Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#7576
R/C Tech Elite Member
If anybody else is looking for clamping front hexes, 91409.
They have some in stock at nitrohouse!
http://www.nitrohouse.com/Front-Clam...5_p_16643.html
#7577
FYI: If anybody else is in search of the front clamping hexes, Nitrohouse has them in stock, i don't know how but they do!
#7578
I run on high bite and I have the reedy square, saddles, and a shorty and so far my car feels the best with a shorty. I NEED MORE STEERING.... I have tried a few things to get more but nothing seems to add the amount im looking for. I love a car that is a little twitchy, just my driving style. Any help is greatly appreciated
My setup
Front: kit stock
Rear: white spring, 1.6 pistons, 30 wt oil, 1 mm spacer under camber link, upper shock inside hole, camber link ran in stock position on inside and hub.
Bad news is our local track just closed, so my one practice day old B5m may be up for sale.
#7579
#7580
The stock ones suck!
Its a widely known issue, the stock hexes are tiny and thin, make changing tires a headache, and that silly screw has been know to pop out letting loose a wheel at the least opportune moment!
If ya get the clamping axles (which are equally as hard to find) and the clamping hexes and your good to go!
Plus the anno'd blue aluminum looks better too!
#7583
my moms gone I need a ride to the lhs to get my b5
#7584
ok ill have them ship it down to me
#7585
#7586
rcplanet.com has front axles in stock.
#7587
I'm a little confused. When you change the axle from 2-3-4mm trailing the manual tells you to change the rear caster block. What part exactly am I changing? The rear hub?
#7589
