    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-12-2014, 11:21 AM   #6796
Tech Legend
Wild Cherry's Avatar
Originally Posted by GTSSTANG View Post
WC, are you still using the same inline electronics setup?
Still using but there has been some refinements.
Will post compete set up later tonight.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-12-2014, 11:22 AM   #6797
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by jpcopeland1 View Post
Seeking a good starting setup for SoCal medium to high bite tracks, mostly stock B5M. Looking to lose a bit of push, and gain more low speed steering. Not interested in having the lightest car out there. Car is already too light in the rear with the pucks, aluminum top shaft, and cut gears, plus shorty pack. May ditch it all and go heavy (all stock plus B5 flat arms, and tower) to gain more stability.
Since we run on lower grip overall out here, maybe look at Mike Gay's setup. Not sure how it is compared to the other guys, but I know he runs his cars on the heavy side and his car is always amazing. I know that he added all the aluminum stuff to his car since he turned in his setup, so if anything his car is a bit heavier.
His setup is on AE's site.
http://www.teamassociated.com/pdf/ca...sJumps_Gay.pdf
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-12-2014, 11:49 AM   #6798
So I know I am going to get a few different repsonses...but that's the idea. I am looking for a recommendation on an ESC. Going to run stock at first. (Sonic Mach 2 17.5) Then once I am comfortable enough, move up to modified. So any input on the type of ESC that would be able to handle both? I dont mind spending a little if its truly worth it. Would love to hear everyone's input!
JHKracing is offline   Reply With Quote
Old 08-12-2014, 12:02 PM   #6799
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I have run pretty much every popular brand. I currently run the orion R10's because i got them used for cheap. The hobbywing v3.1 is just as good though. You can get the stock spec version for about $129. It will do stock and mod down to 5.5 turn. Also, the program LCD box is pretty cheap
http://www.amain.com/Hobbywing-Xerun...ss-ESC/p279086
If you would rather get a "name" The orion stock spec is good. But the program box is stupid expensive.
http://www.stormerhobbies.com/cgi-bi...ns&pn=ORN65120
Both of these are top notch. The main difference is the cost of the box. And the orion has less tuning options.
But.... This might be the next esc I get. SMC is pretty good about testing and performance. It is a small american company, but danny has been pretty great.
http://www.smc-racing.net/index.php?...product_id=238
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-12-2014, 12:11 PM   #6800
Trader Rating: 20 (100%+)
From my experience, all of the Big names are good, I have used most of them. I currently use Novak, Orion R10Pro, LRP and Hobbywing.
I am pretty impressed with the HobbyWing Xerun V3.1 Stock Spec. I bought both the 120A and the Stock Spec, but I have yet to use the 120A. The Stock spec has a plastic case and the 120A version has an aluminum case. I think the Stock one is 15 grams lighter, if that matters to you. Both are very nice.
I like the intergraded on/off switch on the case and the fact that the tuner is only $30.
GTSSTANG is offline   Reply With Quote
Old 08-12-2014, 12:28 PM   #6801
racer x 1's Avatar
Trader Rating: 27 (100%+)
Hobbywing v3.1 or stock spec
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 08-12-2014, 12:33 PM   #6802
Trader Rating: 59 (100%+)
Originally Posted by Wild Cherry View Post
Asked Brent myself about Trcr traction and how it compared to what he runs on .
Said it was about the same or very similar....
Asked others that travel to Chico,Surf city, Ocrc...
They claim Trcr has a little more grip.
I have no doubt the traction may be similar, but a setup that works on a tight track vs a larger flowing track will be different regardless if its identical dirt. I see yall are running a bout 15 second laps at TCRC.. thats a small track. Ive never seen pictures of your track, but i can promise you a setup that works on a 15 second layout is going to be different than a 22-30 second layout... and thats ok. I'm sure your setup does work good where you are... however to say that its the same as any indoor track is foolish.
rc23 is offline   Reply With Quote
Old 08-12-2014, 01:07 PM   #6803
Tech Legend
O
not that small, medium size just like Chico for instance..
Current lay out is a fast one, can see laps slow way down depending on the course design.
When the boys came up here they did not change much at all.
George W. Cherry
Old 08-12-2014, 01:29 PM   #6804
Rybeau40's Avatar
O
15 sec lap times is indeed a small layout.
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 08-12-2014, 01:41 PM   #6805
Tech Legend
I like to count every other lap as 1 Lap doubling the size the layout. Lol
fast lap is 30 sec now
George W. Cherry
Old 08-12-2014, 02:28 PM   #6806
Trader Rating: 137 (100%+)
It's very box stock plus square pack which I don't have one of yet.. The only setup I have not used yet lol.... If I used it I might have to go to 37.5/32.5 since his track conditions are on the cold side, and it has Ben hit as hell, and muggy here.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 08-12-2014, 02:44 PM   #6807
The R10s are great! But I have to give ever so slightly the nod to LRP for their brakes. The best I have ever used, just slightly. Would switch to 4 R10.1s in a heartbeat though.
Old 08-12-2014, 02:50 PM   #6808
lol, what? no one runs my setup. Not even the locals.
Here is my setup. I tried a few different things and I liked the fell of this the best. This is the setup I ran last weekend at the Short Course Shootout. The car was great, the driver was not lol. But the car did everything I asked of it. For me it turned on a dime....But My front tires are magical. lol. Meaning, when ever I want more steering, I put them on and any push I had goes away. Sometimes its too much and I go with a front tire that is more forgiving. Locally, tires are a big deal. And I dont mean the brand specifically, I mean how they are broken in and such. New tires always seem to suck. I tried the 1.4s in the front like cav, but I didnt like it. I tried lower weight oils and I didnt like it. I find my car is very easy to drive, but if I put the wrong tires on, it becomes a handful in a second. You can copy a setup, but kinda hard to copy peoples tires. Anyway, laugh away at my setup, lol. IDK I like it.
Hartson inline setup? Or of your own design? I hear you on tires. All of my tires are new since the durango ditching. Running them all at OC/RC tomorrow a few times to break them in. Maybe when it cools down a bit throw a couple sets on the street and grind em down a touch.
Old 08-12-2014, 03:09 PM   #6809
Super Moderator
yeah I know he wasn't far from kit setup.
Personally I have that Kody OCRC setup on my car and I'm getting around. I've only had a handfull of race days with it because I got my cars right before 8th scale season. I'll start focusing on it in a few more months lol. For now if I need it, I know it's there in a jam haha.
Old 08-12-2014, 03:15 PM   #6810
Get Brent Thielke's hot rod setup. Change to 3/1 antisquat and go to white front spring and green rear spring due to less weight over the rear.This is what i ran in 17.5 MM @ OCRC. You may want to try white rears too depending on the weight of your car.. mine was 1501 RTR.
i also personally ran all hard parts, i think he only ran hard arms and front tower.. not sure .
also if youre not running a slipper eliminator @ OCRC with a mid motor you might as well just buy a rear motor :P
