    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 08-25-2014, 04:18 PM   #7321
bilster44's Avatar
Originally Posted by Wildcat1971 View Post
I found the plastic caps got play in them rather fast and my alum caps have stayed slop free for months.
What more do you need to know? How to keep them clean? I can do that!
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 08-25-2014, 04:20 PM   #7322
Trader Rating: 20 (100%+)
Aluminum vs Plastic shock caps. Please discuss. I see that most everyone including the pros use the plastic caps. I found the plastic caps got play in them rather fast and my alum caps have stayed slop free for months.
I switched to the aluminum cap also, as the bleed screw hole threads in one of the plastic cap was stripped.
The plastics are cheap enough to replace a maintenance item and are a little lighter helping to keep the CG lower.
I did notice the new FT B44.3 comes with the plastic caps too.
GTSSTANG is offline   Reply With Quote
Old 08-25-2014, 04:25 PM   #7323
shannow's Avatar
Originally Posted by Wild Cherry View Post
Never seen someone go faster on clay with a gear diff till now.
I'm more consistent too with gear diffs. Usually I run between 2k up to 12k 5k and 8k being intermediates as it is pretty subtle to me at least.
Funny that this has come up as I, again, snapped the tension screw on it lol. Did this on the 22 as well... Oh well ball diffs don't like me I guess and I'm useless with them.
The only ball diffs that didn't go on me was the schumachers,xray and kyosho. When they were knew I could feel a little clicking noise/feel. I should've gone straight for the ceramic balls...
Anyway I ordered the gear diff for the B5m as I run mostly on carpet/astro with very few slippy sections where all I'm asking the car is do it's best to not loose too much time there.
I really like the fact that it's tunable quite finely,can be repeated without tests (no pressure to guess), really reliable and tough. You can safely hold the rear wheels down and full the throttle to set the slipper to just lifting the nose.
The 22 gear diff only leaked a bit after 6-7 months of weekly usage. So that's about 50-60 hours plus races. I'll see if the b5 can beat that . The gears inside were in pristine condition btw.
Jonathan
shannow is offline   Reply With Quote
Old 08-25-2014, 04:47 PM   #7324
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by QDRHRSE View Post
I'll also add that AE's parts quality has really improved. I definitely can't complain about any of my B5s wearing parts fast. I've done a lot of racing and practice lately and the outdrives on my non-pucks cars are all still near perfect after a couple months.
And that was really the only complaint about previous cars. Now that they have really up'd their game in parts quality... Why would you not run AE? I'm excited to build a B5M.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-25-2014, 05:08 PM   #7325
Tech Legend
Wild Cherry's Avatar
Johnatan
So far my ball diff is original from the first day I built the kit.
Its still smooth & tight.
My top shaft, gears, CVA & drive cups are all shot .
Worn out from mass packs.
I get to replace all of it soon for our N/w Gold Cup next month.
You should be getting the same wear & tear from the B5 ball diff .
not sure why your having difficulties.
I always use the ceramic diff balls & kit thrust bearing.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-25-2014, 05:16 PM   #7326
vr6cj's Avatar
Trader Rating: 124 (100%+)
Johnatan
My b5m diff has held up too since bought the kit first day till last race. Got all gritty and the thrust washer had blew apart. Buts thats alot runs too
vr6cj is offline   Reply With Quote
Old 08-25-2014, 05:29 PM   #7327
STLNLST's Avatar
Trader Rating: 19 (100%+)
I didnt like mine at 1600. I like it around 1550 myself. If he was 1600, he must not have run the pucks and light weight tranny/slipper parts. Because those should put you under 1600 unless you put brass on the car.
Pucks and all the light weight stuff
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-25-2014, 06:00 PM   #7328
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
I want to use my B5m on an onroad track.
I've been looking for road rage tires for this car but I can only find rear tires. Can't even find mentions of road rage tires for the front at all.
Are there any other tires that would work OK onroad?
lagcisco is offline   Reply With Quote
Old 08-25-2014, 06:46 PM   #7329
How do I free up my ballcups? Some are good some bind, help
clydeywidey is offline   Reply With Quote
Old 08-25-2014, 06:50 PM   #7330
Originally Posted by 3srcracing View Post
Believe my question got missed:
"Anyone care to share what ESC settings they are running on a LRP SXX for mod buggy (9.5)?
Also what about ESC settings for a 17.5 buggy?
Never really messed with the settings before but figured I might as well."
Running mine with a reedy sonic 2 9.5. I run a 81 spur and 25pinion.
Feel is stock #3 setting i believe. And boost at #5. No drag brake.
robbie_gtc is offline   Reply With Quote
Old 08-25-2014, 06:53 PM   #7331
Super Moderator
Trader Rating: 17 (100%+)
Mine were kinda sticking some on one car but not on the other.
Place each ball stud in my dremel.
Spun it while in the actual cup for about 5-10 sec.
Popped the ball cup off and spun the ball stud against a scotch brite pad to polish it.
Spray Liquid Wrench silicone spray on a rag and spun the ball stud on it.
Popped it all back together and no more bind. took about 2 or 3 min each ball stud.
Mind you I tried doing the pinching trick, tried multiple things. This method proved the most consistent and reliable. Also it was weird. One car had zero binding, one car had every cup binding. So I completely understand why some guys were complaining about it earlier while others were saying they had none.
*queue 4 pages of ball cup talks starting............. now*
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-25-2014, 07:22 PM   #7332
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
hmm, he had a shorty servo too. All I have is light weight slipper, topshaft, some ti screws, alum hexes, alum shock caps, alum rack, alum front hexes, alum rear ball stud mount and ft axles. No pucks and I am 1570. I would think he was lighter with pucks. oh and I use chassis tape. Regardless. I like the car in the mid 1500's. If I ever add pucks, I will probably try to get more weight in the rear. maybe the front brass suspension holder. seems like a good place for weight. I have never ever likes a super light car. And as bumpy as nats was, I would think more weight was more planted.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-25-2014, 07:50 PM   #7333
JatoTheRipper's Avatar
I picked up the new servo from xpert. It looks great and comes with a nice short lead for the b5m. But the steering link hits the case.
Who makes the Xpert servos?
Leaf Spring Mafia - Member #1
https://www.shapeways.com/shops/leafspringmafia
https://www.facebook.com/LeafSpringMafia
https://www.instagram.com/LeafSpringMafia
JatoTheRipper is offline   Reply With Quote
Old 08-25-2014, 08:09 PM   #7334
Trader Rating: 42 (100%+)
Xpert makes their own and you can get them from shop viper.
Some nice new stuff on the way too but gotta stay tight lipped!
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 08-25-2014, 08:31 PM   #7335
Jmuck69's Avatar
I had the metal caps but noticed oil pooling around the upper shock bushing and couldn't figure out why. I cleaned and was refilling the shock and when I went to push the shaft up with cap on and the bleed screw still in, noticed oil weeping out the cap inside the shock bushing eye. didn't see a noticeable crack or hole but it was weeping. weirdest thing... i put the plastic back on and have no issues. I use the FT shock mount and bushings.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
