    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-03-2014, 11:23 AM   #6541
Default Rear Aluminum Hubs AE
Hey guys I was looking in to getting the Aluminum Rear hubs (91548). I see most people using a 3mm shim with them. What lenght Ball Stud do I need 10mm or 12mm? Also changing out the plastic inner ball stud mount to the aluminum one, Do also need longer ball studs for that also?
Watkins is offline   Reply With Quote
Old 08-03-2014, 11:30 AM   #6542
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Aluminum on both ends of the camber link.... Something is going to bend or snap eventually. Some plastic on either side will help absorb impacts a bit more
ryanpatrickgore is offline   Reply With Quote
Old 08-03-2014, 12:08 PM   #6543
Tech Legend
Wild Cherry's Avatar
Smile
Use 8mm ball stud on rear hubs..
Lighty snub the grub screw , do not torque.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-03-2014, 12:13 PM   #6544
Tech Legend
Originally Posted by suby723 View Post
The right way to run inline.
Looks good but I don't know ...
Your last post claimed inline was the worst ..
George W. Cherry
Old 08-03-2014, 12:22 PM   #6545
lbckevin's Avatar
Trader Rating: 91 (99%+)
He stated your inline setup was not good. The standard Centro style was better for him.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 08-03-2014, 12:58 PM   #6546
suby723's Avatar
Trader Rating: 21 (100%+)
Exactly thank you. WC inline = no buano. Hartson inline = dialed.
suby723 is offline   Reply With Quote
Old 08-03-2014, 02:35 PM   #6547
vr6cj's Avatar
Trader Rating: 124 (100%+)
I +1 on that.
To each their own I guess right.
vr6cj is offline   Reply With Quote
Old 08-03-2014, 02:53 PM   #6548
Tech Legend
The inline setup is an absolute joke! Thats the worst setup to run on the car.
IB here his post...
George W. Cherry
Old 08-03-2014, 03:00 PM   #6549
suby723's Avatar
IB here his post...
By calling you a post wh0re wasnt a reference to you? To clarify YOUR inline setup is junk! Obviously actual ae pros have tried the good inline setup.
Old 08-03-2014, 03:00 PM   #6550
3srcracing's Avatar
Trader Rating: 25 (100%+)
On the aluminum rear brace do you run +2 or -2? And how many spacers?
Also the plastic on comes standard with +2 correct?
3srcracing is offline   Reply With Quote
Old 08-03-2014, 03:57 PM   #6551
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by jpcopeland1 View Post
Have them. Put them on, too much back and forth play, took them off. What shims are you using? Did not have any shims that fit so I went back to the stock arms. I received my aluminum rear hubs yesterday as well. Does the etching face forward, or backward, or does it even matter since they are 0 degree?
:: 91548 / 91549 Aluminum Rear Hubs for RC10B5 and RC10B5M
Installation:
When installing the hubs on either the B5 or B5M chassis, the laser etching 0 should face the rear shocks. RC10B5 rear motor: the etching faces the front of the vehicle, towards the shock
RC10B5M mid-motor: the etching faces the rear of the vehicle, towards the shock
With the stock hubs, you could run the insert in either the up or down position. Use a 1mm shim under the ball stud for the DOWN POSITION.
Use a 3mm shim under the ball stud for the UP POSITION.
Stock setup: #2 hole with 3mm shims under the stock (#91047) 6mm ball stud.
NOTE:
If using zero shims, you will need to use a shorter ball stud (#91451 or #91452, 4mm ball studs) than what comes stock on your B5 or B5M. Otherwise, the ball stud could crush the inner bearing.
NOTE:
Use caution when using thread lock on the rear camber link ball stud. DO NOT get thread lock on the CVA axle or hub bearings.
1
3
2
4
NOTE:
! Usethread ! lock on the
included set screw.
NOTE:
The bearing spacers will only fit correctly in the configuration shown.
#1596 thread lock
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 08-03-2014, 05:04 PM   #6552
Tech Legend
Inline battery set up I'm using came from a really , really good Ae driver...
Con !
Tacompton Rules....
George W. Cherry
Old 08-03-2014, 05:09 PM   #6553
vito's Avatar
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 08-03-2014, 06:27 PM   #6554
Trader Rating: 15 (100%+)
Nice Vito.
Tommygun1 is offline   Reply With Quote
Old 08-03-2014, 06:43 PM   #6555
BillPear's Avatar
Send a message via Yahoo to BillPear
Con !
Tacompton Rules....
Who's name is? Or else its just more of your BS!
BillPear is offline   Reply With Quote
