    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-02-2014, 11:06 PM   #6526
Tech Legend
Wild Cherry's Avatar
Sideways battery is very good for lower grip.
Inline rules on higher traction conditions.
Use what works best for you.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-02-2014, 11:40 PM   #6527
3srcracing's Avatar
Trader Rating: 25 (100%+)
Is it normal to have the same setup on the same car but have a totally different feel?
One is mod, and one is stock. It seems like anything I did to the mod car I could not get it to feel like my stock car.
3srcracing is offline   Reply With Quote
Old 08-03-2014, 12:16 AM   #6528
joykiller44's Avatar
Originally Posted by suby723 View Post
The inline setup is an absolute joke! Thats the worst setup to run on the car. Its funny how only 1 post wh0re thinks its the best ever and adding weight blah blah blah.. i have yet to see an actual legit ae driven run that setup.
Btw was Spencer running an ae lightened chassis or stock milled out? Im running slrc lightened chassis on my stock car and its unbelievably dialed.
I ran my B5m inline today at the Surf City classic at OCRC it's dialed..the weight is 1500g post pics later
joykiller44 is offline   Reply With Quote
Old 08-03-2014, 04:32 AM   #6529
Rybeau40's Avatar
Inline didn't seem to hook up very well on medium bite, but I can see it has its merits on high bite.
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 08-03-2014, 04:49 AM   #6530
eper's Avatar
Trader Rating: 14 (100%+)
Can someone with aluminum hubs measure from the bottom of the rear suspension pin going through the hub to the flat top where the ball studs go. And post that please. Looking to try something out but need this dimension thank you.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 08-03-2014, 07:28 AM   #6531
Tech Legend
Mod car will light up bad driving technique and set up because of the increase speed.
Explains why mod requires more skill to drive well compared to a slower car.
George W. Cherry
Old 08-03-2014, 07:46 AM   #6532
B4TravSC10's Avatar
Trader Rating: 33 (100%+)
I measured about 22mm
Www.stickersmakeyoufaster.com
B4TravSC10 is offline   Reply With Quote
Old 08-03-2014, 08:01 AM   #6533
Trader Rating: 137 (100%+)
Originally Posted by Wildcat1971 View Post
are you running the Rm rear arms also? the car is very heavy. should not need a lot of weight even for mod. I dont know your track, but tires here need a certain amount of wear. Seem like the tires need to be ghost pins. I was also told to shave off the outer edges of my rear tires for side bit. Most of the mod guys here run clay slicks as well. Even some stock guys. So maybe we have more traction than you.
Have them. Put them on, too much back and forth play, took them off. What shims are you using? Did not have any shims that fit so I went back to the stock arms. I received my aluminum rear hubs yesterday as well. Does the etching face forward, or backward, or does it even matter since they are 0 degree?
jpcopeland1 is offline   Reply With Quote
Old 08-03-2014, 08:11 AM   #6534
And new tires.... hehehe
Old 08-03-2014, 08:53 AM   #6535
does anyone know if the v2 big bore shock O rings and spacers will work in the v 1 big bores ?
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 08-03-2014, 08:58 AM   #6536
Speed Freak RC's Avatar
I know a guy here bought the V1 rebuild kit by accident, and once built the shock shafts would hardly move at all.
Speed Freak RC is offline   Reply With Quote
Old 08-03-2014, 09:07 AM   #6537
rcgod's Avatar
Trader Rating: 27 (100%+)
I'm using the X rings in v1 shocks no problem. But also using v1 bushings and spacers.
Inline setup is dialed for me on high bite. Gear diff with 2k oil. Also tried blue csi pistons and the car has never felt better. Been going back and forth between 2 and 3 hole setups and car soaks up bumps like a cadillac with csi. Anyone else tried them?
I didn't have to cut the waterfall brace using short servo.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 08-03-2014, 09:29 AM   #6538
gticlay's Avatar
Or on a clay track - more worn in tires, almost bald.....
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 08-03-2014, 10:50 AM   #6539
pumpkinfish's Avatar
I tried the inline setup and didn't like it at my track. If anyone wants to buy my cut parts, pm me and we can work out a deal.
pumpkinfish is offline   Reply With Quote
Old 08-03-2014, 11:09 AM   #6540
suby723's Avatar
Trader Rating: 21 (100%+)
The right way to run inline.
Official Team Associated RC10 B5m Mid-Motor Thread-screenshot_2014-08-03-11-04-18.jpg
suby723 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
