    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 08-08-2014, 10:42 AM   #6691
wayboarder's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Wildcat1971 View Post
I was thinking about going from 3-2 to 3-1. I fould like more forward drive coming out of the corners. I am hoping the car will square up better. going to try the .5 inserts also. The 3-1 will take away some of the plushness in landings, so unsure if I want to do that.
You won't even notice the jumping difference.
wayboarder is offline   Reply With Quote
Old 08-08-2014, 02:14 PM   #6692
Goodesta's Avatar
Send a message via AIM to Goodesta
this was probably mentioned 11234543 times in this thread but....any idea when the factory team is coming out?
John Goode
Island Raceway, Lindenhurst, Ny / JConcepts / Trinity / Goode's Graphics / Team Ballz Racing
Team Associated B6
Team Associated B64
Goodesta is offline   Reply With Quote
Old 08-08-2014, 02:22 PM   #6693
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You're right, it has been mentioned about 11234543 times in this thread...and probably another 11234543 times in the B5 thread as well.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-08-2014, 02:23 PM   #6694
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I hope they never come out with one.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-08-2014, 02:31 PM   #6695
Trader Rating: 137 (100%+)
Originally Posted by QDRHRSE View Post
Jcopeland1, have you tried to tune rather than ad weight? I would try to adjust anti squat. Less is more on a MM car. I think you'd be better off trying to find traction mechanically rather than throwing weight on.
I agree, but I like the idea of having aluminum back there for suspension mounts. And once the regular top shaft goes back in it will pretty much be setup like my mod car is with the exception of the V2 slipper on the stock car, and the Nova going on the mod buggy today for racing tomorrow.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 08-08-2014, 02:31 PM   #6696
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
I hope they do..because I don't have the MM yet. I will one way or anther this fall though.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 08-08-2014, 02:37 PM   #6697
Only mid-motor car I ever ran that had plushness with little to no anti-squat was the Hobby Pro PR S1. Was a tank too, but could run 3/0 and no chassis slap.
Old 08-08-2014, 06:02 PM   #6698
What is the front outer hinge pin size??
bLamey470 is offline   Reply With Quote
Old 08-08-2014, 06:26 PM   #6699
Tech Legend
Wild Cherry's Avatar
Default Shock Set Up Tip
Measure the shocks stroke length.
Front = 20mm
Rear = 26.5mm
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-08-2014, 06:36 PM   #6700
Tech Legend
With the shock eyes screwed on all the way .
Front = 18mm
Rear = 24mm
Adjust to the correct length .
Will gain more grip & improved landings ..
George W. Cherry
Old 08-08-2014, 10:30 PM   #6701
Tech Legend
New front set up
Hard front B5r arm
B5m tower
Shock
1.4x3 flat piston,35w, green spring, 4 mm internal limiter, 18mm shock travel
Shock position = inside on tower & outside on arm.
Personally really impress with this set up.
Car gains a lot stability on the turns, finish's the turn on exit really good.
Highly recommend to try....
George W. Cherry
Old 08-09-2014, 05:32 AM   #6702
Rybeau40's Avatar
I have two questions:
1. How often do you guys change your Schelle slipper pads on the b5m
2. Are getting new front tires done as often as the rears?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 08-09-2014, 07:34 AM   #6703
Trader Rating: 42 (100%+)
Ordered the mid motor conversion. Tired of getting beat in the corners on a high grip indoor track with the B5RM. Hopefully the difference is substantial.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 08-09-2014, 08:09 AM   #6704
Send a message via ICQ to JiuHaWong
Does anyone know if the diff rings that come with the MIP puck system are the same size as the AE stock rings?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 08-09-2014, 08:26 AM   #6705
Trader Rating: 478 (100%+)
The B5 versions of pucks dont include a gear or rings.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
