would like to get my kid a B5 for xmas. The problem is, if there is a FT car, it wont be until after xmas probably. If there is one at all.
Old 09-01-2014, 09:06 PM   #7645
I would doubt it. Ft option parts are all out now they make more $ selling them individually. Plus then you have the option to add the ft parts where you want them.
robbie_gtc is offline   Reply With Quote
Old 09-01-2014, 09:10 PM   #7646
I would agree. If there was a FT car, I would do the minimal if I were AE. Do like TLR and have people buy the stuff they want and only include the must haves.
So IMO, all the FT should have is:
Alum C & D mounts
Xrings
Alum Hexes for the rear only
Alum rear camber block for the MM
Ti turnbuckles
Nothing else is really needed. Milled motor plates, FT Hubs, alum top shaft and all the rest should be bought separately as option parts.
Old 09-01-2014, 11:18 PM   #7647
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
hate to bring up the ball cup issue, but....
as far as aftermarket, are there aftermarket cups (lunsford) that people are having success with?
RC*PHREAK is offline   Reply With Quote
Old 09-01-2014, 11:20 PM   #7648
Trader Rating: 29 (100%+)
To be honest a FT car wouldn't be a wise choice for AE. If they would just put the FT bearings in the team kit that's already out, it would be perfect for 99% of people that buy the kit. The aluminum stuff adds weight for the guys that run stock, the hard parts are kinda fragile, and I don't know of 1 person that has broke a stock rear camber block. So if they would just add awesome bearings to the kit that's already out it would be an even better car outta the box
Skeeter36 is offline   Reply With Quote
Old 09-02-2014, 09:29 AM   #7649
I recently stripped the head on a 2.5x8mm screw that goes into the front hinge pin holder. I am debating replacing the button heads with caps heads. Any issues with the cap head screws poking out too far?
Old 09-02-2014, 09:37 AM   #7650
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
why replace? get a set of MIP hexes and that will never happen again. I use to do that a lot with other brands. Went to MIP (ya they cost more, but you will never replace them) and havent had the problem since.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
